Some current oil analysis info, ongoing testing.
Old Jul 22, 2012 | 06:10 PM
  #181
apagan01's Avatar
Originally Posted by Raptord
Andy, I will have a zrod UOA in the next week or 2 to post up.
(I'll also be pm'ing you for more oil shortly thereafter)
Raptord sorry for the late reply.
Got your pm and you got your products
Old Jul 22, 2012 | 07:18 PM
  #182
Raptord's Avatar
Yes sir I did
Old Jul 23, 2012 | 10:12 AM
  #183
TommiM's Avatar
I would get Zrod all day long over dominator. They have very similar ZDDP levels.
But there are some who preffer the dominator, the only reason would be because they want a thinner 30 and desire to have the max anti wear additive available! And dominator holds up to alcohol fuels better than others.
I'd still do zrod
Thanks.
Old Jul 23, 2012 | 10:20 AM
  #184
TommiM's Avatar
Originally Posted by kaj
ah. sounds good. i'll do more reading then. makes sense. i just bought the car. she's stock. will be doing auto-x and track days. mostly daily driving. not sure i need to go crazy on all that.
a guy on NASIOC did a bunch of research on the Walmart Full Synthetic. all the tests came back saying it was as good as any off-the-shelf full syn (mobil 1, royal purple, etc). this was for the subaru engine, though.
any thoughts or has that been discussed.
or, since i'm keeping it simple for now, i should just stick with what's on the oil cap sticker?
i hate when people ask what's been answered a million times...but man. this thread is LONG. LOL
I was curious to test out some of these 'cheaper' brand oils. We had a new motor lined up for the other autox car, a 91 mr2 turbo. I wanted to run some non syn autozone oil in it, along with a few other cheap brands and then send out uoas. The engine and turbo were going to be replaced with an upgrade so worst case scenario wouldnt matter much. Unfortuntaely we didnt have time for it so it didnt happen. That was a more "doing it for sh&t$ and giggles" type of thing than any serious consideration.
There is alot of debate on here even with sticking with whats written on the oil cap. I have some pics of higher mileage valvtrain components tarnished in a coating left behind with this brand of oil. Im uncertain whether this is a good thing or bad. All I know is that when I opened my engine with similar miles and it has never used this oil, it was really clean with none of the varnish
Old Jul 23, 2012 | 10:48 AM
  #185
kaj's Avatar
kaj
I'll go look for the thread. The guy is legit. I believe he's an engineer and paid a lot of Money to run all of the tests on different oils. He used a lot of terminology that was way over my head. Lol. But it was a super interesting read.
Old Jul 23, 2012 | 11:21 AM
  #186
Chef-j's Avatar
I will try get UOA of rotella 15w40. Its not going to be soon, I need to run another 1500 miles tho.
Old Jul 23, 2012 | 12:28 PM
  #187
kaj's Avatar
kaj
i'm looking at using the Rotella t6 as well.
Old Jul 23, 2012 | 12:38 PM
  #188
Chef-j's Avatar
T6 is only 5w40. It is great, i will be using it when temp goes down here.
15w40 is just dino oil with high zinc/pho.
Old Jul 23, 2012 | 02:33 PM
  #189
kaj's Avatar
kaj
synthetic...dino. as long as it protects. and.. it IS about 110* here right now.
Old Jul 29, 2012 | 07:45 PM
  #190
masonh's Avatar
it would appear by looking at the site that if you are high hp and do lots of racing that he Dominator would be the better choice,especially for E85,which most high hp cars here are indeed running on.
personally i prefer Motul 300V to Amsoil for various reasons,but if i had to switch i would definitely go with the Dominator over Zrod.i do run E85 and big hp and i like to race,and i know i need to change my oil frequently no matter what oil i use.
just curious why you recommend the Zrod "all day long"?
i'm guessing Tommie is going to be putting down about 600whp and run E85,i would point him towards the Dominator and frequent oil changes.
unless he plans on putting the car in the garage for a while or just going for longer intervals,why would he choose Zrod ?
Old Jul 29, 2012 | 08:17 PM
  #191
TommiM's Avatar
600 might be a little high. MAP built 2.3 with an EF3 turbo along with all supporting mods and E85 tuned to roughly 27 psi for a road race car. Im guessing numbers will be in the 400's.
Old Jul 29, 2012 | 09:35 PM
  #192
masonh's Avatar
not too familiar with the Map EF turbos.i went to the webiste and they rated it at 550whp so i figured they had it underrated.
anyway,if you are going to be racing it,revving it high and using E85 i would say go with the Dominator.
Old Jul 30, 2012 | 05:31 AM
  #193
apagan01's Avatar
Zrod has the zinc and phos levels that have been considered by the industry to be for high performance. Zrod also has a. Very high flash point meaning it will hold up to the extreme heat that happens when racing.
Zrod also has also good rust inhibitors, and holds up to hot fuels like race gas, ethanol ect... Remember Zrod was designed for V8s and 10s in mind, these engines can be very harsh on oils as they are running nitrous or whatever.
Dominator is a very robust oil from a racing standpoint, dominator does not need to be changed at every race, it was proven here in tje forums that dominator can be ran for over 3 full races, in some cases the oil was put through over 800 miles and track times.
Old Jul 30, 2012 | 05:42 AM
  #194
TommiM's Avatar
It is a tough choice. I have been using Dominator for track days exclusively with great results, and now the Zrod line came out. Both seem to have very similar flash points according to the UOAs. Both have similar zinc and phos levels. THe RD30 did come out with slightly higher levels of zinc and phos. on these UOA's. How much that really matters at that level of zinc and phos between the two, idk.
Its gonna come down to what viscosity Im gonna be running that will work best. usually built engines are being ran on 20w50. I need to find out if something like a 15w50 or 5w50 is doable. So far the only 5w50 I have found doing a quick research is from a brand Id rather not run in my engine though. Im really OCD about my fluids. I usually change all my drivetrain fluids,engine oil, and brake fluid before a track event.
Old Jul 30, 2012 | 09:11 AM
  #195
masonh's Avatar
i'm sure the Dominator has equally high if nor higher zinc and phos levels and the flashpoints of the 2 oils are within 1% of each other.
the Z Rod is a little cheaper though,so if you are trying to save money go with the Z Rod.
i still think the Motul 300V is a step up from both,but between the 2 Amsoils the Dominator is their race car oil.
