Focus RS
Old Mar 26, 2015 | 09:22 PM
  #406
GaBe511's Avatar
I do love this car. Just feel like its harder to pass this as an adult car being a hatchback lol.
Old Mar 27, 2015 | 06:26 AM
  #407
OX's Avatar
OX
Originally Posted by warmmilk
looking at the vid at the bottom of this page (http://www.autoblog.com/2015/03/25/f...-york/#image-1), caliper to wheel barrel clearance looks pretty low... certain 18" wheels with bigger barrel diameter may fit over the stock brakes... if 18's do fit, I think it'll look pretty awesome with some wide tires with a meaty sidewall on it... personally I've never been a fan of the rubberband tire look
Yeah, anyone who thinks 18" rotors fit with 19" wheels has never used a tire machine and/or has not dealt with the average cast iron brake caliper. Even the performance calipers, it's hard to find one that has less than 1/2 true height over the rotor edge.
Here is a typical caliper like brembos
Rotor size is 14.9 ", outside of caliper is at 16.6 dia. So you are up to 17's with .2 " clearance and have not accounted for rim neckdown to get bead of tire over rim on tire machine. Add another 1" dia easy for that, and you are at 18's for a 15" rotor.
And add more to that for many cars with bigger brakes that are just average drivers and use cast calipers (not using brembos, etc...) that stick up even higher over rotor edge.
Old Mar 27, 2015 | 09:30 AM
  #408
WarmMilk's Avatar
is the Focus RS rotor size 14.9" or the example drawings that you're using?
If its the Focus RS size... I'm digging the overkill in the braking department..
Old Mar 27, 2015 | 09:32 AM
  #409
WarmMilk's Avatar
unless you have a job that you have to regularly drive clients around, who cares? just get the car you want and screw what other people think...
and if you do have a job that you have to drive clients around, get a used Lexus for 10k and then get your fun car.
Old Mar 27, 2015 | 09:53 AM
  #410
kaj's Avatar
kaj
for me, personally, this has never, ever, ever been an issue. otherwise i probably wouldn't drive an import. especially one with a big 'ol wing on the back LOL.
Old Mar 27, 2015 | 09:56 AM
  #411
Noize's Avatar
EvoM Administrator
An Evo with it's monster wing isn't an adult car by any stretch either. I'm old. I drive what I like and don't care in the least what other people think about my car.
Old Mar 27, 2015 | 10:11 AM
  #412
kaj's Avatar
kaj
i'd say it's our mid-life crisis.... but if that were true, we'd be driving Corvettes.
Old Mar 27, 2015 | 10:15 AM
  #413
Kreeker's Avatar
Seeing this picture:
I think the looks could grow on me. If it was a little longer I think it would be perfect for me. It seems too smooshed.
Old Mar 27, 2015 | 10:18 AM
  #414
OX's Avatar
OX
Have no idea, was just responding to the statement that only cars with 18" brakes should have 19" wheels. If 15" brakes need 18" wheels or more, 18" brakes would need 21's.
That's not to say I don't agree that many cars look stupid with 20's and 80/90's size brakes (or tiny drums are even worse)
Old Mar 27, 2015 | 11:38 AM
  #415
rongdoer's Avatar
I read the brakes had to be big because it uses the brakes (ebfd) in place of any lsd, and with the constant use they'd fade pretty fast.
Old Mar 27, 2015 | 01:27 PM
  #416
WarmMilk's Avatar
ugh... thats the worst news I've heard about the car yet... I hope its fully defeatable like on the mustangs
Old Mar 27, 2015 | 02:55 PM
  #417
nemsin's Avatar
Link to source? If not, its just rumor.
Old Mar 27, 2015 | 03:07 PM
  #418
kaj's Avatar
kaj
"The system is calibrated together with Ford’s Electronic Stability Control and brake-based torque-vectoring functions to work as a package deal."
per Autoweek
http://autoweek.com/article/new-york...ve-spring-2016
Old Mar 27, 2015 | 03:30 PM
  #419
nemsin's Avatar
Originally Posted by kaj
"The system is calibrated together with Ford’s Electronic Stability Control and brake-based torque-vectoring functions to work as a package deal." per Autoweek[/url]
That could definitely be bad news for pad/rotor life at the track.
Old Mar 27, 2015 | 03:47 PM
  #420
kaj's Avatar
kaj
i'd HOPE we could disable it. on the bright side, it should only come into play if you get into trouble which shouldn't be that often. hypothetically speaking, anyway.
