The Ultimate Milage and Gas Milage Thread!
Old Apr 18, 2006 | 01:32 PM
  #316
. M i c h a e l's Avatar
Originally Posted by blackmantis
does she drive on the streets mor than th highway? because if that is the case there is not much that can be done (new plugs) may be a good idea though!...
Yeah, more street. I already did new plugs.
Originally Posted by camaro379ss
270 miles to the tank is good..There aint nothin wrong and revs up to 4k rpm are gonna burn gas too.
There are alot of people who would kill to get 270 miles to the tank on here.
So 27mpg nothin wrong dont worry.
check these links:
https://www.evolutionm.net/forums/sh...hlight=gas+mpg
https://www.evolutionm.net/forums/sh...ht=gas+mileage
also keep in mind that the numbers on a window sticker like for our cars are like 28/35, these are estimates by the EPA, so many variables change it...for instace, mods, age of car, mileage on car, tire pressure, octane of fuel, have a dragging brake pad, upkeep...etc.
I'm aware that higher revs burn gas..I said the highest it sees is that..and thats if she's flooring it...of which she rarely does.
I believe I calculated wrong her mileage per tank is closer to 240
She has no mods..the car is three years old, tire pressure is fine. Always 87 octane..havent checked pads. Upkeep..heh, well thats why i'm here.
Originally Posted by 1speednevo
ck tire presseures...that has alot to do with it!!
I've done that already. They were all okay.
Old Apr 18, 2006 | 01:39 PM
  #317
Ozdriver's Avatar
I get 29 mpg consistantly.... well at least in the warmer weather (don't have to let the car run in to warm up
Old Apr 18, 2006 | 02:33 PM
  #318
jchangsta2six's Avatar
wow lets trade cars ... im lucky if i can get 200 to a tank ...
Old Apr 18, 2006 | 02:36 PM
  #319
HUTCH1991's Avatar
I get 300 to a tank on my Evo.....Fully modded
Old Apr 18, 2006 | 04:05 PM
  #320
cableguy5752's Avatar
i think you and me are in the same boat. mines an '03 OZ manual. 3 years old, just clicked over to 60,000 miles yesterday and i get 22-24 mpg and about 240 miles per tank. but i'm thrilled with that. i've never had a car that got more than 16 mpg. also i have NO mods.
Old Apr 18, 2006 | 04:10 PM
  #321
drucea's Avatar
i wouldnt measure the gallons to the tank, because you dont really empty the tank each time. Just fill the tank till the pump clicks off, then reset your trip meter, then after 3/4 tank is gone, fill back up and divide the miles you traveled by how many gallons it took to fill up the tank. And a lot of things say that at least an intake and exhaust/muffler improve gas mileage by letting the engine breath better. You can find some cheap intakes that do the job. All you really need is a MAF sensor adaptor and filter, then make your own bracket to hold it up
Old Apr 18, 2006 | 06:01 PM
  #322
oz4g94's Avatar
i get around 240 to 3/4 of a tank, probably around 280-300 to a full tank. all of my driving is suburban streets, no highway. the best thing i would suggest to you is to put donuts on all 4 hubs and that should give her some pretty good gas mileage.
Old Apr 18, 2006 | 06:14 PM
  #323
mitsuman6's Avatar
i have the same problem as you do michael. My 02 auto has about 45000 miles on it and used to get about 300 driving to almost E. Now at almost E I'm getting about 250 max. It's been like this for a while now so I guess i'm just going to have to live with it
Old Apr 18, 2006 | 06:37 PM
  #324
try throwing in some fuel treatment stuff ... run some **sea foam**
Old Apr 18, 2006 | 07:09 PM
  #325
I ran fuel injector cleaner already...I might do seafoam..but I just changed her plugs so we'll see.
Old Apr 18, 2006 | 07:14 PM
  #326
travelsize420's Avatar
270 miles to a tank is more like 20~21 mpg... which sucks!
I just had my timing belt and plugs changed at 60,000 miles and my mileage went from 23~25ish to 32~ish city miles.
Old Apr 18, 2006 | 10:27 PM
  #327
drucea's Avatar
I was at about 299 miles at 3/4 tank driving mostly highway with the A/C on and windows closed
Old Apr 18, 2006 | 11:14 PM
  #328
arm07's Avatar
Those are awesome numbers. I get 360 kilometres which is about 220 miles on my auto oz.
I think its an auto thing.
I asked this in the other mileage thread but no one answered. Is it normal to have the black soot all over the chrome tip at the end of your exhaust? My friends civic's exhaust looks squeeky clean. Am I running too rich or do lancers in general run rich?
Old Apr 18, 2006 | 11:19 PM
  #329
Foxphyre's Avatar
Hmm I consistantly see at least 300 a tank and my '02 has close to 80k on the odo. not sure how the previous owner treated it with scheduled mtc, but there are no mods on mine. My previous car was a Nissan Sentra and it got to the point where i was getting like 12mpg highway driving only. i changed the plugs, changed the distributor, changed from a fram air filter to a K&N, changed the fuel filter. i did some other things and my gas mileage went back to normal, but shortly after that my EGR valve went nuts and i developed a vacuum leak. I cant say exactly which it was or what combination of changes brought my mileage back up since i did them all at once, but its a start.
Old Apr 19, 2006 | 04:50 AM
  #330
camaro379ss's Avatar
And u have a manual so ur obviously gonna get better gas mileage. Like previously stated its an auto thing so u wouldnt kno.
even at 24mpg u shouldnt worry. My car i really tend to get 23mpg and my roommate gets 21mpg in his auto lancer.
take a look at this tread. https://www.evolutionm.net/forums/sh...d.php?t=139124
Scroll half way down and look at the pic of the window sticker that i posted.
EPA says our cars get WITHIN THE AREA OF 24/31. Which means it can be slightly higher or slightly lower.
