CBRD- BBK info- NEW turbos, etc...
Old Aug 25, 2010 | 07:50 AM
  #511
mrfred's Avatar
Originally Posted by CBRD
Thanks for the kind words everyone, we are working away on it,
trying to have one specific fitting machined for the production lines.
I like what I've seen from the spooln'up kit, worked very well on a car here the other day!
cb
What's the ETA for the oil feed line assembly? I'd like to use it when I install my BBK Full.
Old Aug 25, 2010 | 08:01 AM
  #512
scheides's Avatar
EvoM Moderator
I don't think you need it on the Full, but I guess it couldn't hurt! (or could it?)
Old Aug 25, 2010 | 08:05 AM
  #513
TURBevO8's Avatar
hey everyone here is an update:
We have been testing a group of these turbos.... and the conclusion has been that at high boost and under stress we are seeing a little more bearing wear than what we feel is acceptable.
We are already working on the solution and testing with a revised bearing package and oil supply which will be supplied as part of the turbo
Everyone keeps commenting (on like 3 threads) about the new oil lines. Any details on the "revised bearing package" yet? This should at least be something we should discuss, no?
Old Aug 25, 2010 | 08:11 AM
  #514
06MREvo's Avatar
Ahhh...good question...I would like to know that as well...
I may try and give you a call after work Chad...
Old Aug 25, 2010 | 08:17 AM
  #515
mrfred's Avatar
By taking some oil from the main line, there's less to go everywhere else, so in concept, the new feed line could mean a little less oil going everywhere else, but I think that CBRD must have assessed this possibility.
Old Aug 25, 2010 | 09:19 AM
  #516
R/TErnie's Avatar
the CBRD oil line kit will most likely be similar to the FP kit. Same issue...same solution.
Old Aug 25, 2010 | 09:37 AM
  #517
detroit pistins's Avatar
Just a thought…..has anyone tried increasing the volume flowing to the cartridge instead of the pressure? if I understand the construction of the turbo cartridge correctly, it has somewhat similar of a setup to a “piston ring” form where it withholds the oil in its place for lubrication. So my thinking is, if u increase the pressure, wouldn’t that increase the risk of leakage thru the ring? but higher volume will help eliminate starvation? …..might be totally off here..lol
Cheers!
Old Aug 25, 2010 | 09:49 AM
  #518
06MREvo's Avatar
Cheers!
With the size of the housing I don't think its possible to increase the volume flowing to the cartridge...I may be wrong as well...
I have always thought it was interesting that larger turbos (T3, T4, 30 & 35R & bigger) can have their oil feed line coming off the stock location on the head but these larger stock frame turbos need the oil feed line to come from the filter housing...
Old Aug 25, 2010 | 10:07 AM
  #519
TxEvo8's Avatar
It is my understanding that the larger frame turbos have ball bearing cartridges, instead of journal bearings, making them better able to withstand the rigors of a extended periods of on-boost, like you would get on a road course.
Old Aug 25, 2010 | 10:13 AM
  #520
06MREvo's Avatar
True...forgot about that...good point...
Old Aug 25, 2010 | 12:49 PM
  #521
EvolutinIX's Avatar
Can you let me in on why you decided on the full instead of the b? I know spool difference, transient response etc, but with your level of knowledge on evos I am curious what led you to this decision. I was set on the b, but now you are the third person I have seen go with the full, any info you would share would be great. Thank you sir.
Old Aug 25, 2010 | 04:10 PM
  #522
mrfred's Avatar
My reasons are probably not typical. I got a good deal on a used BBK Full (scheides'), and when I heard about the BBK-B, I contemplated getting my Full upgraded to a B, but after seeing the kinds of gains that are possible with little or no loss in spool from some of the new tubular manifolds that are hitting the market, I decided that a Full with a tubular exhaust manifold would be a killer street combination for a reasonable cost. A new BBK Full + tubular manifold is a bit more pricey and harder to justify vs a BBK-B with a ported stock exhaust manifold.
Old Aug 25, 2010 | 04:52 PM
  #523
06MREvo's Avatar
Very good points there sir...I've have been reading up a lot on all the tubular manifolds coming out...Looking forward to your results with a BBK Full & Tubular manifold...Any ideas on what manifold?
Old Aug 25, 2010 | 05:35 PM
  #524
turbotboz's Avatar
I think the focus with the new kit is cleaner oil to the bearings and higher oil pressure which can be restricted inline to desired levels until perfected. If the head oil feed line is capped, the quantity of oil to lubricate the rest of the engine will remain the same (unless the new line is significantly longer than oem).
-Travis
Old Aug 25, 2010 | 06:01 PM
  #525
mrfred's Avatar
FiD, ToxicFab (although not clear that he is going to market it), and Fortune Auto all look nice. The first two are equal length while the Fortune Auto is not. All have documented significant gains. The FiD has an awesome collector setup with the tubing aiming into the turbo at as optimum angle as possible.
-Travis
Agree that since the line coming off the head would be capped, there should be close to a zero sum effect on oil distribution through the engine.
