Safe to shift from 2nd to 1st at rolling speed?
Old Oct 10, 2010, 08:39 AM
m3bmw99's Avatar
How do you guys drive your MR? Sometime I slow down to 10 to 20 km, 2nd gear below 2000rpm, it is too weak to pick up speed at that rpm! Is it safe for sst to shfit to 1st while the car rolling?
Old Oct 10, 2010, 08:40 AM
2LOFD3ATH's Avatar
Just heel toe it or the good ol' double clutch.
Old Oct 10, 2010, 08:59 AM
Captainslacker's Avatar
Here's my thoughts having driven mine for almost a year.
If you're driving normally and plan on accelerating and don't want the jerking, just stay in second. The gearing is well enough for getting going for daily driving. If you're rolling to a stop, just stay in second and let the TCU do the downshifting. If you downshift any earlier it tends to jerk and stutter. I think a lot of it has to do with the built in engine braking in sport mode. If you stay near 3k RPM's you won't get the jerking.
Now if you were trying to get on it, don't just drop to first and be ginger with the throttle. If you're going to downshift to first you need to stay on the gas and recognize it's going to hammer the RPM's quickly so make sure you get out of first before hitting the fuel cut.
Viola, no more jerking. Recognize the car and transmission are tuned to go, and to stop. Hence why the rolling stops are kind of finicky. If you let the car do the stopping, and go when you want to go it should be smooth as silk.
Old Oct 10, 2010, 09:40 AM
2LOFD3ATH's Avatar
My bad, didn't notice it was an X since there are almost no X's on this forum.
Old Oct 10, 2010, 08:16 PM
Crester's Avatar
Why wouldn't you be able to shift into 1st while moving??? I've done it before. As long as you're not putting some major shock on the transmission... I don't know why it would be a problem.
Old Oct 13, 2010, 04:12 PM
EvoXMikeMR's Avatar
I down shift in mine at lower speeds all the time it does not seem to be much of a problem to me. As long as the trans is not shuttering shod be ok, mine always is.
Old Oct 17, 2010, 08:34 PM
m3bmw99's Avatar
I can down shift to 1st at low speed , just want to make sure the sst is desgn to to this, but sometimes get loud clicking sounds!
Old Oct 23, 2010, 03:13 PM
N118GT's Avatar
the sst will rev match the shift to first...hell in sport mode it will grab first when it gets much below about 10 mph...whats the problem again?
hearnoevo
Dec 11, 2014 09:42 AM
crimes
Jun 7, 2011 11:25 AM
aycynokia
May 10, 2011 05:33 AM
evo_skillz
Dec 30, 2006 06:09 AM
Luke WL.
22
Jan 26, 2006 08:49 AM
Quick Reply: Safe to shift from 2nd to 1st at rolling speed?
