updated wrx... what does this mean for the ralliart
The car is pretty ugly and the majority of people and even reviews agree with this. The wrx may outperform the ralliart, but many people would think that the ralliart that can perform close or at the same level of the wrx and have looks that are more appealing than the wrx.
I think most of you are taking stock performance figures too seriously. Who keeps a factory turbo'ed car stock anymore these days? Rhetorical question.
EDIT: I guess the high price of the TC-SST might be a deterrence. I personally did not care for my warranty on the IX since Mitsu is notorious for bad warranty coverage to begin with. I don't regret my decision since I've not yet had a major issue with the car that required me to use the warranty.
A lot of people keep their car stock. Read my above comment again, would you mod a car that has a transmission that cannot be serviced or upgraded? If you want to mod, I think the Evo GSR would be a better investment (since the 5-speed is virtually bulletproof).
"(since the 5-speed is virtually bulletproof)" ya unless you don't know how to drive stick and you smoke it.
Ambustom01 is right though, I would get a GSR is you want to mod it. But then again if you were going to get a Ralliart and add 50 HP and bought a GSR instead, you would be at the same HP and have a Evo. You wouldn't need to mod it.
Adding coilovers and changing tires isn't going to void any warranty unless your dealer is an absolute scumbag in which case I suggest you go elsewhere. Each and every review has stated that the factory tires on the RA are garbage and directly responsible for poor braking, handling and slalom numbers and need to be replaced. I believe it was the Edmund's review that said "replace them the day you buy it". You can add that into your price difference argument unless you manage to sell the stockers.
I think the difference in track times that have been played up throughout this thread would be much closer with a simple tire change, and completely negligible with spring/shock or coilover replacement. Subaru had to tighten up the ride after the 08's soft ride agitated everyone, Mitsubishi is making a first attempt here and obviously it's soft from the factory.
I agree that the tires are a major issue but don't forget that the Ralliart shares the same body and suspension as the GTS thus limiting how wide you can go. According to one of the threads on here the max is a 235/40/17 tire with an 8" rim which isn't actually massive considering the weight of the car. In stock form both the Evo and the STI run 245 tires.
I'm sure if you put better tires and a better suspension setup on the WRX it would also show a marked increase in handling and would continue to stay ahead of the Ralliart. Maybe it's just me but I find it crazy to buy a car knowing you'll have to mod it to make it acceptable.
Coilovers would definitely void the entire suspension warranty and they could extend that to other areas as well (like the body since the car sits lower). Coilovers are a major modification and unfortunately people tend to set them up wrong or buy them when they don't actually need them (ie. they slap them on and don't actually use the adjustability). R-Comp tires could void the warranty as well since R-Comp tires can corner so hard that you can actually deprive the engine of oil in longer turns.
Like a body kit, rims, grill?
Considering most reviews don't even notice the looks, I doubt people would really find it that bad. You'll notice bad acceleration and lackluster handling far more than what the car looks like when you're walking up to it.
). Robi managed 17x8.5 +35 with 245/40/17 with some rolling.
Manufacturers give us a product that we, as enthusiasts, like to modify to our own tastes. Why do Evo and STi owners buy those cars only to mod them? Arent they acceptable from the factory?
I'm hoping with some coilovers the RA will fit some 245s or 255s.
Could you possibly explain why you feel the WRX will "continue to stay ahead of the RA" if they both have similiar suspension/tire/wheel upgrades?
Manufacturers do not make cars to be modded, you're nuts if you think that. There is a reason why manufacturers do not warranty modded cars.
As said, the widest people have gone without rolling are 235s, that comes directly from a performance shop. From what I remember the issue is clearance with the struts.
. I'm curious, since you liked the Ralliart so much and had defended all the way. Why didn't you buy it? Why did you buy the GTS instead?
