Rebuilding my VIII
Old Feb 2, 2013 | 06:25 AM
  #166
aggieEVO's Avatar
Here's where I left the car last night:
New cam seals in. Cam gears torqued to spec. Front cover bolted and torqued along with water pump, oil filter housing, tensioner, pulley/motor mount bracket. My scraper didn't come in or I would have installed the oil pan.
It seems that I'm missing the backing plates for the upper timing cover and matching screws for the crank angle sensor. Because of this, I decided not to time the car today. I was going to borrow tools from a local NTEC member, but didn't want to have to undo it all if I needed to remove the cam gears to access the backing plates.
I'm happy with the progress. It's nice to have parts on the motor and off my work bench. If I do anything today it'll be to torque down the intake manifold.
Old Feb 2, 2013 | 06:47 AM
  #167
badev0's Avatar
Great progress!!!
Old Feb 2, 2013 | 10:43 AM
  #168
aggieEVO's Avatar
Scraper is out for delivery today... to my office. I hate it when I do that.
Torqued down the IM. You can see the spacer in there. Hope that + the EGR delete will make for some cooler intake temperatures.
Old Feb 3, 2013 | 12:46 PM
  #169
aggieEVO's Avatar
Mounted the alternator. Hoping to get the oil pan on tomorrow night.
Old Feb 3, 2013 | 05:12 PM
  #170
aggieEVO's Avatar
A few more little things today.
Water pipe installed:
Cam sensor installed. By the way, I broke a cheap Chinese made socket torquing this down:
Exhaust manifold:
Also just installed the dip stick. I need new o-rings for it badly. Tomorrow night the oil pan goes on!
Old Feb 3, 2013 | 05:59 PM
  #171
Blue91lx's Avatar
I have extra dipstick o rings! If you can wait ill see if I can't mail em to ya.
Old Feb 4, 2013 | 07:41 AM
  #172
adrianojp's Avatar
Great job on this rebuild mate! Been there on another car, I understand the work it takes, but you will enjoy a great new car when it's over!!
Old Feb 4, 2013 | 09:40 AM
  #173
aggieEVO's Avatar
Probably the only "cool" part that I'm putting on the car for now. For one, the stock baffle got a chunk taken out when the rod exited the block. And, I don't want to pull the oil pan to do this later. AND, I've wanted one of these on the car since I first saw one.
Worth the wait:
Goodies:
I had to laugh. The auto-generated URL from imgur had a no-no word built in. Evom didn't like the link
Old Feb 4, 2013 | 02:47 PM
  #174
aggieEVO's Avatar
Just placed another small order. Enough to finish the timing and mount the turbo, mainly. Hopefully I can get my clutch ordered next week.
Old Feb 4, 2013 | 03:25 PM
  #175
IzzyRS's Avatar
please dont put a stock clutch in there
Old Feb 4, 2013 | 06:44 PM
  #176
aggieEVO's Avatar
I was planning in it, for budget's sake. I have more time (for a swap later) than I have money for a proper clutch right now. I won't be doing much launching and power mods will be slow for a while. Unless I find a good deal on an Exedy HD, I'll probably put in a new stock disc and call it a day.
Work for tonight:
Old Feb 4, 2013 | 07:39 PM
  #177
Blue91lx's Avatar
You should run the Comp HD single disc with the stock flywheel. Super cheap and is a great clutch.
Old Feb 5, 2013 | 02:47 AM
  #178
IzzyRS's Avatar
had it, loved it
Old Feb 5, 2013 | 04:30 AM
  #179
aggieEVO's Avatar
Super cheap is relative I'm still on the fence. I just read up on it, though, and that would probably be my choice. Thanks for the tip.
Old Feb 5, 2013 | 05:06 AM
  #180
ILuvJDM's Avatar
yeah get the comp stage 2 HD clutch, the one that english racing reviewed. I have it in my car and love it, and it's supposed to hold great power
