swapped to an eclipse 501 MAF
Old Jul 31, 2009 | 10:14 AM
  #76
JRR's Avatar
JRR
the newer the cable the more cars it can do support wise. i think the 2.0 can do all evo's now where like the 1.3 there were a few that were missing for support. i was lookin at the 2.0 but i couldnt beat the deal for the 1.3
Old Jul 31, 2009 | 10:21 AM
  #77
imalancerman's Avatar
So basically, if a 1.3 works for you, no reason to up it to a 2.0?
Old Aug 2, 2009 | 08:34 PM
  #78
JRR's Avatar
JRR
the only rason fo me to get the 2.0 now is if i get an x or if i find more of a reason to get one. im happy with my 1.3 as of now.
and on a side note check this out in my thread. i think i mite be runnin a little too rich with my afr's.
https://www.evolutionm.net/forums/7350306-post132.html
Old Aug 2, 2009 | 08:47 PM
  #79
4g94T's Avatar
JRR: if your using ECUflash, ditch the piggyback. That explains your rich AFRs
Old Aug 2, 2009 | 09:00 PM
  #80
link62's Avatar
i thought he took out the piggy and 5th injector for the 4 wrx injectors or you havent put them in yet?
Old Aug 2, 2009 | 09:08 PM
  #81
JRR's Avatar
JRR
didnt get time today to put them in. hopefully this week
Old Aug 2, 2009 | 09:09 PM
  #82
link62's Avatar
yea i would do it when you get a chance and like 4g94t said it could bet the piggy
Old Aug 2, 2009 | 09:14 PM
  #83
JRR's Avatar
JRR
and that was what i was kinda thinking as well since i "tuned" the car on the piggy with the stock 605 and also in november, but as of late until the swap shes been a little thirsty and she felt a little sluggish in the top end. still spools nice and smooth,but the top end is now where it hesitates. maybe ill get to work on it a work tomorrow....
Old Aug 2, 2009 | 09:28 PM
  #84
02-Lancer-Es's Avatar
Dam im a fkn noob =[
I would want to do this but have no clue on what you all are talking about lol .
I understand the concept on how the 501 would allow more flow but i have no idea on how to "Flash" the car .
Would like to know .
Old Aug 2, 2009 | 10:10 PM
  #85
JRR's Avatar
JRR
for that you need a special cable from www.limitless.co.nz\cables (i think thats the address) or tatrix.com. once you get that then you can get such programs as evo scan for datalogging and ecu flash which then lets you change values in your ecu.
but just remember when doing so, that you can mess things up really fast, so always make a backup for a failsafe!
Old Aug 2, 2009 | 11:08 PM
  #86
I wish it was that easy for me , i used to have a piggyback but car ran worst and sold it . But i would like to do this mod just for fun and a tinny gain . But where would i find the values ? Just copy them down from Senate on his picture post ?
So i would need Ecuflash , Wire and EvoScan ?
I would need to change the settings on my Ecu to the settings in the picture on Ecuflash with the wire connected to a laptop while the car is on or off?
Lol im a fkn noob =/
Sorry guys this is the only thing im a noob at haha .
Old Aug 2, 2009 | 11:32 PM
  #87
JRR's Avatar
JRR
yes those are the values that you need to change. senate is like the all knowing zues god around here.
you need to have the car powered to the accessory spot on the ignition to read/write to the ecu.
and yes you need the usb to obd2 mitsu cable from wither one of those sites , ecu flash to actually read/write to your ecu and evo scan is just to datalog but worth the $25 bux for what it does and can do
Old Aug 3, 2009 | 09:51 AM
  #88
Can anyone give me a link of a good place to buy the open port wire . Not sure i found them on Tactrix but not sure what i need . On there site it also had a memory stick and holder thing .
Old Aug 3, 2009 | 10:11 AM
  #89
Whats the diff between these 2?
All i need is the 1.3 right ? Would the 2.o make any difference ?
Thanks alot guys!
http://cgi.ebay.com/ebaymotors/OpenP...=p4506.c0.m245
http://cgi.ebay.com/ebaymotors/Tactr...=p4506.c0.m245
Old Aug 3, 2009 | 10:35 AM
  #90
senate6268's Avatar
Thanks alot guys!
OpenPort 2.0 is only needed if you plan on flashing/logging an Evo X. Lancers only require the OpenPort 1.3 cable. It's as simple as that.
