Utah Evos
Old Jan 29, 2009 | 11:50 AM
  #19921
wesside's Avatar
Originally Posted by gear head
If I remember right that thing was a torque monster though...would have been interesting to see what the intake temps were at those boost levels.
I wish we had 93 too..100 is sooo damn expensive
For sure, any catastrophic failure will make anybody think twice about agressive tuning I was more or less agreeing with you about you're tune...not putting it down One key element I did leave out is when I was running that much timing it was on the stock cams. Since replacing them my days of running alot of timing was over....until the meth was working that is The '05 cars kick *** for some reason!
Yea I wasn't taking you putting it down at all I do want a more aggressive map but I kinda don't wanna do any tuning until I throw a bigger turbo on because I don't want this ported viii turbo on for too long. The '05 are sick
100oct is way to expensive that's why meth injection is sooo nice We probably have an effective octane rating around 100 running it straight 100%
o btw I finally downloaded that 96530006 rom and was going to start putting it together today. So your xml files are edited for 2byte load, ecu boost and the tephra mod right? Is the ecuboost control something you can just turn on or off like the tephra mod? And should I go ahead and install ecuflash 1.41?? I've been on 1.30 forever
Old Jan 29, 2009 | 12:56 PM
  #19922
Evolution IVGSR's Avatar
thats why you should all go E85 since its rated more than 100oct and cheaper than pump gas
Old Jan 29, 2009 | 01:41 PM
  #19923
Fairclough's Avatar
Here are a couple shots. Sorry the car is dirty.
Old Jan 29, 2009 | 01:51 PM
  #19924
subrwho's Avatar
Cam install?
Hey guys i'm looking to ditch my bc 272 cams and get some gsc s2's. Anyone know a place that will install cams for a good price? (I had solid auo works do it last time and I think it was around 375$. Just curious if there is somewhere cheaper) Thanks.
Old Jan 29, 2009 | 02:24 PM
  #19925
Jason what is the size of the wheels on your car? 19x?.?
Old Jan 29, 2009 | 02:25 PM
  #19926
33's Avatar
33
Is it just me, or are those really narrow?
Old Jan 29, 2009 | 02:27 PM
  #19927
I think I know someone how may want you old cams. How much are you wanting for them? and he may just swap you for labor or something.
Old Jan 29, 2009 | 02:56 PM
  #19928
bbbwrx's Avatar
Originally Posted by 33
I bought it used from a dealer in Riverdale, so I was able to get the current (at the time) Yamaha factory financing offer
Ben, my roommate and I are tryingto get a buddy of ours on a bike, Ill talk to him and see if he is interested.
Sweet!! if someone sells it for me I will kick them a finders fee for sure.
Ben
Old Jan 29, 2009 | 03:16 PM
  #19929
gear head's Avatar
EDIT: you may have to run ECUflash in developer mode to see all the tables.
In the tephra ROM, he has already made the 2-byte mods to the MUT table(no need to change anything)...xml files have no effect on the ROM(they are only for viewing tables)
If you want to use load based boost control just alter the tables in the " TURBO BOOST SINGLE SOLENOID" section.
A good read for load boost....
https://www.evolutionm.net/forums/ec...trol-mods.html
Direct Boost is psi based & requires the JDM MAP. to make this work the tables need to be altered correctly...
That info is in this thread on post #366
https://www.evolutionm.net/forums/ec...ml#post5627574
This is also a good read...
https://www.evolutionm.net/forums/ec...t-control.html
You already have all the tables defined in the xml files, just alter the tables for whatever you want.
There is a chance you will get a PO505...no big deal it's an easy fix, just let me know & I can walk you through the process.
To get the IMMO working change the top value(0xffa) in ECU Periphery7 to 0x0058.
Hey I didn't know 1.41 is out....The only thing that wont work with 1.30 is the Periphery Bits tables(HEX tables will work) & you may have to change the endian to little. If you use 1.41 you should ONLY need to add the MOD file using the same instructions in the folder.....
Old Jan 29, 2009 | 04:20 PM
  #19930
Fairclough's Avatar
19x8 w/235-35-19 Just for show and street (these are only 1.7lbs heavier than my stock setup), I'm going to run 18x9.5 for the track.
Old Jan 29, 2009 | 05:30 PM
  #19931
So you wanting to track the Evo Or Drag? Sounds more like track but I would have thought you would have done Drag with you draging your bike
Old Jan 29, 2009 | 06:12 PM
  #19932
wesside's Avatar
I'll install em, cams aren't bad at all You could install em yourself too
ECU boost control mods
how-to: ECU-based direct boost control
The stock ECU has gear dependent boost control!
Yea I've got it in developer mode and just took a glance at my map. I updated my ecuflash, I had to install service pack 3 for xp cuz it's "recommended" you do so before installing ecuflash 1.41 I don't know if I'd fix the immo code or not..guess I could. So yea I need to do some reading because yea it's confusing and I need to add the tephra v5.10 tables to the xml and I need the p0300 fixed and might fix the p0401 too cuz I don't have any vacuum lines popped off but since it did that one time I cant get the p0401 "egr insufficient flow to go away"
So I'll play with the 96530006 right now for a few minutes before I go out tonight. I might be asking you a few more questions
EDIT: So wtf why is there a 96940011_Mods.xml and a 96940011.xml files?? did you seperate the mods from the base xml file? or they supposed to be serperate? I don't see the tephra mods on my 96940011 map
Old Jan 29, 2009 | 06:28 PM
  #19933
Fairclough's Avatar
I've done 20+yrs of autocrossing, just not in the Evo. I'll probably do both.
Old Jan 29, 2009 | 08:06 PM
  #19934
~BoOsTeR~'s Avatar
Ha ha, I can prolly help you with that.
Old Jan 29, 2009 | 09:02 PM
  #19935
Fairclough's Avatar
I know you can, as soon as it's done i'm bring her over.
