PATCH: NLTS + Valet + KnockCEL
Old Sep 27, 2007 | 06:56 PM
  #211
tephra's Avatar
yep its a minor bug - but I want to get it fixed...
I also need to repackage 96940011 as its not stock and xml's are funky
Old Sep 27, 2007 | 07:16 PM
  #212
bnice01's Avatar
I got one man, check your email in 5min. Its stock
Old Sep 27, 2007 | 07:22 PM
  #213
bnice01's Avatar
email sent
but while tuning a 2 cars today I have tested all three features on rom:
96940011
94170008
94170014
all work great
Old Sep 27, 2007 | 07:40 PM
  #214
Jack_of_Trades's Avatar
Originally Posted by evopower1021
i have rom 94170008 and i just fully tested the nlts.
i have a 35r running 33psi and when i shifted it held 20psi and felt awesome. definately cut the lag time down by a lot
awesome job tephra
at redline I'm at 21psi and when i would shift (at a moderate shifting speed) it would hold around 11-12psi. I bet if I shifted like i do at the track I'd be in the 12-13psi area at least. Gotta love this!
Donating my share to you now Dave. Sent payment to donations@globalshare.net via paypal dot com, everyone else give this guy something at least!
Sooo worth donating some cash for!
Old Sep 27, 2007 | 07:41 PM
  #215
tephra's Avatar
UPDATE
Hi Guys,
I have repackaged 96940011 with a confirmed STOCK ROM - it also has the fix for the CELKnock Flashing bug. There is a new download link just in-case you are behind a proxy
Once someone confirms the fix for the Flashing CELKnock bug I will upload new ROMS for the other ID's!!
Cheers
Dave
Old Sep 27, 2007 | 07:42 PM
  #216
evo 8 ya's Avatar
Originally Posted by bnice01
email sent
96940011
94170008
94170014
all work great
you got the 96940011 to work?
Old Sep 27, 2007 | 07:49 PM
  #217
evo 8 ya's Avatar
Originally Posted by tephra
UPDATE
Hi Guys,
Cheers
Dave
so do we have to just copy the new xml in the 96940011 rom? or copy the xml to the 96940011 rom and all our fuel, timing, ect.....settings to the patch .bin file provided aswell? or is it the same patch .bin file as the ones before it? (like from yesterday)
Old Sep 27, 2007 | 07:50 PM
  #218
tephra's Avatar
I don't think the XML has changed - but just in-case delete any old XML and use the new one.
You will also need to use the new BIN and copy all your settings over again - sorry I know its a pain but such is life
Old Sep 27, 2007 | 07:53 PM
  #219
Mojo Rising's Avatar
Originally Posted by Cyloc
What Xml editor are you guys using? I have 3 on my computer and none of them will open the file.
Someone should do a set by step for the guy (like me) that are just learning ecuflash.
I use "XML Marker 1.1". It works great for this.
http://www.download.com/XML-Marker/3...ml?tag=lst-0-1
Old Sep 27, 2007 | 07:54 PM
  #220
evo 8 ya's Avatar
alright cool. don't worry man, small price to pay for this awesome feature. Thanks again
Old Sep 27, 2007 | 08:09 PM
  #221
Pr3z's Avatar
I got 96940011 to work on the old rom he had.
Anyway the NLTS feature doesn't quite make sense to me. From what I read it's using the top switch which when your NLTSing you want the car to to be out of that mode the second your starting to come back up from the shift. It really needs to read from the switch at the bottom of the clutch stroke.
Anyway to make that happen? Everything else works as it should though.
Old Sep 27, 2007 | 08:15 PM
  #222
accident's Avatar
I don't really care about the valet mode, can I just delete those lines out of the xml file? if I leave it in does it have the option to be turned off like the knockcel?
ed
Old Sep 27, 2007 | 08:44 PM
  #223
recompile's Avatar
ed
Leave the XML as is, just go into Tephra Mods and set Valet to 0
Old Sep 27, 2007 | 09:23 PM
  #224
fixem2's Avatar
Anyone going to the track this weekend to test this patch out for comparison results?
Old Sep 27, 2007 | 09:36 PM
  #225
Going on the 13th, if no one tests it by then...I sure will.
