Time Attack Advice
Old Nov 1, 2021 | 04:48 PM
  #346
codgi's Avatar
My TC is in, it took all weekend, Questions:
1) do all the subframe bolt holes need to be centered? the small bolt hole wasn't centered before so a bolt thread was squished. It came in the same way and I'm not sure if I can change that
2) new ring & pinion, is 1000mi break in required? Is ~200mi ok I wont be doing any hard launches
3) Is this the Koyo radiator people are getting for their IX? Any better options, mainly trying replace the OE rad before it breaks on me
https://www.maperformance.com/produc...-koyo-hh031610
Thanks!
Did the Evo VI one because it moves the hose from over the exhaust manifold: https://www.maperformance.com/produc...-koyo-hh030939. Need an Evo VI upper radiator hose to get it to work. May also need a slimmer after market fan due to the radiator being thicker than stock.
Old Nov 1, 2021 | 06:15 PM
  #347
kyoo's Avatar
Thanks!
i did the sheepey csf, for the same reason - replace before fail.
https://qlmotorsport.com/2020/10/17/...-spal-fan-evo/
https://sheepeyrace.com/products/she...ishi-evo-7-8-9
Old Nov 1, 2021 | 07:59 PM
  #348
Spooled_IX's Avatar
Is oil starvation a serious issue on a stock evo 8/9 on track? Should I overfill the engine a bit?
Old Nov 1, 2021 | 08:08 PM
  #349
kyoo's Avatar
yes, and no you should just get an oversized baffled pan.
Old Nov 1, 2021 | 08:24 PM
  #350
kaj's Avatar
kaj
If you are running a 100tw tire, or better, I'd say yes.
Old Nov 1, 2021 | 09:52 PM
  #351
ViciousLSD's Avatar
Interesting. Is the picture on that link correct? Do you have the 53mm one? Which fan did you get?
Old Nov 1, 2021 | 10:12 PM
  #352
ViciousLSD's Avatar
Tough choice on the radiators. They're all fugly with those welds Any ones that dont look like children welded them?
Old Nov 1, 2021 | 10:21 PM
  #353
Ayoustin's Avatar
Yea
https://stmtuned.com/products/stm-ev...-slim-radiator
Old Nov 1, 2021 | 11:23 PM
  #354
ViciousLSD's Avatar
Originally Posted by ayoustin
Well OK. With kiddie-welds then
Old Nov 2, 2021 | 07:54 AM
  #355
kyoo's Avatar
you didnt like how the sheepey/csf looked?
Old Nov 2, 2021 | 09:21 AM
  #356
ViciousLSD's Avatar
The shroud is kinda half as sed and it's permanent. not sure how to adjust the fan mounting if i ever needed to
  #357
Ayoustin's Avatar
Everything sub $600 is made overseas. Manufacturers don't care what the welds look like so long as they don't leak.
Old Nov 2, 2021 | 09:43 AM
  #358
ViciousLSD's Avatar
I'm also on stock airbox. I will need to convert to cone filter before I can consider anything that relocates the hose. I really hate that swooshing sound from the bov
Old Nov 2, 2021 | 10:02 AM
  #359
ViciousLSD's Avatar
which baffled pan? AMS ones?
Old Nov 2, 2021 | 10:35 AM
  #360
Bee-Raddd's Avatar
Yes it is especially on long right hand turns, overfilling can help slightly but youll probably push most of it back out. issue is the oil gets stuck in the head and cannot get back to the pan, the pickup for the oil pump is on the right side of the engine so once the oil gets sucked up and stuck in the head combined with g force pulling the remaining oil away from the pan you just run out of oil to pump. overfilling can help but generally the engine will push the extra oil out.
oversized pan definitely helps, racefab do a nice one. but the only real fix in the long run is drysump. Depends on the characteristics of the circuits your driving on
