***ECUFlash Now For Base Lancers!***
Old May 9, 2007 | 06:16 AM
  #556
Newfoundlancer's Avatar
Definitely interesting... but on the bright side, we still have a way to tune the ECU in order to run turbo while waiting to save up the cash for a full standalone unit... which also saves from having to buy a piggyback with a turbo kit... which saves money for a standalone. As you say, that condition is rarely going to happen... the only case for me for instance would be where I like to gear down a bit heavily... again however, this will make for negative load, and it won't dump the extra fuel in. Overall, I'd say we're still fine... for now. At least, us N/A peeps can still safely lean out the fuel maps and draw out whatever power is hiding in the lancers.
Old May 9, 2007 | 02:37 PM
  #557
lancerrally45's Avatar
AT LEAST WE CAN STILL GO WITH BOOST.
Id rather be able to go boost then not be able to at all.
Old May 9, 2007 | 03:11 PM
  #558
Z_Lancer_Man's Avatar
I sent this to wickdaddy in a PM, but I thought I'd share it with all of you:
Under normal driving, even aggressive driving you'll never drive in that region. The only time I can really think of needing to drive in that area is if 3rd, 4th and 5th gear all died and you needed to drive somewhere quickly in second gear, but your throttle can't be pushed further than 15% because your legs are too short
Old May 9, 2007 | 03:13 PM
  #559
wickdaddy's Avatar
i really don't think this is going to be any bit of an issue... if you are running high rpms and low throttle, it's time to shift to the next gear...
unless of course you are running 5 grand in 5th, then its time to gradually hit the breaks
Old May 11, 2007 | 06:50 PM
  #560
I finally got all of my stuff in to tune my car. cord, and wideband. Ill be tuning tomorrow after i get out of work hopfully. Ill post maps once im done.
Old May 13, 2007 | 02:50 PM
  #561
I have ran into a problem. I got the zeintrax wideband and i installed it in my downpipe. I ran the lines through the firewall and all of that is done. all i have to do is hookup the signal wires and i have no idea were to hook them up. im almost postive they run to the ecu wires but i dont know what wires (from the wideband) go to what pin number.... thanks
Old May 13, 2007 | 03:19 PM
  #562
I'm afraid this thread won't be much help. Have you done a search for the wideband? And do you mean Zeitronix or do you mean zeintrax? If you mean Zeitronix, have you taken a look at the instructions? : Zeitronix Installation Instructions
Old May 13, 2007 | 03:52 PM
  #563
Sorry about that i spelled it wrong. yeah it is a zeitronix. i have the instructions but i dont know what pins are what. and which one is (for example) power, ground. ..in my ecu harness
Old May 13, 2007 | 08:30 PM
  #564
wickdaddy's Avatar
our ecu pinout is pretty much the same as the evo 8. same locations for the items that you do have... like you don't have an intercooler sprayer
here is a link to RRE's pinout
Old May 13, 2007 | 08:35 PM
  #565
ok i have that, now how do i figure out what wires are what?
Old May 13, 2007 | 08:39 PM
  #566
wickdaddy's Avatar
just click on the link in my last post. those will explain the meaning of the numbers
Old May 13, 2007 | 08:44 PM
  #567
You da man WICKDADDY
Thanks for the help, now i can hook it all up and TUNE!
Old May 14, 2007 | 01:05 PM
  #568
wickdaddy's Avatar
anytime bro
Old May 14, 2007 | 02:07 PM
  #569
I got it all hooked up but my computer is sayen that the driver is not being installed for it. so that means on some computers you have to set up a com/port for it. i know some about computers but not that much, so im taking it in tomorrow to have it looked at
Old May 14, 2007 | 02:25 PM
  #570
kungfugirl's Avatar
what do the rpm's have to be at to be put into this limp mode, at low throttle, im thinking of picking up the tractix cable.
