Old News!! 4G64 Swapped Into A 2002 Lancer
Old Dec 30, 2007 | 05:46 PM
  #346
Jehuty's Avatar
not a direct swap, the heads need to be welded on if I'm not mistaken, basically everything that he's done is just to show that Lancers have an engine swap that they can do! lol
Old Dec 31, 2007 | 08:56 AM
  #347
ihearthondas's Avatar
What axles did he use? and how much power can those handle? anybody know?
Old Dec 31, 2007 | 10:41 AM
  #348
Tech@SA573's Avatar
What head are you guys talking about putting on what block? Are you talking about the 4G63 head on a 4G64 motor? I don't know the specifics on that one, but I seriously doubt it involves welding the head on. If you're talking about the OP's swap, he used a 4G64 head on a 4G64 block. Nothing special needed for that...just an oem 4G64 head gasket. If your talking about the 4G94 head on the 4G64, forget about it. It doesn't fit.
This swap uses your Lancer's stock axles. You're using your stock transmission internals in the F5M42 (the transmission from the 2.4) housing. That's the whole point of doing it that way. So that you don't have to make custom axles.
As for how much power they can handle...no one knows. I don't think I've even heard of anybody breaking the Lancer's axles because of too much power. Then again, we haven't really seen anybody make much more than 300whp
Old Dec 31, 2007 | 11:38 PM
  #349
Jehuty's Avatar
Yes we are talking about the 4g63 head, and yes it does require some modification through welding. Of course and g64 wouldn't need modification on its own blcok, and lastly why the hell would we want to pt a g94 head on a g64 block, that's insanity, lol
Old Jan 1, 2008 | 06:28 PM
  #350
True_Story's Avatar
what modifications need to be done to the head through welding?
Old Jan 2, 2008 | 03:09 PM
  #351
Jehuty's Avatar
F@ck if I know, read this entire forum, do not just start on page 24, read everything, and you'll see that it has to be welded on, I personally do not know.
Old Jan 3, 2008 | 10:20 AM
  #352
True_Story's Avatar
weld on a head? ha! highly doubt that!
Old Jan 6, 2008 | 06:03 PM
  #353
ambystom01's Avatar
Dammit....oh guys unless someone can provide a link, cut it with this pissing contest (since neither of you seem to be able to prove your point).
True_Story, please edit or delete your last post, there's no need for that on here.
Old Jan 6, 2008 | 07:00 PM
  #354
SASD209's Avatar
Admin Alumni
Fixed.
Old Jan 6, 2008 | 07:03 PM
  #355
ambystom01's Avatar
Yeah JD, high five!
Old Jan 6, 2008 | 07:28 PM
  #356
SASD209's Avatar
Admin Alumni
Old Jan 7, 2008 | 07:52 PM
  #357
True_Story's Avatar
now i have a question....if we (non evo lancers) cant put the whole 4g63 motor in our car ....and the 4g64 block drops in our cars ...how is it that the evo's can throw in a 4g64 block to do the stroker thing but we can put the 4g63?
Old Jan 7, 2008 | 08:04 PM
  #358
ambystom01's Avatar
I would assume it's a clearance issue more than anything else. Does anyone actually know what's involved in putting a 4G63 head on a 4G64 block cause that might help answer the question.
Old Jan 7, 2008 | 09:22 PM
  #359
True_Story's Avatar
i know alot of the 3rd gen eclips guys do it......
from this
to this
Old Jan 8, 2008 | 04:50 AM
  #360
Jehuty's Avatar
There is someone, but he is an evo who did the whole evo head on g64 block, and he has posted before. I don't think it was on this forum, I'll look for it and let you all know.
