RRM Short Ram Intake discussion thread
Old Oct 17, 2007 | 09:18 AM
  #406
08Lancer89's Avatar
Rob are you guys making a heat shield?
Old Oct 17, 2007 | 04:04 PM
  #407
krnkimchi702's Avatar
hey Rob when are the cf engine covers comming out? does it look like the stock cover only with cf on it?
Old Oct 17, 2007 | 04:07 PM
  #408
jappaswat's Avatar
Originally Posted by ROCK
It iwll get you laid!
ROAD/RACE
i'll take 100 of those please.
Old Oct 17, 2007 | 04:17 PM
  #409
^ if it has the RRM guarantee then sign me up
Old Oct 20, 2007 | 01:13 PM
  #410
FinestSoldier's Avatar
Hey RRM, I got a code from the intake?? i thought their was no ses? The code was "P0171 System too Lean (Bank 1)" I hope i don't get it again cause i will be forced to remove asap. Thanks
Old Oct 20, 2007 | 02:35 PM
  #411
08Lancer89's Avatar
I havent had any problems or codes show up with mine yet.
Old Oct 20, 2007 | 02:47 PM
  #412
Consider yourself lucky and my *** unlucky
I did a longer reset of the ecu so long that even my navigation when through a reprogramation . I let the car idle for about 15mins without even touching gas. I let it idle while i programed my audio settings again and all taht good stuff.
I hooked up my scanner and i had a pending code which was "P2195 Oxygen (A/F) Sensor Signal Stuck Lean
(Bank 1 Sensor 1)"
i reset the codes with my scanner. i let the car idle again but while i gave it a couple of good revs and back and forth motions. the pending code or anything codes have not yet to appear but i will report back tommorrow after my drive to wrok. on any updates.
Old Oct 21, 2007 | 12:38 PM
  #413
ok today after about 70 miles driven after a long ecu reset process, i still managed to get code P0107 system to lean bank 1 pending! Why do i have to have such ****ty luck not only that but i hit a possum that broke my skid plate on the front bumber!!! and bent my condensor! I noe i heard someone else had this problem with the code???
Old Oct 21, 2007 | 01:04 PM
  #414
I found the topic https://www.evolutionm.net/forums/sh...d.php?t=294781, He is having the same problem as me! Maybe its the piggy that as soon as it senses the intake it starts throwing codes, RRM please resond asap guys thanks, i will probaly be giving a call monday anyways to speak on the phone to see what we can do. Thanks
Old Oct 21, 2007 | 01:46 PM
  #415
WhiteGTS18's Avatar
do you have the pzev lancer like the one in cali? i think that is why it is throwing the codes because that is the only time ive heard of throwing codes on the regular lancer vehicles but i could be wrong.
Old Oct 21, 2007 | 01:58 PM
  #416
new jesrey , california and like 3 other states now carry teh pzev engines , but if this the case then RRM should had put that as a note? This is just turning into another nightmare
Old Oct 21, 2007 | 02:01 PM
  #417
wow that really sucks.. it seems like RRM doesn't know what to do with this problem.. b/c when the other guy called RRM they havn't really delt with that problem i wasn't going to buy a piggy anyways so it won't affect me.. *knock on wood* but yeah hope everything is alright...
Old Oct 21, 2007 | 02:55 PM
  #418
08Lancer89's Avatar
wish you the best man! I dont have thee piggy too, so like you said it could be that but I dont know, PM Rock and see what he has to say, best of luck to you!
Old Oct 21, 2007 | 03:17 PM
  #419
Thank you all for the blessings, i will be calling rrm tomorrow to see what we can do first before i return teh piggy or soemthing.
Old Oct 21, 2007 | 03:38 PM
  #420
polar1120's Avatar
hey I have the piggy and am from Cali so I have the PZEV haven't had any codes yet. Could it of been a bad batch maybe? Did you guys buy them around the same time?
