Let's see your fully tuned timing maps
Old May 12, 2013 | 07:11 PM
  #2236
BEKevo's Avatar
@ AndyCT9W. Which ROM are you using?
Any knock? Also what peak load are you hitting @ what RPM? Tapering to what load / RPM? This will tell us a little more about your tune..
Edit: Just saw it. ROM # 88770005. Is this ROM unique to the Evo IX wagon? I am unfamiliar with this ROM/ have never seen it. Usually, there is 3 high octane and 1 low in the Evo IX ROM's. I think, please correct me if i am wrong.
Have you ever thought of flashing a more common ROM #, possibly even one of the Tephra ROM's?
Old May 12, 2013 | 07:27 PM
  #2237
detroit pistins's Avatar
AndyCT9W,
I think someone more experience with how much timming can be run on the 4g63 can comment on the table's input, but there are two things that jump out at me ...the load/rpm axis of the surface, why is there "0" load or an 11000 clip? I think you could clip the rpm to ur rev limiter maybe and start the load at 10 to allow you for more tunning room in some areas that maybe needed.
The map could use some "massaging" as well... for example the spark jump at low rpm from 15 to 17 then back 15 between 60-80 load.
Old May 12, 2013 | 07:34 PM
  #2238
domyz's Avatar
Originally Posted by detroit pistins
+1 on the article..lol!
I'm also one of many who once searched for that guide without finding it a few years ago.
Old May 12, 2013 | 07:44 PM
  #2239
211Ratsbud's Avatar
That spark jump is there for a reason.
It's associated with anti stall so if the motor starts to lose vac at low rpm the increasing timing helps bring it back.
Old May 12, 2013 | 08:01 PM
  #2240
domyz's Avatar
Yes many of us use this in our timing maps. It's an idle catch up. It's also part of the stock timing map.
Old May 12, 2013 | 08:26 PM
  #2241
learned something new
thx
Old May 12, 2013 | 08:51 PM
  #2242
PCYang's Avatar
For the boost vs timing question, I've been down booth roads back and forth. If you can manage the heat and and remove intake restrictions, boost makes more power.
My computer crashed and I lost the pics. I'll have to put another one together. Let me compile my thoughts and whatever notes I can find.
Old May 12, 2013 | 10:04 PM
  #2243
Boosted Tuning's Avatar
nevermind
Old May 13, 2013 | 02:49 AM
  #2244
foxbat's Avatar
Good answer
Intake upgrade = convert to sd & remove maf housing
What size intake have you used?
Heat management: a larger intercooler would increase efficiency, some heat wraps all over... what else?
I'm looking forward to that guide too
Old May 13, 2013 | 02:55 AM
  #2245
foxbat's Avatar
[QUOTE=AndyCT9W;10803704]I'm after a bit of feedback on my 98RON (93 equiv) map. Intake, exhaust, fmic, stock turbo @ 23psi. How does this look? (Not tuned by me).
This is actually the STOCK table from the JDM GT rom! This was not tuned at all, it's 100% factory table.
Old May 13, 2013 | 02:02 PM
  #2246
maximusnz's Avatar
I also have a random question that I can't find any info on, why do I have 3 high octane and 3 low octane maps in my rom and definition?
Hey bro,
I'm from NZ as well, as far as I know in regards to MIVEC turbo engines, they can run more timing than Evo 8 and below, if you're boosting 23psi I'd assume you would be hitting over 280-300 load mark? Well I do anyway on my Evo 5 with evo 7 ecu.
Do some 3rd gear logs and upload them to this thread
Old May 13, 2013 | 05:25 PM
  #2247
domyz's Avatar
Originally Posted by maximusnz
Hey bro,
In fact VIII usually takes more timing than IX. I think it's related to the IX having more VE up top (agressive cams+ mivec).
Old May 13, 2013 | 11:20 PM
  #2248
AndyCT9W's Avatar
-Knock - 1-3 occasional counts.
-I haven't got load readings but I hit 21 psi @ 3.5k rpm, which creeps up to 22-23 psi @6.5/7k rpm and fuel cuts ( I will be sorting that out soon, if you know how to using ECU boost control flick me a PM).
-88770005 is unique to the wagon AFAIK, I've seen the option of flashing alternative ROMs (one of the options I explored when I was having trouble finding a good definition) but I haven't had the time to look much further into it personally. It is something I am interested in and will investigate when I can devote time to it.
Thanks for the feedback, I will look into that.
That is cool, really good to know.
Old May 13, 2013 | 11:29 PM
  #2249
AndyCT9W's Avatar
Well...****... I just compared them and you are right. So is it fair to assume there is room for improvement?
Hey bro,
Hey man, there are a fair few kiwis on here, I'm from Hamilton. My evo is on axle stands and missing a rear diff currently so I can't get a fresh log. I have one I did a while ago but I am having trouble uploading it (won't accept format), suggestions?
Old May 16, 2013 | 10:53 AM
  #2250
aggieEVO's Avatar
Hey Guys,
Here's my first map. It's FAR from fully tuned. I just spent some time scaling it to suit my car for right now. There were some goofy little sections where timing went up and down. I smoothed things out the best I could. I'm hoping to do some logging this weekend and actually make a few changes. Let me know if I did anything stupid.
Again, this is a stock Tephra V7 Evo 8 map scaled, interpolated, and smoothed out.
