I Can Haz Track Car???
Old Sep 18, 2018 | 09:30 AM
  #286
V.8MR's Avatar
Man some bad luck all around, but at least you had some seat time. Its all a learning experience so each outing should be better than the last. And you know what needs fixing.
  #287
V.8MR's Avatar
And thanks for all your help and support with my build. Dont hesitate to ask if there is anything I can do to help with yours.
Old Sep 19, 2018 | 04:54 AM
  #288
Ayoustin's Avatar
It was a nice to get back on track for a least a little and it didn't cost me anything, still would've been nice to get a bit more time.
No problem man. Always a good time hanging out and shooting ****. I'll probably be getting ahold of you soon when I have time to breath this week.
Old Sep 21, 2018 | 08:58 PM
  #289
codgi's Avatar
Originally Posted by ayoustin
He went off. Slammed right into a corner station. It was a mint 1 owner 20k mile car too.
Crazy stuff
Old Sep 26, 2018 | 07:04 AM
  #290
sumopower87's Avatar
YUP! Subscribed!
Old Sep 30, 2018 | 11:03 PM
  #291
Ayoustin's Avatar
So it looks like I'm going to be yanking the engine and rebuilding it again. At least I'll be able to see how the drop in pistons have fared after almost 10k miles and 5 track days. Had almost nothing in my catch can and most of what was caught was water and fuel so I'm hoping for decent looking cylinders and pistons. Assuming everything checks out okay it shouldn't dent the wallet too much, just going to get the deck on the block and head cleaned up and slap all new gasket on as well as throw the cams in along with some springs.
In other news I was visiting some friends in Indianapolis this weekend and made a couple stops along the way to pick up some stuff from the Pro Awe guys. Ended up getting a set of Hankook TD Z221 tires and two PF01 18x10.5 wheels along with a herra rare evo 7 rear bumper. Got some small body stuff planned this winter and I'm happy I was to get one of these without straining myself for months looking for one.
Old Oct 1, 2018 | 07:04 PM
  #292
deylag's Avatar
How did you push coolant so easily? Seems like an assembly issue rather than a component issue.
Old Oct 1, 2018 | 07:16 PM
  #293
LetsGetThisDone's Avatar
I don't think he ever surfaced the block.
Old Oct 1, 2018 | 08:52 PM
  #294
Ayoustin's Avatar
The head was decked the block wasn't. I measured the block and it measured within spec for flatness. My guess is that it was insufficient surface finish on the block side to seal the headgasket. I've seen this happen before on other engines, it's just more likely to be an issue with aluminum than iron.
Definitely not an assembly issue. A couple months back I rechecked the torque on the headstuds. They were all still at the 85ft/lbs I torqued them to when I put the engine together.
Old Oct 21, 2018 | 06:49 PM
  #295
Ayoustin's Avatar
Well looks like I'm putting the car away for the winter next week.
As it stands here's the plan for the winter:
- Engine rebuild/refresh + cam/spring install
- SSB front knuckles
- SSB lower control arms
- Rear suspension and diff bushings
- Front brakes
- Evo 7 rear bumper and possibly rear diffuser
- New internal wastegate setup
Old Oct 22, 2018 | 06:51 PM
  #296
deylag's Avatar
Ahh makes sense.
Well now you have learned that your block is warped. I need to find a machine shop so I can start my own engine build.
Old Nov 6, 2018 | 07:10 AM
  #297
Ayoustin's Avatar
Motor and trans will be out this weekend. Should have it all torn down next week and off to the machine shop.
Got a good deal on some 1450cc FIC injectors so gonna send those out to Boostin to get cleaned.
Was a little sad upon draining the trans. Saw a fair amount of silver fluid pour out and the plug had a ton of metal stuck to it (pic shows after wiping it off to show how thick build up was around entire magnet). Fluid was fresh as of last fall. The trans is original with 110k on it with 5+ years of track driving and has given me zero issues so it's earned its keep, just hoping I can get one more season out of it as a rebuild isn't in the budget this year.
Old Nov 6, 2018 | 07:49 AM
  #298
heel2toe's Avatar
The plug doesnt look terrible. Sure its not ideal but its never going to come out clean IMO. The way I see if it it aint grinding run it to the ground. What fluid you running in there? Not to get into a fluid debate I've had the best luck with Motul in my trans. Good fluid and a properly adjusted clutch go a long way to keeping the trans happy.
Old Nov 6, 2018 | 08:02 AM
  #299
That's why I change drivetrains fluids pretty much every track day. Just helps get all the junk out.
You can get input shaft bearings and synchros from Jacks for $660. Output shaft shaft and center diff bearings probably another $150-$200. But if it wasn't making noise and it was shifting ok, I'm sure it'll be fine.
Old Nov 6, 2018 | 08:21 AM
  #300
Ayoustin's Avatar
I've been running Pennzoil synchromesh. It's a good fluid for higher mileage transmissions with yellow metal synchros. My main cause for concern is that in the previous times I've drained the fluid, it's not had nearly this much metal debris in it. This is probably 3-4x the amount that came out last time, using the same fluid. The pic is just to show how thick it was, that thickness was on the entire magnet.
Gonna cross my fingers and keep a close ear on the trans next season. Hopefully can get something of a sadety budget in order in case it lets go mid season. Plan was to give it to TRE next winter for their ultimate ratio setup with a PAR 4th and jdm 5th gear. Still undecided on final drive, still plenty of time to change my mind 10+ times.
