Kinugawa 25g turbo thread
Old Nov 12, 2012 | 08:53 PM
  #211
SANDIEGOSFINEST's Avatar
Originally Posted by VIIIdriver
You're absolutely correct, i bought it from their website a month ago,still have to put it on though.
You wanna sell it?
Old Nov 12, 2012 | 09:44 PM
  #212
2.3stroker's Avatar
http://www.enginebasics.com/Advanced...%20Wheels.html
make sense???? i m not sure
Old Nov 13, 2012 | 03:37 AM
  #213
honda-guy's Avatar
^ i'm sure there's some truth to it. mainly billet wheels allow for small production runs and cost less than to make toolings for cast wheels
Old Nov 13, 2012 | 05:55 AM
  #214
Abcastillo's Avatar
Very Interested
Excelente resultados !!!! Me gusto el torque ...
Old Nov 13, 2012 | 02:00 PM
  #215
VIIIdriver's Avatar
Originally Posted by SANDIEGOSFINEST
You wanna sell it?
Sorry,NO.
Old Nov 13, 2012 | 02:03 PM
  #216
VIIIdriver's Avatar
Originally Posted by Abcastillo
Very Interested
Este turbo salio mejor de lo que esperaba,todavia no he intentado gasolina racing ni alto boost,espero todavia mejores numeros cuando lo haga.
Old Nov 14, 2012 | 08:52 PM
  #217
2.3stroker's Avatar
my car made 409hp at the wheel with this td05hr-25g with 11.5cm ex housing and spool up is pretty quick too!! A big THANKS to boostalot!! and VIII driver too~
Old Nov 14, 2012 | 09:00 PM
  #218
VIIIdriver's Avatar
Glad to see you're having fun with it
  #219
honda-guy's Avatar
my TD06SL2R-20G is still for sale
https://www.evolutionm.net/forums/sa...20g-turbo.html
Old Nov 15, 2012 | 06:25 AM
  #220
94AWDcoupe's Avatar
all the billet wheels made for 4g63 turbos flow better than the their cast counter parts. the hubs made smaller allows better flow . and they are lighter.
take fp gt35r hta wheel for example.
original 35r wheel flows 62lbs. has 61mm inducer.
hta wheel flows 67lbs. and the wheel is smaller with 59mm inducer.
result is turbo flows more and spools faster. win, win
the billet 25g in here has same dimensions as cast wheel, but blades are much bigger due to smaller hub mass. it will flow more no doubt and not sacrifice response in the process.
Old Nov 15, 2012 | 12:13 PM
  #221
VIIIdriver's Avatar
^ Can't wait to try mine out.
Old Nov 15, 2012 | 10:11 PM
  #222
2.3stroker's Avatar
ok~ u sounds more make sense, i just buy a billet wheel and see if i can squeeze another 10-15hp out of it lol
Old Nov 16, 2012 | 10:38 PM
  #223
evo7_8u's Avatar
i've just put one of these on my evo 7 and it has an external oil leak on it , anyone else had a oil leak problem with theres ?? all the fittings are tight and have gaskets and copper washers.
Old Nov 17, 2012 | 06:21 PM
  #224
sparky's Avatar
Have you pinpointed the exact source of the leak yet?
Old Nov 17, 2012 | 06:42 PM
  #225
evo7_8u's Avatar
yes theres oil seeping out where the clamp goes around the 2 halfs to hold it together , and i noticed some oil around the compressor cover where the cir-clip holds it on , it's only externally leaking .Brand new turbo as well .Not impressed to say the least.
