Dash Lights don't work
My check engine lights and lights like that work. But the back lights don't. I did have a short some were on my passanger tail light and just ended up splicing a new wire into the fuse box but i don't think it would be hooked up to my dash lights?
FWIW I'm having the same problem and the only thing that affects the instrument cluster lights is to unplug the dimmer switch. Spinning the wheel doesn't do anything. I think I saw a quick burst of light from the cluster before everything went really dim (so if you regular folks turn your dimmers all the way down, you'll see what I mean). Maybe they go bad? I can't figure out how to get mine apart without destroying it. I'll post back if I find anything.
TrogdorWBL
65
May 3, 2016 02:38 PM
poorevo4
May 12, 2015 04:38 AM
