Post your Synapse DV config and results
Got some more time tonight to test out the remainder of the setting possible. I skipped A port only entirely only because from what I have read, it is the worst setting. I may switch to it at some point to, "nail the lid on the coffin" so to speak of it's validity of use.
Push Mode - B: Felt almost the same as A+B but I got a strange buck in second gear when going WOT into boost and then slowly letting off the throttle (checking if I could find flutter).
Pull Mode - A+B: Coming from the B only port to this felt very different. Didn't get any surge or flutter issues at all. Very drivable and well mannered.
Pull Mode - B: By far the best feeling of the 4 I tested. Everything felt a little more responsive then the other settings. Heal-toe downshifting had a little more pep in it then usual and I had to adjust how hard I tap the throttle. No surge or flutter no matter where I was lifting of how I was lifting off. No problems at low RPM WOT to gradual lifting. I will be doing more testing on this setup as it feels the best for how I drive.
As a note, all of this testing was done with the Boost Connect fittings for ease of change. I will try doing a standard Vac line once I finalize initial testing to see if anything changes.
Yeah I thought they said that it was just the BCS that you shouldn't hook it up with. I tried asking them about the boodt gauge but I never got a reply back. I may try rerouting the lines next week so the DV has it's own designated line but I'm not sure where else I can tap into for the boost gauge.
I'm still uncertain as to which version Synapse I want. On a previous car, I used the DV set up and I loved it. Since then the BOV was released. My car is set up for autox/road racing and I don't feel the Tial QR is responsive enough between shifts. I can definitely tell it is holding me back, even compared to the stock DV.
Anyone here try both?
I also tossed a message to Synapse directly.
Btw, I see you drive evo ix but in your mod lists you have hks 274/278 cams isn't the 274 cam made for evo with non mivec engine?
These are the new HKS MIVEC cams that were released at the same time as the 7460R turbo.
http://hksusa.com/products/?id=656
Yeah didn't really know how to describe it. Thanks
