***ECUFlash Now For Base Lancers!***
Old Dec 1, 2006 | 11:49 AM
  #331
Z_Lancer_Man's Avatar
Originally Posted by Redlancer
At this time, I reach my goal.... I tune my car to run with 87 octane gas (AFR between 12.5-12.7)... I increase HP and get better MPG than before. That's also help to remove the flat spot.
You know with the $$$ of the gaz that just goes up, I want to extract more MPG from my car. (I do 350 miles per week just for the work)
That's great! This is just an overall wonderful tool. I'm glad to see it being used. I feel bad myself because I really need to do some more tuning to get my injectors set right and boost levels right. Hopefully next semester I'll have more time for tuning. Now that it's starting to snow here, road conditions aren't really ideal for tuning
Old Dec 10, 2006 | 08:41 PM
  #332
PGDlancer's Avatar
i seem to have some confusion about this tune vs. the piggy if my lancer is NA. if any of the guys checking this thread can clarify some things for me, please click https://www.evolutionm.net/forums/sh....php?p=3745220 and help me out. I actually did read through this thread and am now thoroughly confused. thanks ahead of time......
Old Dec 11, 2006 | 06:53 AM
  #333
I've responded to your thread. Hopefully it helps clarify things for you a bit.
Old Dec 16, 2006 | 04:22 PM
  #334
Wallesasuaz's Avatar
Okay I'm having a problem w/ my car lately. It's nothing on the bad side.. Just the annoying side. LOL
I have an automatic starter on my car and lately I'm having problems with the car starting. I have an idea that it could be the timing belt since it's time to have it changed. But, also I've tested that theory out and notice something else. My revolutions go pretty high everytime on cold starts. Way above the normal 2000. I guess this causes my alarm to disengage and turn the car off.
So my main question, can I extract my rom, and adjust my idle settings on the cold start portion with the OPENecu prog?
Old Dec 18, 2006 | 09:32 PM
  #335
quickie's Avatar
Damn that was a lot of reading....
Anyhow, I've got an 02 LS (technically OZ) Auto. Live in Jersey an willing to meet anyone to work on this. Iv'e presently got a piggy in the car and have been let down after it was reflashed by RRM. If this is really is what it seems to be, I'm down for a a get together. I've already downloaded the program, got a laptop, all I need is a cable, and anyone in the ny/nj area...
I'll bring the beer...
Old Dec 19, 2006 | 06:36 AM
  #336
Well have you atleast extracted your rom and tried to define it? Gotta make sure you have a good definition file to read your rom!
Old Dec 19, 2006 | 07:40 PM
  #337
quickie's Avatar
I'm confused Don't take this the wrong way but, 1.) don't I need the cable to extract the rom from the ECU? 2.) I extract it & then Idefine it, right?
If I understand it correctly, without the cable, I'm stuck
Old Dec 19, 2006 | 07:43 PM
  #338
oh my bad... i mis understood your earlier post. I thought you already had the cable. lol
1. Cable for the connection.
2. Program to make it all work.
3. Extract then define.
4. Tweak
5. Upload to ECU.
Old Dec 19, 2006 | 08:10 PM
  #339
quickie's Avatar
no problem, If this realliy is as promising as it sounds, I can get rid of my
piggy v2... It was AMAZING when I first got it, then I got it reflashed & the power disapeared!!!
Old Dec 27, 2006 | 10:27 AM
  #340
wondering... Can we clear CEL codes? Will they just go away with a reflash?
Old Dec 27, 2006 | 11:30 PM
  #341
krnzzang84720's Avatar
hey guys! does anybody have tuned map for those mods,
Ported 4G93 Mani, Eclipse 65mm TB, Intake, 2.5 Exhaust
PlZ plz let me have the map!
Old Jan 2, 2007 | 09:55 AM
  #342
wickdaddy's Avatar
Well decided to just use my laptop to tune and got my cable today! Can't wait to get home and hook this thing up!
just had a quick question... before I start flashing and such... if I am 'tuned' with my SAFC now, do I need to disconnect this before I start flashing?
Old Jan 2, 2007 | 10:52 AM
  #343
Actually, to be on the safe side, you should. Just cut the power on the SAFC. That way you don't have to disconnect every single wire.
Old Jan 2, 2007 | 11:27 AM
  #344
wickdaddy's Avatar
so should i pull the rom off with the safc connected. then disconnect the power to the safc, reflash the ecu with the pulled rom and then go from there with the safc disconnected?
Old Jan 2, 2007 | 11:35 AM
  #345
Cancel out the SAFC Totally. There won't be a need for it if you're gonna be tuning the eCU directly.
