Utah Evos
Old Mar 8, 2005 | 09:27 PM
  #2806
DynoFlash's Avatar
Originally Posted by UT_Evo
I'll let you know if I notice anything, or see the boost needle dipping or fluxuating a lot. I haven't yet felt anything or seen the needle dip or fluxiate much, it goes up to like 21 real fast and then down to like 20-20.5 usually, is that an issue?
Of course tyour not going to see anything bro - I tuned it ! Its perfect ! Just keep using the same gas and your perfect. Get an alcohol kit and you can turn up the boost 3 psi and 2 more derees of ign timing.
Old Mar 8, 2005 | 11:26 PM
  #2807
vtsnake's Avatar
well the reducer i put in the exhaust tip seemed to create back pressure. boost lag is improved. but it's still not as restricted sounding/feeling as the injen can. i am extremely happy how the car runs! it rocks! al even tho you are a dick, your tune is awesome! THANKS!
zachary... GFY!
Old Mar 9, 2005 | 02:46 AM
  #2808
liberty2000rs's Avatar
Originally Posted by vtsnake
Here's my take on free flowing exhaust. take it for what its worth. you wanna argue about it? go ahead, i won't.
after switching to the magnaflow can (3" straight thru vs the Injen can 3" reduced down to 2 1/8") the car does flow better. it also runs better up top (rpms). but imo the car suffered noticibly down low. i have a ton more turbo lag whereas b4 i hardly noticed it. i'm sure the overall hps with a free flowing muffler is higher but i'm willing to bet the torque curve has dropped. i definitely noticed between shifts the car lagged a lot more than with the injen can. for drag applications the hp gains are prob worth it but for tracks with twistys where you shift a helluva a lot more i think the low end torque with less lag is important.
so what i have done is made a reducer pipe (3"-2 3/8") to try and create some back pressure. we'll see if that helps my spool. regardless tho, i'm happy cause the injen pipe was too restrictive.
Ray your a homo!!! j/k You may have some serious problems though if you keep company with man hands!!!
Have you thought about throwing a quick release v-band clamp on your mufflers?? That way you could switch between the two depending on where you were racing in just a matter of minutes. Just a thought........
Old Mar 9, 2005 | 10:00 AM
  #2809
UT_Evo's Avatar
So, should my boost not be tapering AT ALL in any gear? And if it is and shouldn't be with what I've got, what should I do?
Old Mar 9, 2005 | 10:54 AM
  #2810
UT_Evo's Avatar
And one other question: does the fuel pump get loud and go back to being quiet sometimes? Earlier today it was pretty noisy, and now it's back to being pretty quiet... at least, I think it was the fuel pump, and hope it was that
Old Mar 9, 2005 | 11:01 AM
  #2811
jid2's Avatar
The fuel pump howls, and it does get loud and quiet... that is normal.
You may see .5 -1 psi of taper from time to time. but usually about .5 psi or so.
Old Mar 9, 2005 | 11:04 AM
  #2812
UT_Evo's Avatar
What if it's more than 1psi?
Old Mar 9, 2005 | 11:32 AM
  #2813
scott88vr6's Avatar
Your fine Jake.
Old Mar 9, 2005 | 11:33 AM
  #2814
UT_Evo's Avatar
Scott, I thought we figured out that I'm not gay, but thanks...
Old Mar 9, 2005 | 11:46 AM
  #2815
scott88vr6's Avatar
Mine drops 1-1.5 psi.
Old Mar 9, 2005 | 11:51 AM
  #2816
UT_Evo's Avatar
1st and 2nd gear drop 2-3psi, 3rd and 4th are only like 1-1.5
Old Mar 9, 2005 | 11:53 AM
  #2817
scott88vr6's Avatar
That sounds about right.
Old Mar 9, 2005 | 11:54 AM
  #2818
scott88vr6's Avatar
Whatever man
  #2819
UT_Evo's Avatar
we're so mean
Old Mar 9, 2005 | 11:59 AM
  #2820
bullfrg's Avatar
Some of you guys I am very concerned about
