IX Engine idle noise (belt?) (video)
Old Jun 26, 2012 | 08:29 AM
  #661
eric06ix's Avatar
Stupid question time. Instead of buying the new bracket, can you remove the extra material yourself? It's hard to see in the picture if there is extra material around the bolt holes to make up for removing it in other places.
Old Jul 19, 2012 | 04:33 AM
  #662
MrJuls's Avatar
I hear this noise every morning,the bird chirping one and have just accepted to live with it.
Old Jul 22, 2012 | 01:15 PM
  #663
kaj's Avatar
kaj
does anyone have updated info? most of these links seem to be dead.
Old Jul 22, 2012 | 01:17 PM
  #664
RoMeIX's Avatar
Mine has been doing this for years now. Aside from there being a noise, it really doesn't seem to be a serious issue. I just ignore it now, I'm to the point I don't hear it anymore unless I'm listening for it specifically.
Old Jul 22, 2012 | 05:41 PM
  #665
JaYr_EvO9's Avatar
Old Jul 29, 2012 | 12:05 AM
  #666
NZevolution5's Avatar
I've got a 98 evo 5 which I've owned for about 3 months now and seem to be experiencing the same issue and also a noise by the manifold/injectors, http://www.youtube.com/watch?NR=1&fe...&v=WCFSLVRCFVs have also heard changing the timing belt for a genuine mitsubishi one can stop the noise aswell if your belt isn't genuine
Old Aug 12, 2012 | 08:38 PM
  #667
headlock's Avatar
Also a victim of the noise here. doesn't really bother me that much, but i'm thinking of selling the car soon maybe - and i'd rather it not make a disconcerting noise when you start it up in the morning.
can you just replace the bracket? i've had my timing belt done not that long ago (to fix this noise, but it didn't :/). Warranty is thing of the past so i dont really want to do the whole lot again
Old Aug 15, 2012 | 07:12 PM
  #668
Blue91lx's Avatar
Was at 666 posts. Had to bump.
Old Aug 16, 2012 | 12:12 AM
  #669
Keith437's Avatar
hrm...i have a sound like that but, mines sound like metal on metal, like a RING
overflowing engine in oil is REALLY bad. make sure your not past the full mark
Old Oct 25, 2012 | 05:52 AM
  #670
bk.adams's Avatar
DON'T IGNORE this sound !!! I have an 06 MR that I'm working on for the second time now with this sound. The owner got it used and it has been making this sound for years too.
Well I took off the cam gear cover and guess what? Her blue Gates belt was shredding itself on the inside !!! Side where crank sensor blade is. It was nearly torn in two in a few spots !!! Good thing it was the reinforced belt !!! You can see her belt jumping between the cam gears it was so bad !!!
Anywho. we ordered the revised parts in this thread and looking at the pulley bracket from the SIDE you can see it has been changed. The idler pulley position is changed and several other places have material removed.
I'm replacing that bracket, the tensioner and the crank sensor blade today/tomorrow will let you know the outcome.
Part Number MR984375 Adjuster, Timing Belt Tension Qty 1
Part Number MD369999 Pulley, Timing Belt Tension Qty 1
Part Number 1091A133 Bracket Cylinder Block Qty 1 *****Updated New Part from Mitsu that supposedly fixes the noise problem. Original bracket was machined incorrectly by supplier to Mitsu*****
and this is the crank blade I'm using: MD190865
DON'T IGNORE THAT SOUND!!! I thought I took pix...can't seem to find them now though.
B
ps: belts are supposed to be DRY !!! NEVER put any dressing on a belt. That only MASKS the problem. Like waxing a faded car. The paint
still is bad. You just don't see it for a few months.
Old Nov 6, 2012 | 02:54 PM
  #671
sil80evo's Avatar
^^^^ thats good information. And definitely true.
Old Nov 9, 2012 | 01:59 AM
  #672
MrJuls's Avatar
I still have this chirping sound,and I'm going to try some "belt conditioner" and spray it on the belt and see If it helps.
Old Nov 25, 2012 | 07:20 PM
  #673
headlock's Avatar
replaced the bracket with my timing belt, bearings, water pump etc. Noise gone and hasn't come back
Old Nov 25, 2012 | 08:40 PM
  #674
slc_evo69's Avatar
For reassurance, can anyone confirm that this is the noise? First winter owning the car, and since it started getting cold, it makes this sound on a cold start.
http://http://www.youtube.com/watch?...ature=youtu.be
Thanks guys!
Old Nov 27, 2012 | 12:51 AM
  #675
CRONZ305's Avatar
Mine makes the noise from the serp belt. Worse when hot. If I poor water on the serp belt it stop instantly. Started doing this after my 60k.. Any ideas?
