Kinugawa 25g turbo thread
Old Jul 15, 2013 | 02:41 PM
  #586
rstchris's Avatar
*Update*
I sent the turbo off to Kamak Dynamics in Diamond Bar CA.
They said as soon as they receive it they will ship me a brand new one. Woohoo!
For future ref. if you have issues, don't bother dealing with the guys in Taiwan, call the US number on their website.
Old Jul 17, 2013 | 11:22 AM
  #587
kaonashi's Avatar
On these 25g's is this the exhaust turbine
or compressor turbine?
Old Jul 17, 2013 | 01:53 PM
  #588
WikdEvo's Avatar
Huh?
Old Jul 17, 2013 | 06:24 PM
  #589
kaonashi's Avatar
Is the kit they sell on ebay, the compressor wheel and housing? or exhaust turbine and compressor housing?
Old Jul 17, 2013 | 06:51 PM
  #590
VIIIdriver's Avatar
The 25G refers to the compressor section of the turbo, the full turbo has a TD06SL2 turbine wheel. The ebay conversion kit is only the front 25G housing and wheel.
Old Jul 17, 2013 | 06:57 PM
  #591
FastGti69's Avatar
Can you tell which one I have form this pic? I mean I know it's a 25g, my tuner said I have like 63mm wheel not a 60.5 cause it's not from kinugawa. He ordered it from Mitsubishi or something idk. Is he trippen? lol
Old Jul 17, 2013 | 08:22 PM
  #592
WikdEvo's Avatar
there's no way of telling.. i will tell you that it looks nothing like mine. You'll have to measure the inducer/exducer to get the size if you are really worried.
I'm glad that you got a response about the blown turbo. See, they aren't that bad are they!
Old Jul 17, 2013 | 11:42 PM
  #593
FastGti69's Avatar
Well, I don't know if it's blown yet. My tuner build this for me ready to go, but we had to bend my firewallt o make it fit. My mechanic pulled the actuator and bracket. So I'm guessing that realignment could have messed things up. So I'm paying my tuner out here to build my motor, install cams n valve springs and fix my issue. I'll be somewhere in 500-550whp if this turbo is good for it. I won't have any other restrictions anymore with a built motor.
Old Jul 20, 2013 | 11:51 AM
  #594
kiss_my_SS's Avatar
Mine is finally going in the ol' HHR on the 9th. I hope i can get my 5th injector setup instslled then as well so i can tune on e85 and 93.
On a side note I still havent figured out the lnf ecu payam. I am however tuning a 3076 swap lsj right now. May have james tune it for me but it may be easier without all the factor boost control crap since im using a tial 38 and a hallman pro. I mean is it really necessary to control boost with like 6 different tables? Lol.
Old Jul 20, 2013 | 12:10 PM
  #595
FastGti69's Avatar
Damn dude, you're gonna get it done before me. The LNF Ecu is tricky with the tables. I heard the more you go digging, the more there is lol. LSJ is a totally different breed, I don't even know how to tune haha. Crazy you're doing it!
Old Jul 31, 2013 | 12:12 AM
  #596
FastGti69's Avatar
So if I don't have a boost leak and I'm spooling super slow or not hitting target boost what can it be? I believe I have a 1 bar actuator spring. If I want to boost more than 14.7 psi I would need a stronger spring? I'm guessing its pushing the gasses open as stated above. I'm wondering, if I get the 2 bar spring will I be able to adjust it to be lower than 29psi? Like 24 psi for a DD etc. You know? I just hope the bearing in the turbo isn't shot that's causing this problem... I want to have everything ready cause my tuner is coming down here to build me and fix my issue. I need all parts here in the time frame that he will be here. Thanks again for the help guys.
Old Jul 31, 2013 | 04:06 AM
  #597
dimacoupe's Avatar
2.2k miles...
hot housing made of a foil
hires >>> http://piccy.info/view3/4924670/0012...9a64dc85/orig/
Old Jul 31, 2013 | 04:21 AM
  #598
WikdEvo's Avatar
Wow. That's unfortunate. I'm still running strong at 30 psi. Send it back in to them for a replacement.
Old Jul 31, 2013 | 11:21 AM
  #599
Michael @ FP's Avatar
Originally Posted by dimacoupe
2.2k miles...
https://www.evolutionm.net/forums/10900001-post463.html
Just gonna leave that there.
-Michael
Old Jul 31, 2013 | 11:31 AM
  #600
Because of one bad experience. There are far more fp turbos blowing.
We have an extremely low failure rate even when you count the people who've broken their turbos through their own negligence. Having the most units in production will skew the perception though but I assure you our failure rates are well into the single digits on all models.
Originally Posted by MyronGainz
Yeah, I was gonna say the same thing but I decided to save myself the horror of dealing with the FP fan boys. From what I gather, FP s customer support isn't something to write home about either
But it makes me wonder if its a one off problem or if these turbos have a questionable life expectancy. They definitely don't have the customer base that FP does, so its a little difficult to say
The fact that we have "fan boys" should be a testament to our customer service. People rarely recognize great customer service publicly in this industry but universally almost everyone will share their negative experience.
Creating an advocate is 100x's harder than creating an enemy.
-Michael
