PATCH: CEL Flash on Loaded Knock
Old Aug 12, 2007 | 10:11 AM
  #91
Pd1's Avatar
Pd1
Originally Posted by sleet
Which file is the definition file in the ECUflash directory?
The one in the Evo directory that's named with your ROM ID followed by ".xml".
Old Aug 12, 2007 | 10:13 AM
  #92
Ph3n1x's Avatar
Go to X:\program files\ecuflash\definition\mitsubishi\evo
Backup the entire folder before you start replacing anything.
Open the .Xml file you downloaded here in notepad. then copy the code to the Definition file.
Messege me on AIM if you need any more help.
Old Aug 12, 2007 | 01:27 PM
  #93
dudical26's Avatar
88590015 works for me.
Old Aug 12, 2007 | 03:55 PM
  #94
evo_rc's Avatar
Originally Posted by burnmacs
94170015
I second that! thanks
Old Aug 12, 2007 | 07:01 PM
  #95
mercedevo's Avatar
Originally Posted by MalibuJack
For as much as I love this mod because its similar to the UTEC feature.. I always had a problem even seeing the CEL light flashing at any time besides when it was really dark out. Just keep that in mind if you tune during the daylight hours.
Do what I did. Add a bright led next to the gauge pod pillar. One wire to ignition + and one to pin number 36 on the ecu. Works great for me.
Old Aug 12, 2007 | 09:18 PM
  #96
tephra's Avatar
Updated first post;
96260007 and 88840016 now up...
how different is 94170015 to 94170014?
Old Aug 12, 2007 | 09:46 PM
  #97
ziad's Avatar
thankx dave, dl now and will check the 96260007 today :-)
Old Aug 13, 2007 | 04:42 AM
  #98
phenem's Avatar
Thats a good question, I think they are VERY similar.
Check this out: https://www.evolutionm.net/forums/sh...d.php?t=259595
mrfred might be able to help you as he did this mod and looked at the 94170014/15 ROM closer than me.
~Zach
Old Aug 13, 2007 | 05:41 AM
  #99
andrej's Avatar
Question
Hi Dave,
How's the Aussie patch coming along 88580014? Patiently waiting
Andrej
Old Aug 13, 2007 | 03:56 PM
  #100
msukach's Avatar
Weird Values After Patching
I updated my 88590015.xml with patch code but I'm getting weird values...the Cel Flash on Knock dialgue box on the is my current flash, the one on the right from the file provided from this thread. Not sure why ECUFlash is reading the patch rom correctly and not my current flash...any help?
I'm assuming I can just change the values using Set Value e.g., 0x1 for "Flash CEL on Knock?" Right?
Attachment 110166
Old Aug 13, 2007 | 04:16 PM
  #101
Pd1's Avatar
Pd1
Attachment 110166
You'll have to load all your settings (immobilizer code, timing, fuel, etc) into the patched rom and flash it to your car. You will not be able to use your existing ROM if you want it to flash your CEL upon encountering knock activity. Only the patched ROM, or ROM based on the patched ROM will do this.
Old Aug 13, 2007 | 05:13 PM
  #102
msukach's Avatar
Ok...I'll try that...just curious, if I'm overwriting the patched ROM with my current flash, than how do I know I'm not altering the "patch" on the patch ROM? Comparing both ROMs in a Hex editor as I start to copy my settings into the patch ROM, they both, of course, begin to look the same. So where's the "patch?"
All the setting are now correct...flash to the ECU went fine...I'll test in the morning...so, more to follow.
Old Aug 13, 2007 | 05:14 PM
  #103
ziad's Avatar
96260007 works like a charm :-)
thankx a million.
Old Aug 13, 2007 | 06:21 PM
  #104
Ph3n1x's Avatar
Due to popular request from a few members... here is what you need to do for the less computer inclined
First you need to identify what defintion your flash is. You can do this by opening it in ECUFLASH and under Rom info tree and looking at the Internal ID.
Then depending on which you have u need to download the one from the thread. For instance mine was 96940011.
Then you need to open the C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
and look for the one that you have. Then open it in notepad.
Open the definition you downloaded from the thread and copy everything there between the first "<" and the last "/>"
Then paste it in the the definition file you found in the folder just before "</rom>" and after "</table>"
Then open the .bin file you downloaded and copy all the information from your flash on your ECU to each map in the new .bin. ie. timing high/low. octane high/low and of course the immbolizer.
Flash the ECU and it should work.
Old Aug 14, 2007 | 03:29 AM
  #105
T1 EVO's Avatar
Up
