swapped to an eclipse 501 MAF
Old Aug 3, 2009 | 10:46 AM
  #91
02-Lancer-Es's Avatar
Originally Posted by senate6268
OpenPort 2.0 is only needed if you plan on flashing/logging an Evo X. Lancers only require the OpenPort 1.3 cable. It's as simple as that.
Oh ok thanks!
Hmm not sure which one because i also own a 08 Lancer but not sure if i want to mess with any settings since the car comes with a full 100,000 mile warranty bumper to bumper and car has 20k miles . Stock with Axle back and Intake.
Old Aug 3, 2009 | 10:53 AM
  #92
imalancerman's Avatar
Just reflash the stock rom back on if you take it in for warranty work. Does the 08 lancer have a restrictive MAF as well?
Old Aug 3, 2009 | 11:19 AM
  #93
Nope doesnt have the same style maf as the 02-06 It has a drop in sensor . Was just saying if it was ever needed but prob will just get the 1.3
Old Aug 3, 2009 | 11:28 AM
  #94
ClixT's Avatar
Originally Posted by 02-Lancer-Es
Whats the diff between these 2?
All i need is the 1.3 right ? Would the 2.o make any difference ?
Thanks alot guys!
http://cgi.ebay.com/ebaymotors/OpenP...=p4506.c0.m245
http://cgi.ebay.com/ebaymotors/Tactr...=p4506.c0.m245
dude thnx for the link of the 1.3!! i owe you
Old Aug 3, 2009 | 01:43 PM
  #95
senate6268's Avatar
MAF swap writeup here:
https://www.evolutionm.net/forums/la...tep-guide.html
Old Aug 3, 2009 | 01:48 PM
  #96
So now im left wondering what is Evoscan for ? lol
Old Aug 3, 2009 | 02:10 PM
  #97
senate6268's Avatar
EvoScan is a great tool to have in your tuning arsenal for datalogging Mitsu's:
http://www.limitless.co.nz/evoscan
You can also set alarms, setup gauges to display logged values in realtime and many other features. I strongly recommend it to any Lancer tuning with EcuFlash and using an OpenPort cable.
Old Aug 4, 2009 | 12:18 AM
  #98
ClixT's Avatar
also this
Old Aug 4, 2009 | 11:33 AM
  #99
ThunderOZ's Avatar
Yea you just have to figure out how to use EvoScan lol
Old Aug 5, 2009 | 09:56 PM
  #100
JRR's Avatar
JRR
as an update...
im tryin as hard as i can to get those injedtors in with my piggy messing horendously with my afr's!
as of now im thinkin of puttin back in my stock 605 and re-reflashing my ecu back to stock.
man i need more time in a day to do this sorta stuff, or my own garage! dang apartment life!
Old Aug 6, 2009 | 09:03 AM
  #101
ClixT's Avatar
Originally Posted by JRR
as an update...
i heard you with the apartment life..
Old Aug 13, 2009 | 06:58 PM
  #102
JRR's Avatar
JRR
got the latencies all figured out nd she idles like a charm and bost levels are in check. did a log thatll be posted up.
any reason why the whp in the log doesnt actually give me a reading?
this log is going arund the block with the eclipse 501 maf and 440's.
here is a log of my 501 maf and 440's
Old Aug 14, 2009 | 05:27 PM
  #103
darkmitsu's Avatar
mine is still running great with the 501, my butt dyno says the power difference seems equivilant to putting in a cone filter upgrade...
Old Aug 14, 2009 | 05:58 PM
  #104
The only issue Im having, which will be fixed when I tune as Im running stock maps, is its super rich when you step on the gas. Like below 10.0 afr. So I just need to get a laptop with a good battery and do some datalogging.
Old Aug 14, 2009 | 06:59 PM
  #105
senate6268's Avatar
Since you're not turbo, I would recommend lowering the MAF scaling values to something that is between those of the Lancer and those of the Eclipse 4G64.
