"Project Hard Park"
Old Jul 24, 2016 | 02:52 AM
  #76
kikiturbo's Avatar
Originally Posted by V.8MR
Question for anyone whos reading. Ive been installing everything dry except blue serviceable thread locker. Logic is ant-seize would heat up and melt or burn due to brake heat. Specifically hub to knucle and half-shaft to hub.
Car will never be a daily and is in a garage 24x7. No winters etc.
Any thoughts?
I use tons of copper grease on everything... I do see lots of salt on the roads though.. Makes it a joy to work on later..
Old Jul 25, 2016 | 08:51 AM
  #77
heel2toe's Avatar
Stay cool my friend! I put in a Mitsubishi (yay Mitsu lol!) minisplit heat pump in my garage to heat it in the winter didnt really care about the AC but I must admit now when I go in there I crank the AC and am loving life, lol!
Anyway, just saw your comment about using antiseize. As someone who drives his car in the winter I religiously use antiseize on everything unless its something that needs threadlocker. I make a mess with it but I tell you first time doing my wheel bearings sucked to get it apart but now them literally fall apart. I see you're in Chicago so I'd do everything in my power to make things easier down the road.
Old Jul 28, 2016 | 04:08 PM
  #78
V.8MR's Avatar
Excited to say the least. No rubbing compressed this high. Toed in to check arm clearance and good there. I believe max camber.
Old Jul 30, 2016 | 10:09 AM
  #79
Terror Rising's Avatar
Great progress. This might be the kick in the *** I need to order the final round of parts and start putting my car back together. Watching what's basically a twin car go back together makes me wish this was my thread. I'm also upgrading to 18x10.5 NT03s except I'll be adding 285/30 A7s.
Old Jul 30, 2016 | 12:04 PM
  #80
V.8MR's Avatar
Start a thread, I always loved watching other folks progress on their builds too. This one has been a long time coming. Wish I had the resources when I was younger to do this.
Old Jul 30, 2016 | 02:03 PM
  #81
V.8MR's Avatar
Cut off the exhaust hanger that is unused and has bothered me for years. All 4 corners of the car have all the arms/knuckles installed. Have the front coil-overs on and next up is rear sway-bar and coil-overs.
Old Jul 31, 2016 | 03:30 PM
  #82
Meathooker's Avatar
Good luck getting those wheels to fit...
It's not that bad at all.
Old Jul 31, 2016 | 04:47 PM
  #83
He got them to tuck but running the camber maxed out. That could be a performance issue
Old Jul 31, 2016 | 05:23 PM
  #84
V.8MR's Avatar
Wont know until alignment, but I'm not going to slam the car for any kind of visual goal. Just want it to be functionally as low as possible. I don't think its possible to get wild camber even maxed out with stock arms and eccentric bolt. Once its good enough to put down on its own weight I'll trailer it to get corner balanced and race aligned. Thinking something like the following but I need to research some more:
Max front caster possible
-3 camber up front
-2.2 in the rear
Zero toe all around
I got rear c/o installed. Good clearance to the wheel/tire from what I can see.
I have a lot of little stuff to do now. Like putting rear drum brakes back together, wheel speed sensors, rear sway-bar, new bolts/gaskets for exhaust(old ones rusted out) etc.
Old Jul 31, 2016 | 06:07 PM
  #85
IMO, you have done one heck of a nice job to date Just making sure this is a track & not stance build =)
Old Jul 31, 2016 | 07:02 PM
  #86
V.8MR's Avatar
Thank you, its been fun all along. Lots more to do still.
Old Jul 31, 2016 | 07:15 PM
  #87
RalliartRsX's Avatar
Loving this build!
Old Aug 1, 2016 | 07:17 AM
  #88
nollij's Avatar
-3 camber up front
-2.2 in the rear
Zero toe all around
If this is a track only car,
toe out front (1/16-1/8" total as a starting point)
toe in rear (0-1/16" total as a starting point)
more front camber (-3.5 range as a starting point)
and learn to do your own alignments. Paying $500 each time for a "race alignment" gets expensive when you are constantly tinkering. It also makes it difficult if you want to adjust the alignment at the track.
Old Aug 1, 2016 | 09:17 AM
  #89
LetsGetThisDone's Avatar
$500 for an alignment? LOLOLOLOLOLOLOLOLOL.
Old Aug 1, 2016 | 11:43 AM
  #90
RazorLab's Avatar
What the heck? Who the hell charges $500 for alignments?
I've never payed ANYWHERE close to $500 even for a full "race" alignment with corner balancing, height adjustment, etc.
