The Ultimate Milage and Gas Milage Thread!
Old Jul 3, 2006 | 12:33 PM
  #436
rallioveru's Avatar
http://www.co.suffolk.ny.us/webtemp3.cfm?dept=3&id=2049
Yet another one. ok i'll be nice
Old Jul 3, 2006 | 01:12 PM
  #437
drucea's Avatar
ok, well after thinking about this for myself a while back, I decided to test it. I was getting an average of 26-27 mpg on 87 octane. Then I filled up on 91 octane a few times and tested the mileage, on average, doing the same type of driving as before, school, work etc, I got 29-31 mpg. Therefore proving that the higher octane gas in my vehicle in my area provides a tad bit better mileage. I also drove a little harder on the higher octane, which would hurts the mileage. So from my personal experience, I'd have to argue with you on that.
Old Jul 3, 2006 | 01:15 PM
  #438
drucea's Avatar
Originally Posted by airlinevomitbag
Ummmm once again you don't entirely know what you are yapping about. High octane gas locally (since you cited a MN doc) is non-oxygenated gas in about 75% of the stations outside of the twin cities. Non-oxygenated gas has been proven to produce better mileage and is probably a good reason for why people automatically think the higher octane gas = better mileage, when it is not always the case.
Originally Posted by rallioveru
Yea, umm, its time for you to shut up. i don't care.
Hmmm yeah, when you're proven wrong and respond like that, i'd say thats about time to call it quits. It's also getting a bit off topic, soooo, yeah hows about everyone shut up about gas mileage unless it relates to putting ****ty walmart fuel into your car and getting better mileage.
Old Jul 3, 2006 | 02:07 PM
  #439
72charger's Avatar
LOL! Well, all I have left to say is I have taken a couple years of Automotive class both in high school and college classes, and I have also worked at Wal-Mart changing oil for about 8 months. If anybody that has looked at this thread knows what they are talking about it is I. In my "experienced" opinion, you should dump that oil out and go back to Mobil 1, it makes all the difference whether you believe what these people say or not. And like someone on here stated earlier, you may even get more milage back switching to Mobil 1. If you are waiting 6,000 miles to change your oil then you are definitely going to have a mileage increase every time you change. Mobil 1 is rated to last longer but that doesn't mean it will be just as good at 5,000 miles as it is fresh off of the shelf by any means!
As far as the filter goes, there is no value at all to purchasing a more expensive oil filter. No filter, works any better or worse than the other, neither can they make the engine run more or less efficiently. It is important for you to know, however, that most oil filters need to be changed at NO more than 3,000 miles which is why I don't put more than 3-4k miles on my oil before I change it. Again that is "experienced" knowledge. Whether any of you agree with it or not doesn't make a hill of beans difference to anything. Facts are facts.
Old Jul 4, 2006 | 01:17 AM
  #440
rallioveru's Avatar
I've done the same and i honestly got the same mpg as before. I don't know, maybe its something else?
Old Jul 4, 2006 | 01:19 AM
  #441
rallioveru's Avatar
Wait i thought it was about ****ty oil.
Old Jul 4, 2006 | 01:20 AM
  #442
rallioveru's Avatar
Ok I am a MPG ****. I measure it on every vehicle I own every tank of gas. My life is not much different than that of Bill Murray in Ground Hog Day. I do the same things every day. I drive the same stretch of highway to work at the same time and the same speed. I get gas from the same connoco station everytime. I get a solid 30-31 mpg.
I broke the mold 2 weeks ago. I needed an oil change and I had a ton of this 10W30 "Resolute" brand oil from a car I sent to goodwill. It's about $.97 a quart. I figured I need to use it so I poured it in the car. Previously its been Mobil 1 5w30 since the beginning.
And my first tank of gas I get a solid 33 mpg. On the cheapest, wrong weight oil you can find.
Dino oil = +2mpg?
Someone else try it out. 2 mpg is significant these days.
Am i wrong?
Old Jul 4, 2006 | 06:50 AM
  #443
airlinevomitbag's Avatar
For the last time buddy, higher octane gas is often non-oxygenated, there will be a sticker on the pump if you look for it. (Its supposed to be for off road or antique vehicles) Non-oxygenated gas will get better mileage every single time versus oxygenated. I Get 15-20 miles extra out of it on my bike and thats only 4 gallons of gas you can more than double that on a car.
Old Jul 4, 2006 | 07:03 AM
  #444
I have stated multiple times I am going back to Mobil 1 when this is all gone.
I check it every single tank of gas. In the last 6 thousand miles I have had a Mobil 1 change, no difference, and new plugs no difference. Only thing that made a difference was the cheap oil.
Not entirely true, plenty of reseach online about this. Purolator Pure 1 is the best filter you can get. Fram is the absolute worst. WalMart(Bosch/Champion) is the best value/for performance by far.
No. Manufacturers say 3k for severe service schedules, oil and filter. That means using the car as a cab or police car or something similar. Or its severe weather, like up here in the winter when its -20 or out in the desert in a sandy/dusty environment.
Old Jul 4, 2006 | 07:17 AM
  #445
evo8kiko05's Avatar
Originally Posted by FlLancer
Oh wtf... I get 240 miles per tank before the light comes on.
That's about how much i get, but If I drive it like a granny then I can get about 260ish. and thats with walbro 255, 3inch tbe, k&n dropin' and MBC set at 19.
Old Jul 4, 2006 | 07:46 AM
  #446
rallioveru's Avatar
[QUOTE=airlinevomitbag]For the last time buddy, higher octane gas is often non-oxygenated, ....
How often? Thats pretty vague and it didn't prove anything.
Old Jul 4, 2006 | 10:56 AM
  #447
drucea's Avatar
hes trying to prove that higher octane fuel will give better gas mileage, his arguement being that it is usually non-oxygenated. And when I said unless its about using ****ty fuel, I ment oil, I got mixed up cause thats what everyone was talking about.
Old Jul 4, 2006 | 11:07 AM
  #448
[QUOTE=rallioveru]
Check the pumps. Unless you live downtown or in an urban area you probably will not see oxygenated premium and therefore will get getting better mileage.
You can not say premium gas does not give better mileage when there are two kinds of premium, one of which will give better mileage.
I love this thread. I enjoy arguing about meaningless nonsense.
BTW my e-***** is this big: 8==========D
Old Jul 4, 2006 | 11:30 AM
  #449
rallioveru's Avatar
Ok but i didn't say anything about it being oxygenated. I was just talking about premium gas in general which from my experience i have not had any better mpg. Okay i think were both right in our own way.
Old Jul 4, 2006 | 01:11 PM
  #450
72charger's Avatar
What I love is being corrected by someone who doesn't have a foggy clue about what they are talking about. The objective of the oil filter is to clean any particles of metal or carbon build up out of the oil. HOW IN THE CRAP DO YOU THINK ONE FILTER DOES THAT BETTER THAN ANOTHER??? Sure maybe one has a little better design to it, but either way it doesn't affect performance in the least! As long as you don't have metal and clumps of carbon in your oil you have nothing to worry about and there is certainly no gain to be had in using any other filter.
Lastly, just because someone or some company states something online or on their product doesn't make it true. Wanna argue about that?
