Evo 8 ECU Swap Works!!!
Old Aug 6, 2009 | 04:33 PM
  #106
senate6268's Avatar
Originally Posted by zulu989
hey senate can i use an 05 evo 8 ecu
You can use ANY ECU as long as it's from an Evo 8.
Old Aug 6, 2009 | 10:07 PM
  #107
lilazn64's Avatar
-8- You now need to add the following values from your stock Lancer ROM tables to the matching tables in the Evo ROM to have a proper idle and fuel trims: Injector Scaling, Injector Latency Values, MAF Scaling, MAF Size.
By "Injector Latency Values", do you mean "Injector Battery Voltage Latency Compensation"? Because I can't seem to find Injector Latency Values
Old Aug 7, 2009 | 05:40 AM
  #108
zulu989's Avatar
sweet, cant waittt
Old Aug 7, 2009 | 06:46 PM
  #109
senate6268's Avatar
Yes. They are one in the same. By adjusting the voltage values you either increase or decrease the latency of your injectors. These are the values you adjust when you swap to bigger injectors.
Old Aug 7, 2009 | 09:01 PM
  #110
lilazn64's Avatar
alright i thought so, just wanted to make sure
Old Aug 11, 2009 | 04:09 PM
  #111
gr1910's Avatar
you can use ANY evo ecu, as long is not MIVEC....
a friend is runing 20psi with an evo5 ecu on a 4g93
a good thing also is to change the MAF an MAP for the evo one... evo maf detects boost
Old Aug 12, 2009 | 04:45 PM
  #112
senate6268's Avatar
WRONG.
The Evo and Lancer MAP sensor are the exact same part. Switching to an Evo MAP sensor would be the same as replacing your stock MAP with another Lancer stock MAP.
Also, it's not the MAF that detects boost. It's the MAP sensor that reads the pressure in the manifold.
Old Aug 12, 2009 | 10:07 PM
  #113
03lances's Avatar
deleted
Old Aug 30, 2009 | 02:33 PM
  #114
itscypha's Avatar
could i run this ecu with a n/a lancer for the evos 2step thats built into ecu? thats what im looking for really is just two step and hopefully when i go turbo ill have something to work better off. lmk. thanks.
Old Aug 30, 2009 | 06:14 PM
  #115
senate6268's Avatar
You could. You would need to scale the injectors down to 232 and get the latency values running right. You would also need to replace all the MAF values with the stock Lancer MAF values. You would then need to lower the amount of fuel in the fuel tables so you don't run overly rich. The Evo ECU is meant more for a turbo Lancer than a N/A Lancer, but that doesn't mean it can't be done.
Old Sep 19, 2009 | 09:02 PM
  #116
johnnyr55's Avatar
this is interesting lol .. i had posted this a while back and you said it was not possible essentially.. Good to hear you got it working tho.. Your engines are similar and most mitsu engines are similar with coil packs and injector setup as well as timing electronics.. It is possible for autos to run the ecu in conjunction with your stock ecu which controls the tranny.. I have been doing it for long time with no ill effects.. My original post was https://www.evolutionm.net/forums/la...ed-lancer.html
The map sensor off an evo X is a 3 bar map sensor by the way but you have to patch the evo ecu to run it properly but its available if u search the ecuflash section under evo.
It requires alot of tuning to run this ecu NA by the way and you probably wont perfect it..
It requires a lot of wiring but its not hard.
Old Sep 25, 2009 | 05:40 AM
  #117
*02Lancer*'s Avatar
Thank you senate! lol looking and pming people with evo ecu's :P. I know a couple post back they were talking about the 2 step have you tested this function of the ecu yet senate? i dont see why it wouldnt work.
Old Sep 25, 2009 | 07:04 AM
  #118
pqek666's Avatar
I've already broke 2 cv joints... my 2 step now its disabled... but my car is a mirage, with evo 5 ecu reflashed... and my 2step was about 4700rpm and with my foot down the floor it boost like 6 or 7 psi, my cv joint can't handle it... maybe less rpm...
Old Sep 25, 2009 | 09:04 PM
  #119
senate6268's Avatar
The 2-step requires additional wiring from the clutch pedal position switch to the ECU harness connector. It utilizes a wire that the Lancer does not have. Without that signal wire to the ECU, the 2-step does not work. If people want the info I'll post the instructions, but I don't have any plans to add it into my Lancer. I'm more than happy with feathering my clutch out on launch.
Old Sep 26, 2009 | 06:37 AM
  #120
*02Lancer*'s Avatar
I will want the information on how to get it but first i have to find a dang ecu :P they all sold! lol
