How much power will my setup make [Mega Merge]
Old Mar 23, 2010 | 05:06 PM
  #151
mattz09's Avatar
any idea how much power i would make
i have a an 06 evo
mods
intake full exhaust
turbo smart dual port bov
mbc
880cc injectors
walbro 255 fuel pump
buschur ported exhaust manifold
o2 dump
injen intercooler piping
i want to get it tuned on 25 26 psi how much power do you think the car will put out?
Old Mar 23, 2010 | 05:10 PM
  #152
xcelr8's Avatar
on a dynojet 350whp is possible
Old Mar 23, 2010 | 05:12 PM
  #153
Wht9er's Avatar
+1. you will be right in that area. get some cams though
Old Mar 23, 2010 | 05:24 PM
  #154
mattz09's Avatar
when i do a bigger turbo i will get cams but for now i just want to look stock and sound stock as possible hopefully in the future do fp black also hks 272 cams
Old Mar 23, 2010 | 05:30 PM
  #155
PsychDr. HN$'s Avatar
No cams and on a dynojet I'd say about 330
Old Mar 23, 2010 | 06:02 PM
  #156
03evo8gsr's Avatar
not hks, go with s2 or kelfords 272
Old Mar 23, 2010 | 06:17 PM
  #157
merlin00069's Avatar
X2. Just by switching from bc 272's to GSC S2's i gained 23whp and 15ft torque. The HKS are better than stock...but they wont yield the results of the kelfords or the S2's. Good luck with your build.
Old Mar 24, 2010 | 06:10 AM
  #158
Mellon Racing's Avatar
I had a customer go from 478 to 540 by changing from HKS 272 and arc air box to kelford 280/272 and cone filter.
Old Mar 24, 2010 | 06:17 AM
  #159
RockmanX's Avatar
thats because you squeeze the life out of setups mellon. Long time no talk. your barely on dont even get a hi how are you doing hi whats new with you
Old Mar 24, 2010 | 06:31 AM
  #160
i've been a busy bee
Old Mar 26, 2010 | 04:30 PM
  #161
mr.almeida's Avatar
Any suggestions for me to get to 400WHP???
Current Mods:
-APS Twin Vent BOV
-MBC
-Greddy Evo 2 TBE
Looking to buy:
-Buschur FMIC
-Buschur LICP
-GSC Cams
-Fuel Pump
-1200 CC Injectors
-E85
-Stock VIII Turbo
Old Mar 26, 2010 | 05:01 PM
  #162
Current Mods:
-APS Twin Vent BOV
-MBC
-Greddy Evo 2 TBE
Looking to buy:
-Buschur FMIC
-Buschur LICP
-GSC Cams
-Fuel Pump
-1200 CC Injectors
-E85
-Stock VIII Turbo
all you need is a good tune on e85 after those parts
Old Mar 26, 2010 | 05:14 PM
  #163
mr.almeida's Avatar
Thanks Mellon, that's reassuring. Diirk from AWD will be doing the tuning. Hopefully one day I'll be able to run down bikes like you.
Old Mar 29, 2010 | 04:37 PM
  #164
Rafael2109's Avatar
how much power and pressure this setup is capable safely
AEM EMS System for the EVO IX
AEM 3.5 bar map sensor
EVO 8/9 oil pump assy.
Mishimoto EVO 7-9 aluminum radiator
Exedy Hyper Twin Disk Metallic For Evo 8/9 HD Pressure Plate
Wet Sump Oil Pan AMS-EVO VII/VIII/IX
Power Enterprise 4G63 Balance Shaft Belt
Power Enterprise 4G63 Timing Belt
JE AMS Spec 2.0 Pistons with upgraded wrist pin and skirt coating (040 nore)
ARP main stud kit
ARP Head Studs
Clevite Rod Bearings
Clevite Main Bearing Set
Clevite Thrust Bearing Set
AMS Coil On Plug Ignition System Plug and Play
AMS EVO VIII Fuel System including Walbro pumps, Fuel Lab regulator, and Aeroquip lines
AMS Oil Pressure Sending Unit Remote Mount
Forced Performance EVO IX RED Turbocharger
80mm anti-surge inlet
Misc Auto Parts FP red Intstall kit
Manley88MM – 33.5 lb. Forged “Race Series” Crankshaft
Oil Cooler Kit AMS Evo VIII-IX Upgraded Oil Cooler Kit
GSC Beehive Spring Kit (includes new seats and titanium retainers)
Supertech 1mm over Intake Valves
Supertech 1mm over Inconel exhaust valves
Misc Auto Parts FIC easy tune fuel injector driver
HKS EVO VIII C... Adjustable cam gear for Evolution VIII
Race Balance Shaft AMS EVO Race Balance Shaft Eliminator Kit (NO CORE)
Fluidampr 2.0 4g63 EVO Mitsubishi-SFI (steel construction)
Cometic MITSU-LANCER EVO4-UP 86MM, .51" MLS
AMS EVO IX Black Radiator hoses
NGK Spark Plug for EVO 9 (Heat Range 9)
map adapter AMS 2g map sensor adapter
ManleyPerformance Pro Series 300M Alloy Connecting Rods
3/8" ARP 2000 cap fasteners
HKS intercooler type R
Custom 3" DP
HKS modified to test pipe
HKS catback
Tomei header
Megan O2
HKS 272 cams
Cant be exactly but some people can give me an estimate, so if this people could help me i appreciate.
Thanks, Rafael.
Old Mar 29, 2010 | 04:42 PM
  #165
geez there's so many mods that have nothing to do with power that it's hard to read and I don't think you mentioned the octane, couldn't possibly guess
