Rebuilding my VIII
Old Mar 8, 2013 | 01:57 PM
  #241
aggieEVO's Avatar
Redline fluids ordered for tranny.
Old Mar 8, 2013 | 04:48 PM
  #242
aggieEVO's Avatar
Coolant tank installed:
PCV valve installed:
Injectors with new rubber waiting:
Installed with new clips:
Old Mar 9, 2013 | 09:43 AM
  #243
pre2dat's Avatar
Way to go! It looks like you are going to be driving here soon?
Old Mar 9, 2013 | 10:12 AM
  #244
milruner's Avatar
man the car is looking good. love the valve cover was planning on doing the same thing.
MIKE
Old Mar 9, 2013 | 10:49 AM
  #245
aggieEVO's Avatar
I gotta say, I get a little too excited every time I walk by the car in the garage. It's getting close.
Old Mar 10, 2013 | 05:11 PM
  #246
aggieEVO's Avatar
Well, my assumption was correct. The ring came out of the wave spring at some point and was hanging out in the bottom of the pressure plate. It's out and I'm waiting on a new one. It's fine, but I might as well use the one I ordered. Both tabs were broken off the TOB. Fun times.
Parts will be here Tuesday, but it's my 8 year anniversary. I doubt I'll be installing them
Old Mar 11, 2013 | 06:52 PM
  #247
aggieEVO's Avatar
They're heeeere!
And:
Easy part:
I'll see what I can get done tonight.
Old Mar 11, 2013 | 08:51 PM
  #248
aggieEVO's Avatar
New TOB installed... again:
And she's in:
Not as bad as I thought it'd be. I had to wrestle with the xfer case a bit. It's still not stabbed, unfortunately. I need to get the car a bit higher so I can have room to maneuver. TOB popped right in, like it was supposed to. Slave cylinder is on. Clutch feels great! That's probably all I'll get to do until this weekend. Good update, though.
Old Mar 12, 2013 | 10:28 AM
  #249
pre2dat's Avatar
Man, you're almost there! I take it there was no play in the input shaft that the TOB went on? I'd imagine that there wouldn't be, still wondering how that may cause the P0300 CEL code to throw?
*** I thought my world was over when my wave spring/wedge collar fell out during my install... fortunately, it just needed to be put back together. Funny how such a small ring can leave a clutch useless...
Old Mar 12, 2013 | 12:48 PM
  #250
aggieEVO's Avatar
Yeah, I checked for play. Zero. Everything felt good.
Yes, having that spring come apart really messed things up!
Old Mar 16, 2013 | 05:28 PM
  #251
aggieEVO's Avatar
Well, that's a bummer. Spent 3 days in San Antonio and couldn't get ahold of the guy that told me he'd sell me the spoiler. PMd him numerous times with my number. Sucks.
Old Mar 17, 2013 | 10:36 AM
  #252
aggieEVO's Avatar
Transfer case in and torqued down.
Old Mar 17, 2013 | 08:47 PM
  #253
aggieEVO's Avatar
Well, it was a very productive day. I didn't expect to get as much done as I did.
Transfer case in and torqued. Axles in and wheels back on the car. Oil cooler line temporarily looped to delete the cooler. Oil filter on. Shifter linkage installed (my favorite part of the day). Exhaust fully bolted up from turbo back. Fuel lines bolted up. Battery and tray installed. LICP installed. Radiator installed. Thermostat housing installed. All coolant lines are hooked up.
Things I've found that I need.
1. Still need a stock ROM flashed
2. Diaqueen for transfer case
3. Coupler from UICP to intercooler
4. Hose from BOV to UICP.
5. Stock boost hoses with restrictor pills
There will still be a few things I'll need after that, but those are the major things. I found that my front outer ball joints are torn. I'll need to replace those before I get an alignment.
Also, I hooked up the battery for kicks. I realized I wired the amp back up incorrectly.
And, now that the engine is installed, when I turn on the headlights, I get a lot of noise in the cabin. Not sure if it's because I have the fuel pump hooked up, now.
So, hopefully I'll get an order in tomorrow and get this show on the road!
Old Mar 18, 2013 | 09:55 AM
  #254
aggieEVO's Avatar
Quick pic:
Old Mar 18, 2013 | 10:37 AM
  #255
Lancerboy89's Avatar
coming along nicely
