Rebuilding my VIII
Old Jan 27, 2013 | 02:58 PM
  #136
ILuvJDM's Avatar
couple spoon engines would pull quite the premium a week before race wars
Old Jan 27, 2013 | 06:19 PM
  #137
IzzyRS's Avatar
I like the tuna here
Old Jan 27, 2013 | 07:33 PM
  #138
ILuvJDM's Avatar
bull****, nobody likes the tuna here
Old Jan 28, 2013 | 09:46 AM
  #139
aggieEVO's Avatar
Must.... watch... F&F MARATHON!
Old Jan 29, 2013 | 09:52 AM
  #140
aggieEVO's Avatar
Mocked up my bumper, just so I could the the FMIC framed in. Makes me happy.
Old Jan 29, 2013 | 10:20 AM
  #141
ILuvJDM's Avatar
no intent to get an aftermarket intercooler? You can get an ETS 3.5" for like $500 I think
Old Jan 29, 2013 | 10:28 AM
  #142
aggieEVO's Avatar
Not at this point. I want it to be stock-stocky-stock-stock at first and go from there. Minus some things that just make sense at this point.
Plus, I'm always broke.
Old Jan 29, 2013 | 02:00 PM
  #143
aggieEVO's Avatar
Just picked up my head. I'm excited but a little confused at the same time.
Last week I dropped off the head, new guides, new seals, stock springs, retainers and keepers, and what were supposed to be stock sized valves (inconel exhaust, black nitrited intake, slightly used, bought off the forum).
When I picked it up today, I asked him if it was a lot of work. He said yeah, getting those larger valves in the seats was more work than he had anticipated... I was a bit shocked, to say the least. He did a little drawing and tried to explain to me what was done, but it was over my head. I asked if they were +1mm. He said no, not that much larger.
I'm going to measure them against the stockers I have at home to see what's going on. I called Supertech to see what they had to say. They said that for a stock sized valve, no work should need to be done. I'll remove a valve when I get home to see what's up.
How concerned should I be with the situation? The tech at Supertech said I probably wouldn't notice anything, but might have a bit more power. I'm worried about interference with the stock piston? Should I be able to clear? What about tuning?
Pics for now:
Old Jan 29, 2013 | 03:56 PM
  #144
aggieEVO's Avatar
If they're oversized, they must only be .5mm over:
There's no way that's enough to hit a valve with stock cams. I'm just stressed. It was a long day and this was unexpected.
Head on block:
ARP washers and nuts are lubed up and in hand tight. I'll torque this evening after dinner.
That leads to my next question. There are mixed numbers posted all over EvoM for ARP torque specs. APR says 60. I called and confirmed 60. I even ran by some of the numbers on the forum. He said no, use 60 and use their lube...
Any helpul info here? I'm leaning towards 60...
Old Jan 29, 2013 | 04:24 PM
  #145
aggieEVO's Avatar
Okay, I must have screwed up something when I was looking at the part number earlier. It's 80... Glad I triple checked. What a day....
Edit: I think my computer at the office must have had the pdf for the main studs stuck in cache or something. Disregard.
Old Jan 29, 2013 | 05:24 PM
  #146
aggieEVO's Avatar
Starting to look like a motor:
ARPs torqued to 30-60-80
Old Jan 29, 2013 | 07:05 PM
  #147
steven121's Avatar
Nice!!!
Old Jan 30, 2013 | 07:07 AM
  #148
aggieEVO's Avatar
Cleaned up my lifters according to Jaffromobile on Youtube.
Laid out:
Filled and soaked in diesel all night:
Bled them out. Came out perfectly clean. Cleaned them out with brake parts cleaner:
Filled back with oil, bled, slathered in assembly lube, carefully placed in the head. Rockers and cams going in tonight:
Old Jan 30, 2013 | 07:23 AM
  #149
EVWO's Avatar
Awesome build!Cannot wait to see the finished product.
Old Jan 30, 2013 | 08:05 AM
  #150
aggieEVO's Avatar
You and me both!
