Ams Evo Cam Test
Old Oct 12, 2008 | 02:07 PM
  #511
Migsubishi's Avatar
Originally Posted by mike 99gsx
I would talk with FP directly about your goals and setup. One option is to run the FP4R intake and FP5R exhaust which will help the spool a bit. I'm guessing that they'll tell you to run the FP5R though if you're on the 2.3l. FP also has other grinds that were developed for the stroker a few years ago. Check their website for details.
I here ya, yea I used to run their 3x cams but the head that was used was destroyed and I know have Bee hive springs. Those springs will not work well with their x series cams per FP's own words. I had a set of Bf 272's I wanted to run and could have if degreed but I didn't know they where mystery cams. I also had no idea that they would come w/o a cam card for timing events info, if told this upon purchase I would have not purchased them. I just lost my last engine to pistons meeting valves because the cams where installed straight up. Thats all Buschur kept telling me to do again and I just spent 8k on this new engine so that was a negative. I sent them back with a 15% restocking fee and plan on ordering a new set tomorrow or sometime this week.
From the reading I have been doing through the search button it seems that the Kelfords or Juns are the way to go for what I want. I just want to order the best one out of the two.
Old Oct 12, 2008 | 04:20 PM
  #512
Ted B's Avatar
One thing that I should note is that any engine with reworked head that employs larger diameter valves and aftermarket pistons should be subjected to a valve clearance test. When I say valve clearance, I mean actually putty the pistons and see to it that there is at least 0.060" on the intake and 0.080 on the exh. Aluminum rod motors should see even more. I had to do this with my motor, and without that, I would have met the same fate. I can only imagine that many others are within a gnat's a$$ of destruction and don't know it.
As for your cam selection, I would keep the duration reasonable, which should maintain your midrange torque and not cost you any power up top (i.e. through 8k rpm or so) with your 2.3. The JUNs are a fairly long duration cam.
Old Oct 12, 2008 | 07:04 PM
  #513
94AWDcoupe's Avatar
Cams are setup specific. Although the this AMS test is extremely valuable info it is on a 35r 2.0 on relatively small boost. Start adding stroke ,high boost, and head flow and you really need to do your own cam test to find what works best for your setup.
Old Oct 13, 2008 | 05:59 AM
  #514
vagelisix's Avatar
Hey guys have anyone nows anything about the BC 288-288 for the evo-9??
Old Oct 13, 2008 | 06:07 AM
  #515
evane's Avatar
i think i'll be getting the kelford 272's when the time comes
Old Oct 13, 2008 | 07:11 AM
  #516
Migsubishi's Avatar
From what I have been reading that sounds like an exellent choice
Old Oct 13, 2008 | 10:13 AM
  #517
supeazn's Avatar
definitely have to subscribe to this. Good work !!
Old Dec 9, 2008 | 06:52 AM
  #518
condi's Avatar
Nice work, cause we here in iceland don't have a dyno it's a nice thing to see . My hks272 cams work great btw
Old Dec 9, 2008 | 08:17 AM
  #519
High_PSI's Avatar
Probably one of the Best threads going on in a while, alwasy from AMS.
Old Dec 9, 2008 | 10:15 AM
  #520
boostedtres's Avatar
awesome test. obviously a lot of variable to cover and praise to AMS for doing such an in depth test. awesome info. thanks guys!
Old Dec 9, 2008 | 05:30 PM
  #521
Levar's Avatar
Veteran: Army
I haven't visited this thread in quite some time. So to give everyone an update, I presently have the APS TBE, MBC, FP, Injen CAI, Injen LICP, and GSC S1. My intentions once I return from Iraq (fourth trip) is to buy the BR BMIC, O2 dump, and the BBK Full turbo (running E85) along with the necessary parts. In going through ALL of the posts the Kelfords and GSC S2s have caught my attention. My question is whether or not they will make an ultimate difference when at the end of the day my goad is to have a spirited 450whp? I'm thinking that they won't considering the larger FMIC, turbo, and E85 but it doesn't hurt to get other opinions.
Old Dec 10, 2008 | 06:03 AM
  #522
Oettinger's Avatar
Where is the best cams for TD05 Magnesium (Turbo IX RS)?? And for FPGreen?
I need more power un down, non in up rpms, spool same stock.
Old Dec 14, 2008 | 08:08 AM
  #523
Oettinger's Avatar
Up!
Old Dec 14, 2008 | 08:40 AM
  #524
Ph3n1x's Avatar
Stock Cams then.
Old Dec 14, 2008 | 11:06 AM
  #525
High_PSI's Avatar
GSC S1 cams Evo IX, I have them and they work FINE. No loss in spool, fatter mid range, that's the way to do it.
