for anyone that has crankcase pressure issues
Old Apr 21, 2016 | 03:04 PM
  #1381
_des_'s Avatar
I tested one of those with shop air, it failed at 35psi. I got money back on it...lol
Good to know, they say its supposed to hold up until 150 psi. Whats the alternative? a Boomba?
Old Apr 21, 2016 | 03:06 PM
  #1382
LetsGetThisDone's Avatar
Yea, boomba. They seem to work well.
Old Apr 21, 2016 | 03:11 PM
  #1383
_des_'s Avatar
Hmm I guess I'll have to check them out.
Old Apr 21, 2016 | 03:20 PM
  #1384
_des_'s Avatar
I have some of these laying around from the dsm days
http://www.usplastic.com/catalog/ite...6844&catid=489
Really tempted to try them lmfao.
Old Apr 21, 2016 | 03:32 PM
  #1385
asu11's Avatar
Would the boomba be suitable to replace the stock pcv valve entirely?
I've heard some say that he stock pcv not only acts as a check valve, but meters air?
Old Apr 21, 2016 | 03:57 PM
  #1386
The 3/8 boomba restricts enough that the idle is controllable by adjusting the BISS..
Old Apr 22, 2016 | 03:47 AM
  #1387
tscompusa's Avatar
Originally Posted by asu11
Just a heads up for anyone that is having oil in your intercooler/intake system because of crankcase pressure pushing oil back thorough the oil return: clean out your intercooler, piping, intake, and filter now and often if needed.
My car drives 100% better after I cleaned it all out. I did not know it was that bad. The car feels like it is running a lot smoother and picks up noticeably better. I literally poured oil out of my intercooler and intake. Pipes were coated and bov was as well.
The oil coating on the parts also reduces heat transfer and could induce knock. It can also possibly damage sensors.
I got my new setup on and it seems to be working much better. Ill post some pics up later on.
Oil in the intake tract will cause detonation. I hope it wasn't ran like that for to long.
Old Apr 22, 2016 | 03:54 AM
  #1388
tscompusa's Avatar
If memory serves, I hit one of those with over 100psi and no leakage. They work pretty well.
Old Apr 22, 2016 | 05:38 AM
  #1389
TeachersEvo's Avatar
Has anyone tried switching to a less viscous oil to reduce oil pressure and had any success stopping leakage on their DBB FP turbos? I've tried quite a few things now and am about ready to just switch to JB turbo.
Old Apr 22, 2016 | 08:33 AM
  #1390
How much is your turbo actually leaking? Mine gets a little bit of oil in the piping, but it took about 6,000 miles last time before I really felt like it was time to clean everything out. And the TB still wasn't oil soaked. And I run 5w50 amsoil.
Old Apr 22, 2016 | 09:05 AM
  #1391
asu11's Avatar
Longer than I would have liked to. Hopefully my new vent setup will resolve it or at least greatly reduce.
Old Apr 22, 2016 | 09:07 AM
  #1392
asu11's Avatar
I don't think switching oils will assist the issue much less stop it. Hows your current crankcase vent setup?
Old Apr 23, 2016 | 03:53 AM
  #1393
tscompusa's Avatar
My roms are set to flicker your CEL at 3 counts so if you haven't seen it lighting up I wouldn't be to worried.
Good thing is you got it cleaned now, and id recommend you check back on it once summers over to be safe.
Old Apr 23, 2016 | 11:23 AM
  #1394
asu11's Avatar
Yeah it was getting some cel flashing/knock here and there but most of the time it was OK. Just felt like something was holding the car back. Almost like the ebrake was on lol.
Gonna need a retune for the 100+ degree weather anyway so ill be in touch.
Old Apr 24, 2016 | 05:00 AM
  #1395
tscompusa's Avatar
Hopefully not to much detonation. Sounds good!
