Kinugawa 25g turbo thread
Old Jul 1, 2013 | 09:55 AM
  #526
welshevo's Avatar
Oh the one with a spring on the outside attached to the arm lol. I was thinking about finding another similar spring and adding it in to try and reach 20. I am aiming at running 28
Old Jul 1, 2013 | 10:56 AM
  #527
WikdEvo's Avatar
No not on the outside. That could work though. I had another smaller diamater spring on the inside.
Old Jul 3, 2013 | 01:37 PM
  #528
jaredh's Avatar
Had the turbo shop check the balancing and bore out the catridge for the bigger wheel. Put it all together last night. Everything fit perfect! Great Turbo components! I still need to change to the 25psi wastegate spring I have and do the port/polish. When the build is finished I will post some mustang dyno numbers. Do mustang dynos read low?
Old Jul 3, 2013 | 03:53 PM
  #529
VIIIdriver's Avatar
They generally read low but it all depends on how it's set up, you can set up a Mustang Dyno to read however you want, which is the reason why some people don't trust Mustang Dyno numbers.
Old Jul 3, 2013 | 06:00 PM
  #530
WikdEvo's Avatar
It's just numbers anyhow.. the real numbers are at the track.
I'm a bit confused on your build. Did you take a 9 turbo and have it fitted for the 25g wheel and compressor cover?
Old Jul 3, 2013 | 11:19 PM
  #531
jaredh's Avatar
that is correct.
Old Jul 4, 2013 | 07:33 PM
  #532
dimacoupe's Avatar
hi, guys!
kinugawa sent me new version of actuator and it have some difference with my old actuator
1. preload adjuster much longer
2. actuator body inner skirt deeper for better diaphragm pressing
3. bigger diaphragm
4. actuator body shorter
5. arm is bent more
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
but! look at #2 photo ... i needed shave 0.7mm because cap not pressing diaphragm! and it's new factory billet thing!
forged 2.0 bottom, stock cams, stock airbox, stock ex and in manifold, short ets intake, fic 1100, walbro 255l
actuator preload in maxium, arm move near 3mm! 2 bar actuator spring.
12psi on 4k rpm, max only 26psi on fullboost(100% wgdc in all area) and 19psi on boost off.
too late spool and too low boost system checked on any boost leaks twice.
350 g/s aiflow = 46 lbs/min. it's too low for td06 25g with billet wheel, 11.5cm hot housing
Old Jul 4, 2013 | 10:44 PM
  #533
FastGti69's Avatar
^^ I'm having same issues. I'm like 23 psi at 5.5k rpm and same liek 15psi at 4k rpm. Spools soo slow and I tightened my wastegate downt o the last thread. I checked no more boost leaks either. IDK what to do anymore.
Old Jul 4, 2013 | 11:49 PM
  #534
evoiao's Avatar
I'm at 28 psi and 462 whp on stock cat.
Im thinking about replacing the Kinugawa WG with either a forge WG or a FP WG?
Im looking to hit 30 PSI.
any thoughts?
Old Jul 5, 2013 | 03:39 AM
  #535
WikdEvo's Avatar
With putting a 2 bar spring and a few more smaller springs inside to help I could hit 32#. But that is without having any sort of control over my boost.
You guys could try removing the nut from the waste gate arm and trimming a few threads off. That way you could get even more preload.
My issue with it is that the exhaust pulses were so strong that they were pushing the waste gate flapper open at 32 psi.
My solution was to use an external waste gate in conjunction with the internal. Works perfectly. Hits 30# and holds it to redline. I can also hit 34 for my e85 tune.
Old Jul 5, 2013 | 03:40 AM
  #536
WikdEvo's Avatar
Also, on stock exhaust mani, cams I am hitting 30# @ 4900
Old Jul 5, 2013 | 03:53 AM
  #537
wisniaPl's Avatar
lots of Watergate problems...did anyone tried diff wastegate?? like fp 25psi one? will it fit??
Old Jul 5, 2013 | 07:14 AM
  #538
dimacoupe's Avatar
my graph with removed nut, but it's nothing, no more airflow, only +0.1bar and much more hot air.
preload adujster +5 full 360" from zero preload = 350 g/s airflow,
max preload with removed nut >>>same 350 g/s airflow, but +0.1 bar boost on top
btw, 2.0 bar spring is realy 2.0 bar. blowing with compressor open gate on 2+ bar pressure
Old Jul 5, 2013 | 07:25 AM
  #539
WikdEvo's Avatar
What intercooler do you have?
Old Jul 5, 2013 | 07:28 AM
  #540
dimacoupe's Avatar
blitz
