updated wrx... what does this mean for the ralliart
Actually the R&T comparison goes in line with all the other Ralliart reviews, hell it actually posts the fastest 0-60 times of several reviews (the worst being a 7.X).
In what way is the Ralliart closer to the WRX? Did they test the new Ralliart and the new WRX in the Lightning Lap shootout? The WRX is faster to 60, faster in the 1/4 mile, shows better handling numbers and shows close to a 2 second difference in a sub-1 minute autocross course. What do you think would happen on a larger course with more straight aways (something they complained about with the Ralliart), more high speed corners and more quick braking zones? I promise you it'll be a far larger difference than the 5 seconds between the Evo and the STI considering an autocross course should be reasonably good for the Ralliart (speeds are lower and the car can stay in it's peak range better).
Compare the performance numbers of the STI to that of the Evo, they are nearly identical. The 0-60 times are the same, the 1/4 times are the same and the handling numbers are so high for both that you couldn't realistically test them on the street.
You can claim fanboyism all you like but the data suggests otherwise.
Ha Ha Ha Ha. How did you round 5.7 seconds down to 5 seconds. You are a fanboy face it. Face it your arguments for the STI don't hold water when you are denouncing the Ralliart for the same thing.
Also I have yet to see a comparison where the STI as fast than the EVO GSR in a straight line. According to Road and Track the EVO X GSR pulls away siginificantly over 100 mph;
http://www.roadandtrack.com/assets/d...Vwrx_chart.pdf
You are making this way too easy for me lol.
Why am I a fanboy, because I can actually work out that a 2 second difference on a 45 second course is a larger difference than a 5 second difference on a 3 minute road course? Granted I didn't graduate with a degree in math but I'm pretty sure that 2/45s is larger than 5/180.
Both the STI and the Evo are capable of 5ish 0-60 times (you are free to check the times listed in R&T). I agree that the Evo will pull at 100 MPH speeds because the turbo is larger.
I love how you're accusing me of being a fanboy yet the same arguments apply to you, it's fantastic. Moreover, when did I diss the Evo and how is the Evo applicable to the Ralliart? The Evo is a competitor to the STI, that's obvious to anyone.
Road and track clocked the EVO X at 0-60 in 4.9 seconds and the STI at 5.0 seconds. Also Car & driver clocked the GSX at 0-60 in 4.6 seconds and STI at 5.0 seconds. Read the article where your beloved Subaru finishes last again and load the test sheets;
http://www.caranddriver.com/reviews/...omparison_test
That 0.4 second 0-60 mph difference between the EXO X GSR and STI is the same as the 0.4 second 0-60 mph difference between the 09 WRX and in your words the slow Ralliart. Sorry I'm not going to argue about your hypothetical theories of how the Ralliart would fare against the WRX on a different track. I'll stick to published numbers to keep contradicting you.
The Evo uses a larger turbo than the STI, that is a fact. If you've ever seen the two compared next to each other it's startling really. At 100 MPH speeds, I don't think weight is as big an issue as say when launching. At those speeds the larger turbo makes a big difference since it's not running out of steam.
The engine isn't what makes the Evo faster since the engine outputs are the same. The Evo has nearly telopathic computers which make it's handling just plain stupid really. You'll notice that these computers are not present in the Ralliart.
I have the issue with that comparison and yes the STI finishes last. Again, so what? The performance numbers are almost the same and in other comparisons the STI and Evos finish so closely (ie. the times are less than second apart) that you would be hard pressed to notice a difference. This tells you that the two cars are very comparable and what you might be seeing is differences in driver capabilities. In the real world, the Evo and STI are essentially different brothers from different mothers.
You're taking the times from the C&D test yet in the R&T test the difference is 0.1 of a second. In no review has the Ralliart clocked a better time than a 5.4 0-60. That 4.6 0-60 for the Evo is also somewhat perplexing since it's faster than pretty much any time out there. I'm not going to get dragged into another Evo vs. STI pissing contest but based on pretty much every review, the WRX is faster than the Ralliart, end of story.
2. That doesn't make it superior, a traditional auto eliminates the possibility of a miss-shift and can indeed shift faster than a human (in some cases) but they're not better than a human under all conditions.
3. The people who produce the FQ series are not just a tuner shop, they're HKS who work in conjunction with Mitsubishi (much like STI or Mugen). http://www.mitsubishi-cars.co.uk/evo...x/overview.asp. It's somewhat damning that FQ decided not to use the TC-SST. You can argue it's a profit based decision but that doesn't make sense, they would logically charge more for a TC-SST containing car thus their profit would be identical.
3. Making no sense if they would charge logically more for a SST?? Sorry, but that's such a naive thinking. Not to mention a poor business proposal for anyone. What about the cost of extra research? The cost of extra trial & error? The cost of everything else that they are unfamiliar with?
So tell me, if you are a company and there's a new product. Would you 1) rather spend time to come out with something that's already been proven and ensure to sell, or 2) spend time on something that's new and will take much more effort to find out because of its newish factor???
If you choose 1. i applauded that you are still part of this real world. If you pick 2. i applauded that you still have a dream.
2. Some autos aren't that bad, modern torque-converter transmissions can shift reasonably fast. As another example, look at a CVT transmission as in the GTS. It can "shift" (albeit falsely) but it's not superior either. Logically no shifts should be the best but that's simply not the case. At the moment there simply isn't an ECU that can match the human brain in all conditions. Some reviews have noted this where the transmission is confused as to what gear it should be in.
3. I don't see the issue. If they used the MR as their base, their base cost would increase and they would pass this on to the consumer. The amount of R&D is irrelevant of the transmission, they wouldn't need to adjust the maps or anything like that, just mod the engine. You did raise the main point, unfamiliarity. You may be comfortable putting all your eggs in the basket of an unproven technology, but I'm not.
Something else to consider, if they went with the TC-SST, they could sell more units theoretically since it wouldn't limit the car to people who can drive stick.
I understand and saw the video amby was referring to. That error was due to the driver and the computer. Anyone that has driven an MR for more than 30 minutes knows that he should have paddle shifted into first in that U-turn. The driver was unfamiliar with how the MR tranny works and just left it in full auto mode, the computer was shocked by him trying a hand brake U-turn and did not go into the right gear for the situation. This is not an everyday driving or track situation, it was more of a rally setup if you ask me. So yes the programming may fail, but in the end an experienced driver can over come that by going into manual mode.
How is what I said wrong? Some reviews have noted that the transmission seems confused at times (mainly at the track) and shifts needlessly. I would love to drive an MR but I'm not willing to put a 5000$ deposit down on a car that I have no intention to buy. Moreover, I would hate to be that douchebag that bags on someone's potential car.
What's the point in having the TC-SST if you're not going to actually use the modes (ie. Sport, Super Sport)? Why not save the thousands and buy a traditional manual? To clarify this point, if you're just running the car in manual mode, you still need to provide an input to get the car to shift. I fail to see how pulling a paddle is substantially different than pushing a shift lever into another gear. Some people have argued that a traditional manual is "distracting" but the same could be said of the TC-SST in manual mode.
C
It's down a lot of ponies but it's got a good amount of torque which I suspect is due to a smaller turbo (which also explains it's lack of umph in the higher speeds). It's good to here you found a car you like. Something people need to keep in mind is it's up to them to decide which car is right for them, the magazines just give them the numbers.
