Confirmed: Evo ROM Can Be Flashed to Lancer ECU
Old May 9, 2010 | 09:48 PM
  #241
link62's Avatar
yea it takes a while to start moving foward and its slow doing it and when i get up to speed i get knock plus when shift the car from park to revese the tranny does it hard and going from reverse to drive it does the same
Old May 9, 2010 | 09:52 PM
  #242
03lances's Avatar
I have noticed the high knock as well. I had to drastically reduce my timing compared to my stock rim I was running before that. Not sure why either. I have been busy in my days off clearing my property to build so haven't been able to tune more but as of now I still get counts of 7-9 and my performance is suffering due to the extremely low timing.
Old May 9, 2010 | 10:00 PM
  #243
4g94T's Avatar
Have you tried adjusting the transmission maps with the stock ROM and not the GTA rom?
Old May 10, 2010 | 12:10 AM
  #244
bvasquez12's Avatar
Im confused, 03lance, are you auto?
Old May 10, 2010 | 12:12 AM
  #245
link62's Avatar
no hes not
Old May 10, 2010 | 12:16 AM
  #246
RoadSpike's Avatar
You should try adding 1 to the knock multipliers 03
I'm figuring that your knock is just engine noise just remember you have to be careful
Old May 10, 2010 | 12:22 AM
  #247
03lances's Avatar
Link is correct I am not auto but the knock problem seems to be universal with these evo roms when transitioning for the lancer rom
I can try this only thing I am scared of is what if this is infact real knock? I asked senate before if he has adjusted his knock maps at all and he has not. Man there has to be a way to find out for sure but idk if its possible yet.
Old May 10, 2010 | 12:33 AM
  #248
RoadSpike's Avatar
get some race fuel and see if it persists pretty easy test.
Old May 10, 2010 | 07:20 AM
  #249
senate6268's Avatar
One thing that's been weighing on my mind ever since I swapped to an Evo ECU was if the Evo and Lancer knock sensors are different. I don't know if the signal being output from the Lancer knock sensor is being interpreted correctly by the Evo ROM. I don't have these large counts of knock that people are running into, but I do occasionally have a sub-10 knock count in certain acceleration situations that I'm still working out. I had them with my Lancer ECU too, so I'm not too overly concerned.
Old May 10, 2010 | 08:46 AM
  #250
03lances's Avatar
This is true never thought of that. Would I run it straight? Or more of a mix?
Old May 10, 2010 | 09:21 AM
  #251
RoadSpike's Avatar
Mixing would be fine but straight is even better. You just want to bump the octane enough to believe it shouldn't knock with those settings.
Old May 10, 2010 | 09:43 AM
  #252
bvasquez12's Avatar
Okay hes not auto, so the evo rom Being flashed onto lancer Ecu is NOT going to work the same as using the evo ecu, or is this a problem faced with the evo ecu as well?
Old May 10, 2010 | 11:30 AM
  #253
03lances's Avatar
There is no dicernable difference for me when I had the evo ecu I had the exact same issues.
Old May 10, 2010 | 11:32 AM
  #254
RoadSpike's Avatar
It probably is a different knock sensor all together which is why it picks up weird knock issues. Perhaps the evo knock sensor isn't as sensitive?
In any case it can easily be tuned out with corrected knock multipliers for low, mid, and high rpm.
Old May 10, 2010 | 11:50 AM
  #255
03lances's Avatar
so I guess after I get some race gas and test this out and confirm the knock is still there I will have to flash back my original evo ROM I made to directly replace the lancer rim I was running then adjust the knock multipliers until I am hitting the same knock I was with the lancer ROM in place does this sound right?
