***ECUFlash Now For Base Lancers!***
Old Jun 8, 2007 | 07:24 PM
  #601
Z_Lancer_Man's Avatar
Originally Posted by sykou
read thru most of the thread and ive only seen zlancer's maps but he's turbo...SO i'm wondering what results someone who is NA is getting. AFRs and such....This seems to be more beneficial to the turbo guys cuz timing becomes an issue at higher rpms but for us NA guys i dont think thats a problem or at least i havent had to touch the timing...I looked at the parameters you can adjust such as injectors, timing, etc but even highly modified NA's wouldnt have to touch those things...or am i wrong??? So i guess what i'm trying to say is for NA guys the RRM Piggy is tunable enough to get what you need. But for turbo guys you need to adjust other things due to higher injector/fuel needs... Someone tell me if i'm wrong
Timing is usually not a concern like you said for NA guys. Maybe a little adjustment is needed as you lean out the top end, but nothing like turbo guys. The piggyback is fine for that, as long as you're confortable paying $400+ for something that does the same thing ECUFlash does for $90 (cost of cable).
Old Jun 8, 2007 | 07:38 PM
  #602
Redlancer's Avatar
I'm N/A... I retard the timming a little bit from mid to top end to keep away the knock.... I leaned the afr to increase my MPG... My car seen to knock a little with the stock flash and burn more fuel... (Because the Ecu switch to the Low octane map...)
And you can datalogging with the cable too with EvoScan.
Old Jun 8, 2007 | 07:55 PM
  #603
kungfugirl's Avatar
what do u have urs leaned doown too redlancer?
Old Jun 8, 2007 | 09:52 PM
  #604
wickdaddy's Avatar
Isn't that a universal fuel pressure regulator from Ebay?? Please tell m it isn't
It was on the car when I bought it, but didn't work so one of the guys that tuned my safc replaced my old one with that one
Old Jun 12, 2007 | 05:14 AM
  #605
sykou's Avatar
so... anyone get around to making a nice map for NA yet? Jus curious as to what AFRs people are getting with this ecuflash
Old Jun 12, 2007 | 07:56 AM
  #606
For N/A, you'd want to be aiming for AFRs of 12.5s. That was determined to be the safest for the engine and still provide the most power. For the turbo'd guys, AFRs should be around 11.2, unless you put on a decompression head gasket in which case you could increase it to 11.5.
Old Jun 14, 2007 | 04:39 AM
  #607
MR's Avatar
MR
1.6L NA Lancer
Can someone assist in the definition xml file for this rom?
File Type: zip
Old Jun 14, 2007 | 09:53 AM
  #608
It should be finished soon!
Old Jun 14, 2007 | 11:15 PM
  #609
MR's Avatar
MR
Thanks dude! cant wait to be able to get the ride tuned up....
Shall wait ....
Old Jun 21, 2007 | 08:52 PM
  #610
MR's Avatar
MR
Any update?!!!!???
Old Jun 21, 2007 | 09:12 PM
  #611
We need some more information from you about your Lancer. What is the model? Does it use a MAF or a MAP for air metering?
Old Jun 23, 2007 | 08:25 AM
  #612
MR's Avatar
MR
It is a 1.6L version..Lancer GLX... MAF...
Old Jun 23, 2007 | 11:42 AM
  #613
4G93/NA's Avatar
hey how about 5g mirages??
we tried but it did not comunicate with ecu!!
Old Jun 28, 2007 | 09:12 PM
  #614
lancerrally45's Avatar
as for tuning with a turbo. do you guys know how to tune over the %100 load. using ecuflash. because if you cant tune it then what would happen if you are at 5 grand? boom?
Old Jun 30, 2007 | 07:42 AM
  #615
What do you mean @ 5 grand? Are you talking RPMs? I've taken my turbo'd OZ past redline without a problem at WOT and full boost. Just gotta watch those AFRs, knock sensor and EGTs.
