Some current oil analysis info, ongoing testing.
Old Oct 22, 2014 | 06:01 PM
  #286
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I'm pretty cosmopolitan.
Old Jan 7, 2015 | 02:29 PM
  #287
Drew1's Avatar
Had an oil analysis done on some Z-Rod 10-30 oil I ran in my engine and when the people over at Blackstone said my great wear was probably not from the oil, I wanted to test it and throw in some OTC Catrol Edge 10-30 (top 5-30 is my typo). These are the results: Z-Rod 10-30 on Right column and Castrol 10-30 on Left column. Middle is Averages for all reports given to Blackstone. Both were done after 5,000 miles with Z-Rod probably 2500 miles E85 and 2500 miles 91. Castrol was 4,000 on E85 and final 1,000 on 91. Daily driven, no tracking.
File Type: pdf
Old Jan 7, 2015 | 03:59 PM
  #288
mrfred's Avatar
Not sure what to make of the report. The content appears similar for both oils for most elements. Some sizable differences in B, Ca, and Mg. Are those found in journal bearing materials?
Old Jan 7, 2015 | 04:33 PM
  #289
TommiM's Avatar
Arent Calcium,Boron, and Magnesium detergent additives?
Old Jan 8, 2015 | 08:50 AM
  #290
Drew1's Avatar
Yes and they explain that in the narrative above the values.
Old Mar 17, 2015 | 10:38 AM
  #291
Mecheng1993's Avatar
How often are oil changes when running E85 recommended? I usually do it when the oil starts smelling like E85, but it happens fairly quickly. (Tune is good)
Old Mar 18, 2015 | 12:13 PM
  #292
Drew1's Avatar
Why do you feel it needs to be changed more often? I have had analysis done on E85 oil after 2,500 miles and then 4,000 miles on it and nothing is different.
Old Nov 5, 2015 | 05:50 AM
  #293
CaptainSquirts's Avatar
Here is my oil report. Car has bolt on's and a tune around 330-340 all wheel hp 93 octane and 93k miles. Ran 10W-30 Signature series for a good 40k miles and recently now using z-rod 10W-30.
Attached Thumbnails Some current oil analysis info, ongoing testing.-oil-analysis.png
Old Nov 5, 2015 | 07:49 AM
  #294
kaj's Avatar
kaj
some people have reported oil issues with e85. i think it depends on which oil... but it seems to be almost random. kinda like the injector "goo". e85 is just weird that way. a friend of mine blew up an engine more than once due to the goo.
if your oil shows no issues then it's all good. which oil are you on?
re the rest of the thread:
i still find no info to deter me from using Rotella T6, though i'm back on a JB turbo, so may look for something with even more zinc.
Old Nov 5, 2015 | 01:57 PM
  #295
Talonboost's Avatar
If it quiets down my lifters like mobil1 0w40, then I most certainly will start using this oil though.
Have you come to any conclusion about lifter tick with Rotella T6?
Old Nov 13, 2015 | 11:42 AM
  #296
Klaiceps's Avatar
Here's my oil analysis with Amsoil Z-Rod 10W-30. Oil had a little over 3k miles on it and it looks like I can definitely go further on it which is good news. This oil had no track time on it. Half of the mileage on this oil was due to a road trip and the other half was from a mix of highway and stop and go driving. The first 400 miles was with E-85 and the rest was on pump gas.
Interestingly enough, I drove through some dusty highway stretches on the road trip with a K&N cone filter and apparently it did a good job of keeping the dust out. I was always under the impression cone type filters never do a good job filtering out dust.
File Type: pdf
Old Dec 24, 2015 | 06:02 PM
  #297
Drsous's Avatar
Does anyone here run motul oil? If so how do you like it compared to all the other oils compared on this thread.
Old Jan 5, 2016 | 05:41 AM
  #298
TommiM's Avatar
300v is one of the best oils you can use. Its more difficult to find and more pricey as compared to something you can go down the street and pick up from a shelf, so thats the downside.
All things considered, imho, with a stock to mildly modded evo (gas or E85 tuned), mobil 0w40 is hard to beat considering all factors; price,performance, and local availability. I am currently EVO-less, I sold my evo, but from information I gathered on here and my own testing, my next EVO is going to see mobil 0w40 exlcusively. ymmv.
Old Jan 5, 2016 | 05:55 AM
  #299
TommiM's Avatar
Sorry for late response, I dont get on here much anymore.
Yes, Mobil 0w40 quieted down my lifter tick the best. Rotella did an ok job, much better than Zrod I was using though.
With the T6, the ticking never completely went away, so I must say that Mobil did better in that aspect.
Old Jan 5, 2016 | 12:36 PM
  #300
kaj's Avatar
kaj
am i reading that you used Amsoil and changed it at 3k miles with mostly freeway and cruising miles? why would you change the oil so soon? was it just for testing?
