PATCH: CEL Flash on Loaded Knock
Old Aug 31, 2007 | 09:21 AM
  #181
fixem2's Avatar
Thanks for the clarification and the awesome work!!
Old Sep 2, 2007 | 06:42 PM
  #182
MR Turco's Avatar
Does anyone know where I can get ECUflash v1.29a? I looked on openecu.org and they do not have archival downloads.
Thanks,
Mike
Old Sep 3, 2007 | 05:26 PM
  #183
MR Turco's Avatar
Thanks,
Mike
Bump, anyone?
Old Sep 3, 2007 | 07:36 PM
  #184
Vigman's Avatar
I have a 1.30 version if interrested!
Old Sep 3, 2007 | 07:44 PM
  #185
tephra's Avatar
aside from being offtopic once we get this sorted we can get the mods to delete these posts
what do you need 1.29 for?
Old Sep 3, 2007 | 08:03 PM
  #186
andenbre's Avatar
I have 1.28 and 1.30 but not 1.29a. let me know if you want either.
so if you open the rom in 1.31 it scrambles the knock flash info?
Old Sep 3, 2007 | 08:16 PM
  #187
andenbre's Avatar
http://www.megaupload.com/?d=VBFURU6Z
here is 1.29a
Old Sep 3, 2007 | 10:14 PM
  #188
Jeff_Jeske's Avatar
Back on topic.....
When I use launch control I always get knock. If there is a way to correct this please tell me how. If not what configuration do you put into the knock controls to avoid this are of WOT from kicking up a CEL?
Old Sep 3, 2007 | 10:16 PM
  #189
tephra's Avatar
what load are you seeing ?
Old Sep 3, 2007 | 10:55 PM
  #190
Whoop_ass's Avatar
ye just increase the load value for knock CEL
i dont think using the 2 step you would go over 160 load.
and it is not true knock, when you hit limiter it will show up as knock as well.
where have you set the knock to flash at 2 counts????
Old Sep 4, 2007 | 04:55 AM
  #191
C6C6CH3vo's Avatar
How can you confirm this is not true knock?
Might be knock occurring from the leaness when hitting limiter. At the rev limit the car just does a series of brief fuel cuts which is known to cause knock
Old Sep 4, 2007 | 04:56 AM
  #192
recompile's Avatar
Originally Posted by Jeff_Jeske
Back on topic.....
Try slowly ramping up to the limiter... if you slam the throttle it usually knocks, but if you slow ramp, you should be fine
Old Sep 4, 2007 | 05:21 AM
  #193
Mellon Racing's Avatar
usually the knock will go away after a few seconds with a 2-step
Old Sep 4, 2007 | 05:34 AM
  #194
MR Turco's Avatar
Roommate(crazymikie) couldn't get it to work in 1.31 or 1.30 so I was trying to find 1.29a
Old Sep 4, 2007 | 05:59 PM
  #195
mchuang's Avatar
I tried to test this patch for my rom, First I changed the endian to little and i got the correct millisec 3431ms..so I then changed it to 5000ms and changed the immobilzer code to mine by typing 0xffff (example) and I flashed my rom using 1.30 and the car started and died as if the immobilizer was wrong. But I looked at the address and it shows correct. So then I reflashed my backup rom and it started just fine. Any suggestions?
