JDM Evo IX MAP sensor group buy
Old May 10, 2007 | 08:49 AM
  #271
TouringBubble's Avatar
/cheer
Old May 10, 2007 | 09:12 AM
  #272
chrisw's Avatar
sent a pm
Old May 10, 2007 | 09:16 AM
  #273
Blue Evo 8's Avatar
i'm running an AEM 5 bar map sensor, the shop cut off the stock plug and soldered on athe one for the AEM map sensor. Now I need to pass emissions and dont have a plug lyning around to plug into the stock map sensor.... can someone help me? or point me in the right direction?
I'm missing the green plug that goes into the map sensor
Old May 10, 2007 | 01:41 PM
  #274
andenbre's Avatar
you know what may have happened? I think I may have inadvertently flashed in a map that doesn't have the jdm map sensor coding in. ps I am also running no o2 with the rear o2 disabled and a 10 ohm resistor in the heater circuit
Old May 10, 2007 | 01:54 PM
  #275
mrfred's Avatar
Originally Posted by fixem2
Installed my JDM sensor today and the car would not stay started. It would start but immediatly stall. Put the old sensor in and all was good. ANy thoughts? Car is an EVO 8 with 96940011 Rom.
I found all the tables for your ROM. :-) I'll be writing instructions this evening.
Old May 10, 2007 | 01:58 PM
  #276
mrfred's Avatar
Originally Posted by chmodlf
I don' t have the sensor in yet but I have a Random Tech HFC and have never had a CEL. Wierd.
Where did you purchase your Random Tech?
I got mine from UltraRev. They had a good price. Its definitely a genuine Random Tech HFC. It took about three months before the first CEL appeared. I have read other threads where people with the Random Tech HFC also get a CEL. I installed a mechanical fix (spark-plug anti-foul extender) a few weeks ago. It seems to be helping.
Old May 10, 2007 | 01:59 PM
  #277
mrfred's Avatar
Going to the PO now to mail about 12 sensors. :-)
Old May 10, 2007 | 02:01 PM
  #278
kreionic's Avatar
Sweet cant wait for mine/ Hopefully it will be here by saturday
Old May 10, 2007 | 02:54 PM
  #279
andenbre's Avatar
OK I poured over my tables and found 1 entry wrong in my MAP Check table, @ the 448 position I had 50 in place of 60 . oops If any thing returns I will let ya know.
Old May 11, 2007 | 07:18 PM
  #280
Max Power's Avatar
Awesome, thanks for all the work mrfred. Wish I had my car here to test it out
Old May 12, 2007 | 04:59 AM
  #281
phenem's Avatar
My car is getting the p0401 code as well and idle is really bad! I don't know if this is the problem but I didn't change anything since. I am going to check it out right now.....
~Zach
Old May 12, 2007 | 08:08 PM
  #282
mrfred's Avatar
Updated instructions for the '05 Evo 8 96940011 ROM are here:
https://www.evolutionm.net/forums/sh...d.php?t=259595
Old May 13, 2007 | 04:24 AM
  #283
chmodlf's Avatar
Sweet. Thanks mrfred.
How close is the 96940011 ROM to the earlier 96420008 ROM? Would it be difficult to find the addresses for the 96420008? I would try but I am weak in the area of dissassembly...
BTW- received the sensor. Thanks for the fast shippping!
Old May 13, 2007 | 06:56 AM
  #284
mrfred's Avatar
Wow. I mailed it on Thursday. That was fast. Send your ROM to either email address I gave you, and I'll check it out.
Old May 13, 2007 | 07:17 AM
  #285
phenem's Avatar
You might want to change you "Other EVO 8 ROM's" to add the tables and change the scaling values to log boost correctly. I was reading it and it was a little missleading to me as plugging it in and going did work but threw a code, but it did not read the correct boost settings until you gave me the tables to update the scaling values. Then it seemed to work. Do you think you should put that in there?
~Zach
