Rear Diff Options - Power Oversteer Found Here
Old Mar 18, 2011 | 09:17 PM
  #511
kyoo's Avatar
+1
my diff was sent to him to get the side cover installed and the diff shimmed etc - FYI, the cusco he designed the diff for turned out NOT to be the cusco I have - he said mine seems to be a newer design, here is the website for anyone w the cusco to check - http://www.cusco.co.jp/en/parts_prod...rs_typemz.html - the type-RS
Old Mar 19, 2011 | 06:22 PM
  #512
EVOlutionary's Avatar
Originally Posted by TommiM
. . . Remember that not always what oem recommends is necessarily optimal for performance. Its all in the details and his experiences with modifying what he has seen be a weak point--- you probably wont see that in any service manual.
Great point. For example - from the factory the OEM transfercase ring and pinion are set up a bit loose becasue the factory figures that the average person is not going to spend the time properly breaking in their drivetrain. This can put the load/contact patch on the outer edge of the ring gear teeth rather than right in the heart of it where it is strongest. . .
Old Mar 21, 2011 | 10:15 PM
  #513
03upstatefire's Avatar
Great info. Makes me less worried about future t-case troubles now that I have one fresh from dogbox.
Old Mar 21, 2011 | 10:30 PM
  #514
milruner's Avatar
This is really good info, was looking at upgrading my rear diff on my evo aswell.
MIKE
Old Mar 24, 2011 | 01:46 PM
  #515
kyoo's Avatar
MIKE
you won't regret it - my personal recommendation as of now is definitely with TRE's
Old Mar 24, 2011 | 10:24 PM
  #516
EvoDan2004's Avatar
well i drove the car today for the 1st time with the new TRE rear.
i also changed a lot of suspension parts. the car will get a realingment but i am pretty sure i got it where it was before i took it apart. here is the weird thing. it feels like the car has rear wheel steering. does the TRE rear give that type of feel?
Old Mar 25, 2011 | 06:42 AM
  #517
Ludikraut's Avatar
^ I'd reserve judgment on that until your alignment. Messed up rear toe can have that effect.
l8r)
Old Mar 25, 2011 | 06:50 AM
  #518
4cdndctn's Avatar
Yep, toe out produces this feeling. Measure to see how many 16ths of an inch you are pointing.
Old Mar 25, 2011 | 06:53 AM
  #519
EvoDan2004's Avatar
Funny thing is I didn't touch any toe settings. Just coilovers sway bar and lower control arms.
Old Mar 25, 2011 | 07:20 AM
  #520
Bassicfun's Avatar
Do you know how the evo toes as you change things like ride height (from coilovers)?
Old Mar 29, 2011 | 09:38 AM
  #521
vortico's Avatar
Has anyone tried the STU legal diff refreshes? Any benefit over the stock setup?
Old Mar 30, 2011 | 10:23 AM
  #522
kyoo's Avatar
the refresh from my understanding IS the stock set up, just reshimmed or whatever to get it back up to factory spec/new - but considering that the stock rear diff is pretty ineffective from the get go i don't think there will be much benefit to be had. i could be wrong though
Old Mar 30, 2011 | 01:08 PM
  #523
griceiv's Avatar
The stock diff has the plates stacked wrong from the factory. The STU legal diff restacks them like the service manual says along with all the other touch up stuff that gets done to the max lock.
Old Mar 30, 2011 | 01:44 PM
  #524
Bassicfun's Avatar
I found the STU legal rebuild to be of NOTICABLE change..
Old Mar 30, 2011 | 03:04 PM
  #525
kyoo's Avatar
gotcha, sorry for the misinformation - i wasn't aware he actually restacked them when he did the stu rebuild - should make a considerable difference then.. didn't see it on the website but im sure he still does it. still can't comment on how much of a difference it makes though
