New BW EFR Turbo Thread
Old Dec 14, 2014 | 11:30 AM
  #2791
chetrickerman's Avatar
Veteran: Army
Nothing besides 7-9 pounds of weight loss (they weren't sure exactly how much)
Old Dec 14, 2014 | 02:45 PM
  #2792
SWOLN's Avatar
The new housings look pretty amazing with the quick spool valves built into them.
Old Dec 15, 2014 | 09:32 AM
  #2793
R/TErnie's Avatar
anyone have pictures of the QSV'd EFR's? I'm curious how they implemented them.
Old Dec 15, 2014 | 10:05 AM
  #2794
mrfred's Avatar
Originally Posted by r/ternie
anyone have pictures of the qsv'd efr's? I'm curious how they implemented them.
+1
Old Dec 15, 2014 | 12:53 PM
  #2795
RSMike's Avatar
Here ya go
Taken from this page:
http://www.motoiq.com/MagazineArticl...4-Part-II.aspx
Old Dec 15, 2014 | 03:10 PM
  #2796
mrfred's Avatar
Thanks!
Old Dec 15, 2014 | 03:32 PM
  #2797
Tonba's Avatar
That quick spool valve design looks interesting...
Old Dec 15, 2014 | 08:00 PM
  #2798
nollij's Avatar
Quick spool valve is more effective than utilizing the twin scroll for spool up? I would hope so considering it adds weight and another component that can fail.
What turbos in the EFR line have the aluminum CHRAs at this point?
Old Dec 16, 2014 | 10:46 AM
  #2799
SpeedAddict502's Avatar
I agree with you, I would really like to see some data comparing using just a true twin scroll to using the QSV as well. Interesting.
Old Dec 16, 2014 | 11:47 AM
  #2800
mrfred's Avatar
All the flow is being forced down one volute. This gives higher exhaust velocity, so higher driving force for pushing the turbine wheel. I'm sure its only intended to be used at lower rpms where there is not much exhaust gas volume. For rpms above the boost threshold of the turbo in its TS configuration, I'm sure the QSV is not meant to be used.
Old Dec 16, 2014 | 01:41 PM
  #2801
RSMike's Avatar
Yup.
That's exactly why there is a plain Jane wastegate actuator attached to it.
Once it reaches it's desired boost level, the flap will shut.
Old Dec 16, 2014 | 05:19 PM
  #2802
kutija's Avatar
In 1992 Garrett did variable turbine housing for Peugeot 405 T16. For those not familiar there was street version of 405T16. It was 220hp 4wd.It was in production from 1992-1995.
Anyway it also had two actuator one for wastegate and the other for VAT system.Turbo was called VAT25.
Here's the pic:
Old Dec 16, 2014 | 05:23 PM
  #2803
94AWDcoupe's Avatar
thats a really cool design. hopefull for some back to back results with it.
Old Dec 16, 2014 | 06:20 PM
  #2804
nollij's Avatar
Yes, but this turns the TS into a SS until the QSV goes over. Once a turbo is up and running, what is the difference between a SS and TS?
Essentially, this eliminates the separation of exhaust impulses funneled down into their own turbine entry. So, does reducing the volute size at the expense of eliminating the exhaust impulse separation from each bank of cylinders result in increased spool to offset the increased weight and complexity? For BW to do this I would have to assume that this is the case but I would like to see some information to prove this is the case.
Old Dec 16, 2014 | 06:40 PM
  #2805
mrfred's Avatar
My bet is that exhaust velocity wins in this case. But again, I doubt there is a need to invoke the QSV when the turbo is within its "natural" powerband, i.e, if the boost threshold without the QSV is 4000 rpm, then I would think that for anything above 4000 rpm, the QSV is not needed.
