"Project Hard Park"
Old May 20, 2016 | 08:51 AM
  #31
V.8MR's Avatar
8 balljoints and 18 bushings later... every suspension arm completely rebuilt!
Old May 23, 2016 | 10:06 AM
  #32
TexasLT4's Avatar
Looks great! I just finished rebuilding my fronts with Superpro equipment and I'm doing the rear arms next weekend. Did you try the freezer method this time for the rear ball joints? Good to know I'm not the only one who is taking on this project. Every single one of my friends said its way to much work for bushings and don't think there will be the much of a return in performance, but I think they're just intimidated by the press.
Old May 23, 2016 | 03:24 PM
  #33
V.8MR's Avatar
Yeah its not bad really. The hardest part was finding the correct pushers and receivers. Also the only bolt which sucked was the drivers side rear upper control arm rear bolt. So close to the fuel neck etc. For the upper rear control arm I used some plumbing fittings in copper and cast iron which worked perfectly. The bushings have the poly bonded to metal. Was hard to find something to both fit over the poly, and just barley small enough for the metal portion. I am in no rush so taking my time and several trips to parts stores/hardware stores to make sure I had the right stuff. Also I feel highly skilled with the press, lots of experience now. Overcoming some of the violent pops when the ball-joints let go etc is another thing.
Old May 28, 2016 | 09:52 AM
  #34
V.8MR's Avatar
Its been slow going the past few weeks. Working a lot of over-time. I also managed to sell my Harley to help fund this. Got started on rebuilding brakes. Procrastinating on dropping the front xmember. That's whats left to get front sway bar and steering rack bushings in. Then I can reassemble everything Ive taken off.
Old May 28, 2016 | 10:43 AM
  #35
Way to go, we are watching you & envious of your enthusiasm & progress
Good job moving the Harley out & putting forth those $$$ towards a saver alternative. EVO is not a bike, but when modded, its as close as we are going to get
Old May 28, 2016 | 11:15 AM
  #36
V.8MR's Avatar
Thank you Sir. I just don't get the chance to ride since I got married and had my son. So its just losing value and gaining dust in the garage. Was time to let it go. I also recently sold my 68 Chevy C10 which I've had for a while. My garage feels so empty now lol:
Old Jun 10, 2016 | 03:55 PM
  #37
V.8MR's Avatar
Ok got a lot more work done. Finished the caliper rebuild, dropped front sub-frame and installed rack bushings and front sway bar. Also cleaned and painted some of the mounts.
I have fallen into the "spiral". Everything I take off/work on, I find more stuff to buy and install "while I'm at it".
Going to take this "opportunity" to also do complete engine/trans mounts. Just ordered the Torque Solutions 4 piece kit. Also exhaust hangers.
And because I am a little OCD I ordered most of the bolts/nuts and hardware I have removed new from mitsubishiparts.net.
All rebuilt!
Fresh out from under the car.
Disassembled
All together. A little more cleaning after this photo
WL Front sway bar vs OEM
Motor/trans mounts. Timken front hubs.
Had to remove exhaust.
Lazy dog on a rainy day
Old Jun 10, 2016 | 04:33 PM
  #38
Nice Bro!
You will notice a difference w/those TS mounts, especially the rear trans mount. I kept my rear mount stock due to the vibration complaints I read
Old Jun 10, 2016 | 04:36 PM
  #39
Lazyfong's Avatar
Love how exhausted your dog is from doing all the work.
Old Jun 10, 2016 | 05:00 PM
  #40
V.8MR's Avatar
Taking NVH to the next level haha
Old Jun 11, 2016 | 11:28 AM
  #41
V.8MR's Avatar
They both were tired from all the hard work. Here is the other one
Old Jun 18, 2016 | 10:50 AM
  #42
V.8MR's Avatar
Some smaller updates. Cleaned the knuckles. I think that's what they are called lol. Shot some paint at them too. Also installed ARP studs on Timken front hub/bearing ***. Still waiting on rear from mitsubishiparts.net. Also waiting on hardware from them to get start to put all this back together.
Got motor mounts replaced with TS pieces also.
Before cleaning/painting. Just getting started on mating surfaces.
Hubs with ARP studs, knuckles/spindles cleaned and painted.
Rear mount/sub frame. Also cleaned/painted the bracket.
Front mount
Old Jun 18, 2016 | 02:36 PM
  #43
Are you considering doing at least an Autopower roll bar? One of the best mods Ive done
Old Jun 18, 2016 | 03:26 PM
  #44
V.8MR's Avatar
I'd like to do a legit cage but its not in the budget at this time. Probably next year.
Old Jun 20, 2016 | 05:55 PM
  #45
Balrok's Avatar
FYI unless you call and harass olympia/mitsuparts.net you won't see your parts. For oem stuff use STM or MAP.
