Utah Evos
Old Feb 18, 2007 | 09:54 AM
  #9631
Kodiak's Avatar
I’m planning on @ least 5 events this year maybe more. I’m taking the car to Vesko in the next week or two to get some performance upgrades. As for gaming I’m waiting for Forza 2 for the 360(may 07). I got the new Microsoft wheel and now I want to get this racing cockpit
http://www.247motoring.com/shop/shop...nt=247Motoring.
Originally Posted by munoa13
No worries, are you going to back at the track this year? I love the PS3 been playing GT HD all the time thanks for the hook up!
Old Feb 18, 2007 | 10:05 AM
  #9632
MSM_S2K's Avatar
Originally Posted by MSM_S2K
See, I do have good advice, and I'd love to hear what he said... Or read, as it so works out.
--- Says Jake on his Dad's account on his Mom's computer... sigh
I'm so confused ... did I post that in my sleep or did mom?
Jcnel, good insight from Paul. I've tried a lot of different options to get rid of inside rear wheel lift on my car. I'm finally just removing the rear sway bar. I'll need a fair bit of time to get things dialed back in with adjustments to the front bar and rest of suspension.
Whether you have Vesko, Ray or someone else do the initial setup; I like and prefer the approach you're taking of learning as much as you can on your own. There is a lot of personal preference in driving style and suspension setup. Approach recommended to me by quite a few different people is:
1. Focus first on chasis tuning (sway bar adjustments, etc) to get handling characteristics you prefer
2. Then springs
3. Damper adjustments
4. Tire pressure
My initial setup was a set of custom valved double adjustable Koni 28s. Very noticeable ability to tune handling based with compression and rebound adjustments. There's some good info online and a number of books on damper setup and tuning. I've heard good things about the KW variant 3s, which are reasonable cost double adjustables. This year I made the jump to tripple adjustable Motons. I'll be using Race Technologies DL1 for data analysis to help with tunning of the tripples.
Moton has a double adjustable clubsport setup that is also excellent; though still pricier than the KWs.
Old Feb 18, 2007 | 10:09 AM
  #9633
mountainturbo's Avatar
Hey guys, just checking in. Got an 05 RS a few months ago and have been loving every minute of it! I used to auto-x an 88 turbo RX7, and I'm looking forward to taking the evo out to push it's limits a bit.
So do you guys have a local club, or do meets or anything? I'm a member of the local RX7 club, maybe we should do a joint meet sometime
Old Feb 18, 2007 | 10:24 AM
  #9634
MSM_S2K's Avatar
http://www.247motoring.com/shop/shop...t=247Motoring.
Hey Mr. Bear, with the weather like it is ... I think we should all be on track now!
Save yourself a $100 and get this one: http://www.bobearlracing.com/
I'm waiting for Forza 2 as well. I got it for x-mas.
Old Feb 18, 2007 | 11:29 AM
  #9635
UT_Evo's Avatar
I hope they pushed it back to April to add MMP to the track line-up... But maybe I"m dreaming... Bastards pushed Super Smash Brothers Brawl and Super Mario Galaxy back to December 31st. And any gamer remembers Starcraft's many year wait...
But from seeing video of Forza 2 (which, as I'm told, is on a computer and not the actual 360 graphics) and playing the GT HD demo it is going to be VERY VERY hard to get the graphics, if GT HD has realistic damage then the 360 will have Halo 3 going for it at least...
Old Feb 18, 2007 | 11:59 AM
  #9636
eficker's Avatar
Do your fronts tend to get worn on the outer 2 to 3 inches of tread on track? That's usually a pretty good sign that you're overdriving the fronts. For example, you get into a turn ... car starts to understeer a little bit and rather than easying off the steering you get on the throttle. That's what I mean by mashing it. If you've seen that kind of wear on track, then you're likely not going to do well with 710s. Even with RA1s, you'll be faster if you don't overdrive the fronts.
Whether you run RA1s or something else, remember to swap front and rears to prolong tire life. I'll finally be able to do that with my car now that I've gone to a non-staggered setup.
I actually had very even tire wear. I was told that the v710 does well even with less camber than other tires. I was running about 2.7*. I wouldn't say i was overdriving the tires, perhaps i was misleading in that comment. I don't allow the car to "push" through corners like others might. I also understand the slow in - fast out technique and like to use it.
I just think that the fronts overheated (typical on an FF) and it was hot ambient that day and they just let go.
I am excited to see your 3-way motons!
