Mk V Supra - My Evo's Replacement?
Old Dec 29, 2022 | 07:01 PM
  #2356
Lumpy Sticks's Avatar
5 Year Member
I have only seen a few of these b58s fail. Most were just because they were making too much power on a stock engine. Like 800whp. Don't think I have heard of a trans or rear end failure. Axles break but again, high hp drag cars. Couple bent front arms from hitting rumble strips. Overall, so far at least, these things seem to be reliable and track worthy out of the box.
Old Dec 29, 2022 | 07:12 PM
  #2357
5 Year Member
Originally Posted by RazorLab
I already bottom out on the speed bumps in my mother in laws neighborhood and with the splitter, forget about it...
just wait until that splitter goes on. It's quite impressive with how easy it scrapes. The bottom of mine is destroyed already. Doesn't help I can't make it in or out of my neighborhood with both the splitter and diffuser scraping twice each way.
Old Dec 29, 2022 | 09:01 PM
  #2358
5 Year Member
Side skirt mock up ground clearance....
Old Dec 29, 2022 | 10:39 PM
  #2359
kaj's Avatar
kaj
So..... Maybe I won't be doing aero, after all. I like to take the Toyota out around town, occasionally. Sounds like that would be miserable.
I would definitely be copying the splitter using plywood x 10.
Old Dec 30, 2022 | 07:19 PM
  #2360
RazorLab's Avatar
Also why I didn't do the side skirts. I wouldn't even be able to get my quick jacks under the car unless I double the amount of wood I *already* drive up on.
That said... adding aero to my Supra week continues...
Old Dec 30, 2022 | 07:57 PM
  #2361
5 Year Member
I have already come to the conclusion that having to drive up on wood is normal for these cars. My 3/4" pieces are now going to get swapped for 1-1/2" pieces. I still need to get some canards one of these days. Honestly, the only reason I went with the skirts and spats was for looks. Just didn't look right without them.
Old Jan 7, 2023 | 01:09 PM
  #2362
RazorLab's Avatar
@LetsGetThisDone Starting the splitter install today. Man, you where not kidding, this SUCKS. The template is wayyyy off. I cut the rectangles out and they are like off by like .75" front/back
I'm just hoping the template is right side to side before I drill the mounting holes in the bumper bar.
Old Jan 7, 2023 | 03:28 PM
  #2363
kaj's Avatar
kaj
This is not encouraging..
Old Jan 8, 2023 | 01:33 PM
  #2364
RazorLab's Avatar
Glad this splitter install is done. What a pain in the ***. Need to source two longer bolts for the rear sides since they supplied ones aren't long enough.
Aero is now all installed!
Old Jan 8, 2023 | 04:31 PM
  #2365
Bee-Raddd's Avatar
inb4 this place is named www.SupraM.com lol
Old Jan 8, 2023 | 05:01 PM
  #2366
kaj's Avatar
kaj
We can't help that we're part of a growing community as well as a dying one
Old Jan 9, 2023 | 10:10 AM
  #2367
5 Year Member
Sure you are tagging the right person? Haha back a couple pages ago....
Have fun cutting and drilling holes in the car! The wings template is nearly spot on. The splitters template, not so much. It worked fine side to side but I had to cut out like an extra inch in the bumper slots to get the brackets in the correct spot. Overall, both are pretty straight forward installs.
Old Jan 9, 2023 | 10:26 AM
  #2368
RazorLab's Avatar
Oops, yes, meant to tag you. lol
Old Jan 9, 2023 | 10:33 AM
  #2369
5 Year Member
I mean we both have the same name but he spells his the wrong way
Glad you got it on. It was by no means a fun task. Have you taken it around the block yet to see how bad it scrapes or is your car in winter hibernation?
Old Jan 9, 2023 | 10:59 AM
  #2370
RazorLab's Avatar
I haven't, car is up on my quickjacks. I'm about to pull the suspension out to send to MCS to get repaired.
I also realized I don't have the splitter aligned 100% as the drivers side rear is back about .25". So I need to loosen everything up again and realign.
