razorlab's simple build(s)
Old Apr 25, 2017 | 12:49 PM
  #601
RazorLab's Avatar
TF is going on in here. Been way too long with no updates...
Tell me about it.
Engine was being put all together and a misplaced part put it on hold for two weeks as I had to re-order a $2.50 cam bearing.
Continuing to test my patience but at least it isn't being rushed.
Old Apr 25, 2017 | 01:05 PM
  #602
mines5's Avatar
This thread is so informative.
I haven't read the whole thread but i want to why you used so much heat shielding ?
Are you going to take it to circuit or auto x ?
With the requested clearances which engine oil grade are you going to use ?
Old Apr 25, 2017 | 01:06 PM
  #603
LetsGetThisDone's Avatar
Derp. At least the misplaced part was inexpensive, and not overlooked...
Old Apr 25, 2017 | 01:18 PM
  #604
RazorLab's Avatar
Car is used for track and with the turbo in the back on the 4b11, decided to go overkill on the heat shielding.
Most likely going to use 5w40 or 10w50 oil.
Old May 18, 2017 | 12:44 PM
  #605
RazorLab's Avatar
Progress!
Old May 18, 2017 | 04:37 PM
  #606
Pal215's Avatar
Super clean build! Can't wait to see it done. With all that heat shielding on it should easily pass the **** Visual smog test we have here in CA as long as they don't see the wastegate (which they probably won't).
Old May 19, 2017 | 01:41 PM
  #607
RazorLab's Avatar
More progress.
Clutch in, transmission mounted.
Building turbo to block brace now...
Old May 19, 2017 | 01:47 PM
  #608
V.8MR's Avatar
Man that shielding looks awesome...
Old Jun 20, 2017 | 05:12 PM
  #609
RazorLab's Avatar
Well..... everything was going great, almost everything back in and buttoned up and then....
Fuuuuuuuuuu.......
Old Jun 20, 2017 | 07:57 PM
  #610
e_kobz's Avatar
Is the down pipe the one that came with the MAP kit? What brand?
Old Jun 20, 2017 | 08:08 PM
  #611
e_kobz's Avatar
http://www.streettunedmotorsports.co...nch_2_bolt.htm
Could use this with 2 vibrant gaskets and some longer hardware
Old Jun 20, 2017 | 08:42 PM
  #612
RazorLab's Avatar
Yes, came with MAP kit. It's unique fabbed for their kit.
The real problem is the 02 sensor hitting the drive shaft...
Arrghhhh.
Old Jun 20, 2017 | 09:16 PM
  #613
e_kobz's Avatar
Arrghhhh.
Yeah that's really bad what's your alternative? Block that off and weld another bung on?
Old Jun 20, 2017 | 09:41 PM
  #614
RazorLab's Avatar
I contacted MAP as soon as I found out. To their credit, they where very fast in reply. They are looking into it. Going to see what they say first.
Old Jun 21, 2017 | 08:04 AM
  #615
Knowing how map handles fitment issues, they're probably going to tell you it must be an issue with your car.
