Time Attack Advice
Old Oct 2, 2021 | 05:33 PM
  #211
Jaraxle's Avatar
I use NAPA rubberized undercoat. It dries to a NOT sticky finish with some give to it... Like the coating on the right side in your picture.
Old Oct 2, 2021 | 10:34 PM
  #212
ViciousLSD's Avatar
Do RS's have that black undercoating? I hate this crap. The dirt is always oily and I've had it going to my eyes, hair, shirt, etc lol while working under the car. I'm done with the fronts, the rears are probably 4x the work but it'll be worth it
Old Oct 3, 2021 | 11:39 AM
  #213
kaj's Avatar
kaj
fuuuu*****¢¢¢¢kkk I've had that crap in my eyes more times than I can count.
Old Oct 4, 2021 | 08:35 AM
  #214
ViciousLSD's Avatar
just brushing on some flat white enamel. The original paint on the underside is so thin so I might apply enamel all over when its time to replace the fender liners. the rears will be 100% covered since it has that cream glue material all over. I'll do the same under the seats after a good power wash
Old Oct 4, 2021 | 08:52 AM
  #215
Ayoustin's Avatar
Man you're making me think of stripping my wheel wells too while my car is apart.
I'm hoping to get the chassis acid dipped in a couple years. Would be nice to start from a blank slate.
Old Oct 4, 2021 | 09:13 AM
  #216
ViciousLSD's Avatar
WD40, spray, stir with bristle brush & wipe. Purple degreaser and my tire sprayer for the final wash
testing enamel
I also painted axles and brake shields too lol
Old Oct 4, 2021 | 10:57 AM
  #217
ViciousLSD's Avatar
custom parts look nicer when theres no goopyshiet distraction
wouldnt that acid negatively impact the glue keeping the car together?
Old Oct 4, 2021 | 12:57 PM
  #218
Ayoustin's Avatar
No, the substance you're referring to is seam sealer and that's really all it does, seal seams. It's there to keep water from flowing between sheet metal in the chassis. On older cars like ours just about the entire chassis is held together with resistance spot welds, it's still the most used form of sheet metal bonding in production cars today. Glues and adhesives really only come into play when you're bonding dissimilar materials like steel to composites or aluminum, which in that case you would want to remove those parts before acid dipping anyway.
It's kind of a multifaceted solution for a few things. Gives me a chance to seam weld the chassis, change some parts of the cage, eliminate any rust forming on the underside of the car, and give it all new paint and undercoating.
Old Oct 4, 2021 | 02:17 PM
  #219
ViciousLSD's Avatar
I thought this adhesive is what makes the chassis so stiff Thanks for the info
Old Oct 4, 2021 | 09:42 PM
  #220
ViciousLSD's Avatar
Grossness
Kaboom
On to the other side
Old Oct 4, 2021 | 10:55 PM
  #221
Ayoustin's Avatar
I'm sure white will be fun to keep clean hahaha. Looking good though!
Old Oct 5, 2021 | 10:26 AM
  #222
Balrok's Avatar
Hmm, I got a truck I may need to do that on (not white lol), what epoxy did you use?
Old Oct 5, 2021 | 11:10 AM
  #223
ViciousLSD's Avatar
Soapy water and a paint brush. I'm always under the wheel well anyway lol
this is just the basic Home Depot Rustoleum flat white enamel paint. I still have to see how it holds, especially during winter. I'll just power wash it off it cracks or peels.
if you want a good undercoating, look into the CRC Corrosion Inhibitor, its clear-waxy, not black-rubbery. Has great reviews on youtube and even works on electric connections. I'm after a clean wheel well that wont collect brake dust and sand & shiet.
I've had experience with epoxy on the garage floor... never again!!
Old Oct 7, 2021 | 02:02 PM
  #224
ViciousLSD's Avatar
Just learned this thing existed. I dreaded revisiting my RSB due to that stupid OE bracket
KBR22-24
Old Oct 8, 2021 | 09:00 PM
  #225
ViciousLSD's Avatar
finally got these today, but my 5" swift springs are stuck in some container somewhere. QQ: I should be going for the longest configuration for the rears right? anyone know how much (minimum) thread should be in that green canister? its just barely peaking thru that hole as pictured and it's a tad shorter that my KW v3
