Time Attack Advice
Old Oct 20, 2021 | 03:04 PM
  #301
ViciousLSD's Avatar
Is this a "You can take Evo out of rally, but you can't take rally out of Evo" kind of quirk?
those have the most suspension travel, since it digs and jumps I may have seen a rear lift on a hairpin - corkscrew
Old Oct 20, 2021 | 03:11 PM
  #302
Dallas J's Avatar
Veteran: Army
Its a function of 60% weight being on front axle, high front CG and low RC, and underworked rear tires. You cant make the inside rear tire do work without ruining front mechanical grip.
So, lifting a rear tire is inevitable. You don't really want huge lift, but more rear spring less rear bar will balance that. Remember, once you lift a tire the rear bar is effectively done contributing and will just lift the tire higher.
This is not relevant to high aero cars though where a flat front splitter is more important than everything else.
Old Oct 20, 2021 | 03:12 PM
  #303
Dallas J's Avatar
Veteran: Army
I'm sure they can get 60% front weight the way theyre driving
Weight and Load are not the same thing.
Old Oct 20, 2021 | 03:28 PM
  #304
ViciousLSD's Avatar
We can at least agree that its a *problem*, not a feature. If we had the backing of a whole engineering team then it can dialed out, but we dont. FWD cornering it is
Old Oct 20, 2021 | 03:41 PM
  #305
Dallas J's Avatar
Veteran: Army
I wont agree its a problem. It is what it is.
But I will agree its a FWD thing. Yes, the Evo should be treated like a FWD from entry to apex.
Old Oct 20, 2021 | 03:46 PM
  #306
ViciousLSD's Avatar
OK.
I do like it when my car turns like a pro, not understeering (rest of the way) lol
Old Oct 20, 2021 | 04:47 PM
  #307
kyoo's Avatar
this is why im trying to move as much weight to the rear as possible
this is where my front and rears are, been thinking of raising the front a little. i dont know if the uprights impact any of that, but i think i'm looking to get the street ride height one
Old Oct 20, 2021 | 05:21 PM
  #308
Construct's Avatar
Originally Posted by Dallas J
MCS is an example of a shock that actually has too little travel. Its not droop, its travel.
Can you expand on that? I had my eyes on MCS if I ever upgrade shocks. Didn't realize they had low travel on our platform.
Old Oct 20, 2021 | 05:24 PM
  #309
Dallas J's Avatar
Veteran: Army
You can definitely lower the rear, 0.5-0.75" lower than the front.
Old Oct 20, 2021 | 05:26 PM
  #310
Dallas J's Avatar
Veteran: Army
I've seen on several Evos and Porsches the MCS's came with so little travel the wheel couldnt get much further than 1" or less of a tire-fender gap. Not the best measurement system, but they've been short enough times its a "thing" when MCS is discussed.
Old Oct 20, 2021 | 05:33 PM
  #311
kyoo's Avatar
so it's more about the differentials, rather than net height? for RC i guess that makes sense
Old Oct 20, 2021 | 06:15 PM
  #312
Dallas J's Avatar
Veteran: Army
It comes down to the change in roll axis with it steeply angled forward when over lowering the front. Lowering the rear more helps at least get it somewhere more flat-ish. This is cause the RC moves at much different rates front and rear. Roughly 3:1 front and 1:1 rear. Lower both ends 1" and the front drops 3" and the rear drops just as much as the CG. So lowering the rear also has almost no effect on rear roll couple.
The thing to worry about in the rear is the camber curve ramp rate. It gets steeper and steeper which leads to unpredictability once you start sliding.
Old Oct 20, 2021 | 06:54 PM
  #313
kaj's Avatar
kaj
that rear is high. I dropped mine to a 13mm rake and the car instantly felt better.
Actually, I lowered the car as much as I could without the control arms being in a bad way. Then I adjusted to the 13mm.
Old Oct 20, 2021 | 07:02 PM
  #314
kyoo's Avatar
thanks guys. i will probably do some kind of combo of dropping the rear and raising the front. i don't know if it's immediately apparent but i take it my level warrants the 1.25" correction length, not the 2" correction length?
Old Oct 20, 2021 | 08:11 PM
  #315
ViciousLSD's Avatar
Maybe it's just me but I made sure my stock control arm bushings we're un-flexed after making big ride height changes. I'm not normally this **** lol
