razorlab's simple build(s)
Old Feb 7, 2017 | 08:57 PM
  #586
RazorLab's Avatar
Short block is all assembled! Yay final stretch. Trying really hard not to get anxious now....
Old Feb 8, 2017 | 09:44 AM
  #587
LetsGetThisDone's Avatar
Awesome man. Can't wait to see it going. You have a lot of wiring ahead of you with that datalogger setup.
Old Feb 8, 2017 | 10:54 AM
  #588
stupidadult's Avatar
This thread is epic! I'm not even an EVO owner (yet) but kudos man, this is a sick build.
Old Feb 13, 2017 | 03:53 PM
  #589
RazorLab's Avatar
Anybody have a good source for high quality silicon vacuum caps?
Also, I can measure mine but does anybody off the top of their head know the cap size for the breather port on the intake manifold?
Old Feb 13, 2017 | 11:10 PM
  #590
deylag's Avatar
https://www.mcmaster.com/#silicone-tube-caps/=16chnbq
Old Feb 14, 2017 | 01:48 AM
  #591
tephra's Avatar
1.2e+7 nano meters...
or 12mm...
at least thats what I put on mine
Old Feb 14, 2017 | 02:16 PM
  #592
RazorLab's Avatar
or 12mm...
Thanks!
Old Feb 23, 2017 | 08:07 AM
  #593
RazorLab's Avatar
Update. The machine shop assembled the short block with clearances I didn't agree with (a bit too tight).
So it's back at the machine shop to see what they can do.
Old Feb 23, 2017 | 09:34 AM
  #594
Where were they vs what you want?
Old Feb 23, 2017 | 09:48 AM
  #595
RazorLab's Avatar
Current:
Mains - .0015"
Rods - .0020"
Top ring - .017"
Second ring - .022”
Requested:
Mains - .0021"
Rods - .0022"
Top ring - .020”
Second ring - .022”
Old Feb 23, 2017 | 10:02 AM
  #596
They're gonna have to line hone the block to open the mains, and possibly polish the crank a bit.
What did they set piston to wall at? Or did the sleeve installer set that?
Old Feb 23, 2017 | 10:13 AM
  #597
RazorLab's Avatar
Yea I am waiting to hear back their feedback on my request. They had already line honed the mains for the ARP hardware.
I figured they would machine or polish the crank.
I'm still trying to get the piston to wall measurements. RED did the cylinder bore for 86.5 (my request for my pistons) after he put the sleeves in.
Old Feb 23, 2017 | 11:15 AM
  #598
The cool thing about pistons, is the size they list is actually the finish size for the bore. So, an 86.5 piston is actually 85.496 if the mfg'er wants .004" clearance, so an 86.5 bore will yield that.
When line honing for studs, they shave a few thou off the seat surface of the main caps, and then bore them back to round. This ensures any distortion is removed without oversizing the bores. There is a spec for main bearing bore diameter, they probably put it at the tight end I'm guessing, and need to take it out a bit.
Old Mar 25, 2017 | 12:05 PM
  #599
RazorLab's Avatar
So the block was redone and finished on the 7th.
Stated it was "redone to the measurements I requested" this time which where:
Mains - .0021"
Rods - .0022"
Top ring - .020"
Second ring - .022”
I asked for the spec sheet after doing it again and have yet to see it. I think this might be the first and last time I use a "old school" machine shop.
They charged me another $300 to redo the block, which included new main bearings so I guess that isn't so bad.
Either way I am anxious to get the car back. Going to contact my buddy at the shop on Monday to see what the progress is.
As of April 11th, the car will have been down for a year. :-/
Old Apr 25, 2017 | 12:38 PM
  #600
TF is going on in here. Been way too long with no updates...