Originally Posted by evobeatsti
how much are you selling that car for one of my friends in looking for a new car... is it street drivable???
Asking $5k. I daily drove it, but street driveable is in the eye of the beholder. He would want a fixed bucket (i used a sparco fighter) to get down away from the roll cage and seat belts.
Originally Posted by UT_Evo
Over driving is the Evo's forte...
And that isn't necessarily true, in the case of Jeremy's car it had enough horsepower that the throttle was GREAT for correcting understeer and induced a perfect amount of oversteer, especially for turn 5. But the main key is indeed to avoid understeer by whatever means, not only does it ruin your tires but it either forces you to slow down (when, had you been going the proper speed you'd likely be speeding up at that point in the Evo) or it means you're horribly off line and trying to force the car to do something you shouldn't...
The Evo is a train, stay on the rails and you'll haul, but if you stray all you'll hear is grinding and slow down a whole lot. Remember too that it isn't a lite car by any means, so with the really tight corners (namely the last one on the west track) you have to slow down, a lot, I was trying it without slowing down nearly as much as I do now and Ray pointed out that Dennis was gaining on me AFTER the corner in the Exige, once I slowed down he'd gain on me like crazy going in but be left in the dust going out and I gained 15 mph at the end of the straight afterwords.
Or buy some slicks, then it does pretty much everything you tell it too
I only have had one day in the evo at the track, but it seemed that whenever i started to understeer, all i had to do was add throttle, the understeer would go away and some manageable oversteer would happen.
I am running Tein Super Racings with a higher spring rate in the rear, but other than that, off the shelf. Very happy with the way they perform, and also happy about not upgrading the rear sway.
jcnel- that is all good info. I have felt the way that the car transitions from understeer to manageable oversteer (as desc above) and love it. Whenever you are behind one at the track, you can see it happen. Very controllable and looks cool from behind too!
I like that feature, that way you dont have to run crazy static toe that will eat tires on the street. The more i find out about these cars, the more i am glad i own one.
Old Feb 18, 2007 | 12:10 PM
  #9637
eficker's Avatar
Pics of my car
Old Feb 18, 2007 | 12:16 PM
  #9638
MSM_S2K's Avatar
The list of tracks for Forza 2 is published on the MS site. Does not include MMP.
Old Feb 18, 2007 | 12:39 PM
  #9639
eficker's Avatar
Looks like it will be PS3 for me. I like the MS controllers better though.
Old Feb 18, 2007 | 07:17 PM
  #9640
evobeatsti's Avatar
alright maybe sometime in a few weeks i will get my friend to come down and check out your car fick. he is coming form a miata and wants a hard top now and your car looks really sick.
Old Feb 18, 2007 | 07:38 PM
  #9641
munoa13's Avatar
Fick the RS looks sick! I like the hood shot the best!
Old Feb 18, 2007 | 10:47 PM
  #9642
silverofs's Avatar
well since we are doing pictures here are a few of mine
http://i177.photobucket.com/albums/w...evopics005.jpg
http://i177.photobucket.com/albums/w...evopics003.jpg
http://i177.photobucket.com/albums/w...evopics002.jpg
http://i177.photobucket.com/albums/w...dJan070011.jpg
not the best pictures but oh well
Old Feb 18, 2007 | 11:54 PM
  #9643
Kodiak's Avatar
The only problem with the PS3 is sony took out force feedback and rumble. From what I have read forza 2 + the Ms wheel should be a much better feeling than just the pain controller. I have the MS Wheel its ok. I have been playing GTR2 on my PC for now. This is the Wheel I want G25 but so far as I can tell it won't work with the 360.
Old Feb 19, 2007 | 12:02 AM
  #9644
Kodiak's Avatar
Forza 2 will have downloadable content through Xbox live. New tracks and cars are going to be coming sooner than later I hope.
Old Feb 19, 2007 | 12:06 AM
  #9645
UT_Evo's Avatar
I won't be using the plain controller, don't forget that both systems have USB ports now, and I don't know about the 360 (cuz I haven't used them) but the PS3 is compatible with just about every computer device that doesn't require a seperate software install (keyboard, mouse, microphone, the list goes on). They took the rumble out to maintain power for longer periods of time (because, unlike the 360 and the Wii, it runs off of a much smaller and lighter power source than 2 double A's) But, controls asside, the realistic physics (including driving and damage) will be my main factor, course, I'll probably get both since Forza 2 is April and GT:HD is December.
And don't forget the PS3 has downloadable content and FREE online multiplayer... Which are both about half the quality of Xbox's but still...
