2.3L GT3076Build
Old Dec 16, 2008 | 12:14 PM
  #361
EVO8emUp's Avatar
Yeah, the guys in the ECUflash forum are amazing!
Old Dec 16, 2008 | 04:52 PM
  #362
wshihdnevo's Avatar
Originally Posted by jid2
Yeah, I guess I won't really know until I start working on it, but it's just awesome the stuff that's becoming reality with the stock ECU.
Word to your *****, son! Now go DO WORK and get that leak fixed
Old Dec 16, 2008 | 06:39 PM
  #363
justboosted02's Avatar
Old Dec 17, 2008 | 12:15 AM
  #364
SickSilverNLow's Avatar
^BIG BLACK Yo!!!!
Old Dec 17, 2008 | 09:54 AM
  #365
wshihdnevo's Avatar
Old Dec 31, 2008 | 09:05 AM
  #366
jid2's Avatar
I've got a bunch of stuff taken back off and am hoping to pull the tranny today. I'm less than motivated though... Must go skiing.........
Old Dec 31, 2008 | 08:28 PM
  #367
jid2's Avatar
The tranny is out and now I just need to remove the clutch and flywheel and replace the leaking plug. I'll load some pics later.
Old Jan 1, 2009 | 03:42 PM
  #368
wshihdnevo's Avatar
word, bout time son!
Old Jan 1, 2009 | 08:00 PM
  #369
RAbishi's Avatar
It can be hard to get motivated to work on the car...
Old Jan 4, 2009 | 11:40 AM
  #370
wesside's Avatar
Hell yea it can this year I put in a motor, clutch, tranny and now I need to throw a new turbo on it because mine ate **** on xmas eve
Old Jan 4, 2009 | 12:37 PM
  #371
Dragracer187's Avatar
Do you have a picture of the leaking plug? I have my tranny out, and want to replace it just in case it will leak.
Old Jan 4, 2009 | 08:06 PM
  #372
jid2's Avatar
You should be OK. The only reason mine leaks is that it was removed by the machine shop that bored and faced the block and they stripped the allen head a little. When I put it back in I don't think I got it tight enough. There's a small chance it's the freeze plug on the end of the block, but i won't know for sure until I remove the clutch and flywheel.
I removed the tranny on New Years Eve, and it's just been sitting waiting for me to finish. Here are a few pics from pulling out the tranny. I'll snap some of the leaky area when I get there.
Old Jan 4, 2009 | 11:22 PM
  #373
http://www.harborfreight.com/cpi/cta...emnumber=39178
you need it
Old Jan 5, 2009 | 07:24 AM
  #374
jid2's Avatar
Originally Posted by justboosted02
Yeah that would help. Luckily the transmisson doesn't weight that much. I end up laying under the car and man handling it with the jack for support.
Old Jan 11, 2009 | 02:39 PM
  #375
jid2's Avatar
Good times .
I finally took the clutch and flywheel out to look at my "leaky" plug... It wasn't leaking
Turns out it was the freeze plug on the end of the block, which is accessible without removing the tranny. This was the hardest plug to remove by far; back when I was working on the block a few months ago. The passage behind it is not very deep, so you can't spin the plug to remove it like the others. I ended up having to pry on it from the deck surface along with other prying moves, it was a bear. Some of that work may have slightly damaged the sealing surface - thus my current leak.
So I wasn't going to try and remove it again, especially with the head blocking the passage which allowed me to remove it originally. So I drove it in a little deeper, cleaned it with acetone, and put JB weld around the joint. Hopefully it works
Now I need to put the transmission back in and get it back on the road for more break in miles. That was a lame detour.
